Like Tree5Likes
Old 11-04-2004, 11:52 AM   #8431
if you are looking for the most reliable and durable car.
hands down to pro 2. It's like a rock.
It has a lot of imperfection as stock ( what comes in the box and basic design), for instant the chassis flex a lot, if you think the flex in pro 4 is bad, pro2 is worse. For acceleration, it is not as good as the top end car on the market today.
but no doubt, it is a great car for beginner.
yeuc001 is offline   Reply With Quote
Old 11-04-2004, 02:35 PM   #8432
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Rookie....maybe there is no offset on the Orion rim....and that is the problem. I know that some nitro foam tires do not have any offset in the rim. Carpet foam rims all have an extra 2mm offset built in I believe...so that might be the problem. Once you get some real carpet foam tires I bet that you wont have this issue. I have seen 30mm TRC foams fit the rear of the car so there must be something with the Orion rim.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 11-04-2004, 04:27 PM   #8433
ChadCapece's Avatar
Unhappy
Has anyone lost a D-clip retaining the shock guides and orings? What did you do to replace it? My lhs said they are on backorder. Is there something else that will work?
ChadCapece is offline   Reply With Quote
Old 11-04-2004, 11:15 PM   #8434
RCGaryK's Avatar
Default Re: front bumper
Originally posted by rai13
Does anyone know of an aftermarket wider front bumper for the pro 4? I keep braking hubs and i think a wider front bumper would help alot.
Also does anyone know if the rpm bumper for a Nitro TC3 will work without modifications? Can I just slip it under the foam bumper?
thanks in advance
rai
You can modify the BRP TC3 front bumper to fit. I just did this myself, took all of about 15 minutes to do, it was pretty easy. Thanks for the heads up on this BTW Erik.
I know a lot of you have gone to aftermarket 3mm chassis sets for your cars on carpet, and I actually just redid my car with the HPI 3mm lower and 2.5mm upper deck. The car feels a heck of a lot stiffer than with the stock chassis. Until recently I didn't even realize HPI had a thicker chassis out there. Something to consider if you are going to swap plates.
Will have photos of the new shell and chassis set soon. Probibally by this weekend.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 11-05-2004, 07:46 AM   #8435
cartmen34's Avatar
You know, that's the ONLY thing I don't really like about his car? I don't like the way the shocks seal assembly is designed.
And I can't find anywhere online that has them in stock either....sure glad I ordered a pair as soon as I found them!
cartmen34 is offline   Reply With Quote
Old 11-05-2004, 08:02 AM   #8436
rod_b's Avatar
Send a message via AIM to rod_b
I think you can use the clips that are used in nitro engines to hold the wrist-pin in place in the piston. They should be approx the same thickness and size...so I've been told.
rod_b is offline   Reply With Quote
Old 11-05-2004, 09:01 AM   #8437
Solara's Avatar
Trader Rating: 16 (100%+)
You might be right, then I have to wait untill the Parma and find out...I have mounted nitro 30mm foams for TP racing, but all I can do is mount the shock to the closest #3 position at the lower arm in order to get the clearence.
Thanks.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 11-05-2004, 12:18 PM   #8438
Default Hara's servo
Hi, just a quick question for you guys. Would somebody be able to tell me which KO servo Hara has been running recently? I saw one with a gold heatsink (i assume) band around it. just wanted to know which model it was...cheers
g4t2 is offline   Reply With Quote
Old 11-05-2004, 12:42 PM   #8439
Trader Rating: 37 (100%+)
Worlds Set-up...
HPI Europe posted Andy Moore's setup in pdf format.
http://www.hpieurope.com/
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 11-05-2004, 03:35 PM   #8440
Aurra Sing's Avatar
You're right, the clips are a little hard to put in and take out, but the whole design of the shock is much more sealed compared to TRF shocks. After 4 races with the Pro4, i rebuilt the shocks expecting to see the oil blackened by dirt, but the oil came out crystal clear unlike TRF shocks after 4 races.
Aurra Sing is offline   Reply With Quote
Old 11-05-2004, 03:52 PM   #8441
JohnB's Avatar
R/C Tech Charter Subscriber
Next time you go to the dentist. Ask for some of their old tools. They will usally give out one or two. They work great on these clips and a lot of other small things.
take care
john
JohnB is offline   Reply With Quote
Old 11-06-2004, 07:30 AM   #8442
VerOn_Pat's Avatar
Default ??
Wanna ask something. Y my rear right feel gritty when i turn my differential and the left wheel feels smooth? is there something binding?
VerOn_Pat is offline   Reply With Quote
Old 11-06-2004, 07:47 AM   #8443
Kenneth Tan's Avatar
Default Re: Hara's servo
Its the KO 2363. The 2364, also with the gold heat sink, is the high-torque variation.
Kenneth Tan is offline   Reply With Quote
Old 11-07-2004, 01:23 AM   #8444
Unhappy easy motor removal
Hi guys, i am a new owner of the pro 4 and simply wanting to know if anyone has developed any tricks for easy motor removal
There surely must be an easier way than an allen key...
Cheers
Michael
sweet'n'sour is offline   Reply With Quote
Old 11-07-2004, 02:15 AM   #8445
Carbon_Fibre3's Avatar
chek the hex hub is not clamped up against the bearings too tight, i chek this every time i put wheels on.
when the wheels are done up too tight, they exhibit a gritty feeling
Carbon_Fibre3 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
