Old 11-07-2004, 07:45 PM   #8461
Default Roll out ...
what is a good/recommended rollout for the Pro4. I race on a reasonably small but fast circuit ...
I'm after top straight line speed with moderate conering speed ..
Using stock 27turn motors with rubber tires...
cheers
hapiya is offline   Reply With Quote
Old 11-07-2004, 07:55 PM   #8462
JDM_DOHC_SiR's Avatar
Trader Rating: 30 (100%+)
Originally posted by Pro4Capece
Those are professional setups. We won't see steel outdrives for a while. Come to think of it, we haven't even been given our promised aluminium spool
I belive I saw the the front Alloy Spool at the Track last night..? .. They just came to Japan..
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 11-07-2004, 08:10 PM   #8463
rc-zombies's Avatar
the aluminum spool was just released in Japan..the US should have it soon.... if you're good... Santa may give it to us by X'mas.
I don't see a need for Steel outdrives. just too heavy and decreases acceleration. but TIR may release Ti outdrives to go with their Ti /Delrin Spools.
Old 11-07-2004, 08:15 PM   #8464
tunerjetta29's Avatar
Pro4Capece: The spool is on HPI's website under option parts, i just havent seen it anywhere yet. http://www.hpiracing.com/newparts.htm
tunerjetta29 is offline   Reply With Quote
Old 11-07-2004, 09:14 PM   #8465
BerNardLee's Avatar
I noticed a lot of them using spool for the World Champ, just wanna to know the main different between 1way and spool in term of car handling....
Is it the main reason is able to apply hard braking to car?
What about cornering, is 1way has better cornering?
Is spool having the same front bevel gear break problem as 1way?
BerNardLee is offline   Reply With Quote
Old 11-08-2004, 07:46 AM   #8466
StewartFan20's Avatar
Default Ackerman
I would like to know what the different ackerman setting do.
The manual does not explain them at all and I have searched this thread and found contradicting answers. One post said that the #3 setting provides the quickest turn in and another post said that #3 provides the least turn in.
Does anyone know which one is correct?
Devil Dog Racing | HobbyTown USA (Kansas City,North) | Fastlane Raceway | Matrix Tires
Someday, I hope to be the man my dog thinks I am.
StewartFan20 is offline   Reply With Quote
Old 11-08-2004, 08:09 AM   #8467
I'm looking for some gear options for carpet for both stock and 19turn. I have asked at the track but got 2 very different answers. My track is only around 80' long by 40' wide. I had one guy tell me 27teeth for stock and another tell me 32t to 33t. I went with 30teeth and it felt pretty good but I was curious what others run. Stock motor is an Epic Binary and the 19t is a chameleon.
DJG24 is offline   Reply With Quote
Old 11-08-2004, 08:45 AM   #8468
Solara's Avatar
Trader Rating: 16 (100%+)
Tower has it on order....it said, mid november (that means early December)...? But for sure we will have it in USA sooner or later.....the best part is, less then $15
http://www2.towerhobbies.com/cgi-bin...?&I=LXJLH4&P=7
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 11-08-2004, 08:52 AM   #8469
Trader Rating: 36 (100%+)
I just ran my Pro 4m last night for its first race and I noticed that the ball cups became very sloppy. I was wondering what some of you other guys were using. I race at RSJ's. I use to use rpm cups on my Losi car but I don't think they will work on the Pro 4 as the ball studs look way bigger than the losi ones.
andy....you can use either RPM or Schumacher Ball Grippa ball cups...both work well.
longer ackerman = more aggressive entering a corner
shorter ackerman = less aggressive, smoother
kevin k or someone could verify this...but in short i believe this is correct.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 11-08-2004, 09:04 AM   #8470
ND
Default Steering Ackerman
Hi
I think the steering ackerman is rated as below
1 Least aggresive
3
2
4 Most aggresive
ND is offline   Reply With Quote
Old 11-08-2004, 09:42 AM   #8471
Erik Shauver's Avatar
Originally posted by Erik Shauver
The settings (steering) go in this order from most aggressive feel to least aggressive: 1, 3, 2, 4. 1 and 2 are with the slanted edges of the plate facing forward, and 3 and 4 have the slanted edges pointing to the rear. The main difference is that 1 and 3 have a lot of initial steering, but 1 has more steering at full throw. 2 and 4 will calm down turn in quite a bit, possibly even causing understeer. The 90 degree arm is just an extra part on the tree, so that that plastic mold is more versatile (as in if we decide to ever turn the servo 90 or something similar).
Erik Shauver is offline   Reply With Quote
Old 11-08-2004, 09:53 AM   #8472
Default Ackerman
So, the stock setting will be the most aggressive. How do the two holes on the steering knuckles affect the ackerman?
Old 11-08-2004, 11:14 AM   #8473
rraden's Avatar
Trader Rating: 224 (100%+)
Need help with a cornering problem. I'm currently running Kevin K's carpet setup but I'm having a problem with the inside rear wheel lifting during cornering. It causes diffing and scrubs off a lot of cornering speed. I tried going softer in the rear but the problem stayed and the chassis just drug horribly. Can anyone suggest a couple of set up changes to try to eliminate this problem?
rraden is offline   Reply With Quote
Old 11-08-2004, 11:35 AM   #8474
JohnB's Avatar
R/C Tech Charter Subscriber
Causing diffing? That's a new one on me. Sounds like you might need a stiffer front spring, the car is rolling to much weight forward. How much droop are you running? I would try stiffer front spring first, then less droop.
I've had good luck with 30 lbs. springs front and rear. Ran 35 lbs in the front a couple times, but usally 30, depends on how the steering feels. Rear droop about 3 mm over ride height.
take care
john
JohnB is offline   Reply With Quote
Old 11-08-2004, 11:39 AM   #8475
JohnB's Avatar
Does anyone know what is on Hara's wires? Thad?
