Old 11-01-2004, 08:41 PM   #8371
Solara's Avatar
Trader Rating: 16 (100%+)
Originally posted by Aurra Sing
You have to "break in" RPM ball cups. The way I do it is pop a ball connector on (by itself) and spin the connector in the cup's socket with a dremel. After a few seconds the plastic will warm up and be broken in.
Then again, i've never tried it with HPI connectors. They might be bigger than what I was using..
My other told me the same thing....which I will give it a shot and see, but more likley, I will just simply use the Schmy cup instead..
Just thought if HARA use it, it might be some like plug and play....but now i know it is not even close to plug and play.
Old 11-01-2004, 09:16 PM   #8372
robk's Avatar
Trader Rating: 22 (100%+)
Rookie,
take a pliers and pinch the ball cup,** while it is installed on the ball stud, **as hard as you can. It should free the ball cup, but still be pretty slop free.
Old 11-01-2004, 09:18 PM   #8373
rc-zombies's Avatar
Originally posted by MI2
does any one have a pro 4 for sale
I'll sell you mine for 1 kazillion dollars....
there were a couple on the for sale thread..and a few on Ebay.
good luck.
Old 11-02-2004, 12:55 AM   #8374
BerNardLee's Avatar
Default Re: Re: Front Bevel Gear
Originally posted by alana07
hi bernard,
either we change to a front diff or we avoid banging the track barriers (very difficult to do so)
i was thinking of putting a front diff in next time i go to bk's track again...
Hi Alan,
when are you going to test at bk's track? today?
I think the track still wet....
Is anyone tested with front diff and it solved the problem?
But how's the car handlering? it may not be the same anymore or may be better???
BerNardLee is offline   Reply With Quote
Old 11-02-2004, 02:45 AM   #8375
Nipple's Avatar
Originally posted by Brian McGreevy
Nipple,
Technically, torque = force x radius , work = force x distance
okok
I correct
torque = force x perpendicular distance (Nm)
work = force x distance of the displacement (J)
Nipple is offline   Reply With Quote
Old 11-02-2004, 07:59 AM   #8376
Solara's Avatar
Originally posted by robk
Rookie,
How much will you charge me for doing that...? Or I should do get the Schmmy one from Kriag @ KT....thanks
Old 11-02-2004, 08:06 AM   #8377
Send a message via AIM to galway
If anyone is looking for a pro4 I am selling mine and will probably have pictures up in a couple days. It is mostly stock, but has the tru-spin plate and a ball diff instead of a one-way.
It was raced for 4 months on carpet. I am looking for $200 shipped anywhere in the lower 48. I only accept paypal.
galway is offline   Reply With Quote
Old 11-02-2004, 08:08 AM   #8378
coastaltony's Avatar
If KT is out of the cups, call Adrian @ 813-889-9691. Schumacher is in Tampa, Fl. You might have them by the weekend.
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 11-02-2004, 09:01 AM   #8379
robk's Avatar
"quote:
Rookie,
How much will you charge me for doing that...? Or I should do get the Schmmy one from Kriag @ KT....thanks"
I will fix the ball cups for free as long as you let me give you a demostration of the Tweak-O-Matic.......
Old 11-02-2004, 09:46 AM   #8380
TeamPRP's Avatar
Default Re: Front Bevel Gear
Originally posted by BerNardLee
About the gear cracked problem, I believe somebody has mentioned in this tread before but in order to save some time fo me, can someone can tell me any solution for it.
If you still have the original 1.0 gears and using a one-way diff, you might want to try my aluminum backing plate. We haven't had a gear break since installing it last spring.
Thanks!
B
TeamPRP is offline   Reply With Quote
Old 11-02-2004, 09:59 AM   #8381
rc-zombies's Avatar
Thanks!
B
highly recommended... I've been using the PRP backing plate since it first became available... haven't broken any gears. Still running the original gears.
Old 11-02-2004, 10:07 AM   #8382
BerNardLee's Avatar
Thanks!
B
Is your backing plate same as the ver.1.1 backing plate?
Do you have any photo to show?
Any idea anyone selling this part in Singapore?
Old 11-02-2004, 10:20 AM   #8383
rc-zombies's Avatar
Default Re: Re: Re: Front Bevel Gear
the PRP backing plate is actually bigger than the HPI version.
it covers the entire back of the diff gear.
for pics check out the PRP website.
Old 11-02-2004, 10:29 AM   #8384
Solara's Avatar
"quote:
Rookie,
After looking the RSJ track pictures, I have to lay it down to my wife that I MUST get to there soon....I am shotting sometime within the next 2 weeks....hope to see the PRO 4 gang at RSJ on some SAT....
Thanks for your help Rob....(p.s. are you heading to Cleveland as well...?)
Old 11-02-2004, 10:30 AM   #8385
Solara's Avatar
Hmmm....in USA? Where in the world I have the info that I have to order those cup from UK...? I need to stop sniffing those traction compound for lunch.....LOL
