Old 11-03-2004, 04:06 AM   #8401
Eirik's Avatar
octavio,
Most of the HPI Team Drivers including Hara and Moore have been using the thiner 2.0mm chassis from HPI on asphalt this season.....
When I tried this chassis I found the car to have more traction all around and my laptimes where more consistent!!
I recomend this for Asphalt w/Rubber tires!!
For Foams on carpet the 3.0mm chassis will be better I guess....
Eirik is offline   Reply With Quote
Old 11-03-2004, 04:47 AM   #8402
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
Default Re: Re: Re: Front Bevel Gear
Originally posted by BerNardLee
Hi Alan,
when are you going to test at bk's track? today?
I think the track still wet....
Is anyone tested with front diff and it solved the problem?
But how's the car handlering? it may not be the same anymore or may be better???
hi bernard,
i wont have any time to go car testing on weekdays, only on selected weekends whereby my visa gets approved!!
i havent test with a front diff yet, but will on my next visit there. turn in to corners will not be as fast as a 1 way, but probably more stable. i think a front diff better suits the current track design, as there's quite a number of hairpin turns....
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 11-03-2004, 04:54 AM   #8403
azenis's Avatar
Default for asphalt - foam or rubber
Guys running out door on asphalt, what do you run your pro4 on, foams or rubbers?
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 11-03-2004, 05:11 AM   #8404
Eirik's Avatar
azenis,
In Europe we dont use foams at all....!
I have seen someone testing it both on carpet and asphalt. Works really good on carpet, but on asphalt they where slower and had major runtime problems!!
So for asphalt racing, stick with rubber!
Old 11-03-2004, 05:22 AM   #8405
azenis's Avatar
Hi Eirik
At my club its probably around 60:30 foam:rubber, depending on the day.
But foams have so much maintenance, truing and chunking and changing gearing to account for wear, rubber seems so much easier. Not to mention the foam dust all over the car!
I might try a season on rubber to see how it goes...
Nige
Old 11-03-2004, 06:49 AM   #8406
octavio's Avatar
Hey Eirik, thx
this thinner 2.0mm chassis from HPI, is this an option part?
I'll have a look on their site.
Azenis:
we all run rubber outdoors, mostly used is takeoffCS27, or Sorex R28, R32 depending on the temp.
octavio is offline   Reply With Quote
Old 11-03-2004, 07:01 AM   #8407
tunerjetta hpw are you placing the pinion with the set screw close to the motor if so just flip it the motor shaft should be long enough it is on my monter stock with rr purple pinion and it lines up perfect no shimming.
sportracer is offline   Reply With Quote
Old 11-03-2004, 07:02 AM   #8408
Eirik's Avatar
Octavio,
Yes, it's a option part, #73824
Old 11-03-2004, 07:13 AM   #8409
VerOn_Pat's Avatar
Default Asking
Do u think that the pro4 can last as long as Pro3 ??? As in about 2 years before they come out with a new car
VerOn_Pat is offline   Reply With Quote
Old 11-03-2004, 09:00 AM   #8410
Skill's Avatar
Judging by how much of a "failure" the Pro 3 was said to be, and it still lasting for 3 years, I can't see the Pro 4 being replaced in the near future, of course, HPI will be looking at making improvements and possibly testing prototypes, but I think it'll be a while before we get a Pro 5 judging by the Pro 4's performance at the moment.
Skill is offline   Reply With Quote
Old 11-03-2004, 10:05 AM   #8411
Solara's Avatar
Trader Rating: 16 (100%+)
Default Re: Re: carbon graphite shaft
Originally posted by VenomWorldOrder
yes i've been using a carbon HPI shaft in my pro4 with a 6T hacker brushless motor for 6 months with no hassles. it has not twisted 1 mm since installation. the 6T is equivalent to a 7T brushed motor!
Can you give me more information (website) about this Hacker motor...? I am in the market for the BL system for the outdoor race....beside, Novak and the upcoming Reedy, I want to know about this Hacker system too....thanks.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 11-03-2004, 02:53 PM   #8412
Send a message via Yahoo to miniman
www.hackerbrushless.com is their homepage
(I have some BL equipment 4 sale too - shoot me a PM if interested)
miniman is offline   Reply With Quote
Old 11-03-2004, 07:00 PM   #8413
tunerjetta29's Avatar
Can anyone tell me where i can get a carbon fiber shaft for the Pro 4? Ive been looking for one for a while, but most the places that sell them dont sell them for the pro 4.
tunerjetta29 is offline   Reply With Quote
Old 11-03-2004, 07:03 PM   #8414
ChadCapece's Avatar
speedtechrc.com
ChadCapece is offline   Reply With Quote
Old 11-03-2004, 10:25 PM   #8415
yeah I got some binding on my steering knuckles when I built my pro4 too. If you search carefully no this threat , you will notice serval other people have the same problem too.
I guess this is sort of "normal" for the pro 4 owner.
however, I just use sand paper to make my steering knucles a little bit smaller so that it won't have any binding.
yeuc001 is offline   Reply With Quote
