Like Tree6Likes
Old 11-01-2004, 01:40 PM   #8356
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Jesse is right. From a physics point of view, it's about mechanical advantage. The force required (torque) to turn the spur is lessened because you must use a larger pinion to get the same ratio. The larger pinion has much more leverage on the spur. Therefore, the car will accelerate harder and faster, and the motor will run cooler.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 11-01-2004, 01:46 PM   #8357
JDXray's Avatar
Send a message via AIM to JDXray
Anyone looking for sets of C-hubs 2,4,6 degrees, i have a set of each brand new never used. LMK
Jon
JDXray is offline   Reply With Quote
Old 11-01-2004, 04:15 PM   #8358
TOEBSTER2's Avatar
I'm going to ask you all again about the Pro 4 chassis tweek. Can anyone help out with this issue. Do I have to file the motor plate or something. I couldn't find it posted here earlier.
Crookid Creations
TOEBSTER2 is offline   Reply With Quote
Old 11-01-2004, 04:28 PM   #8359
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Jason.....make sure that all you gear boxs are sitting flush on the chassis and when you put the top plate on make sure that all the holes line up. With the motor mount make sure that you installed it straight across....I have seen them shifted and that might be a cause of a tweak. In regards to the motor mount it is almost like it needs a 3rd screw at the end of it to keep straight as they can get askewed. Hope this helps.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 11-01-2004, 04:35 PM   #8360
TOEBSTER2's Avatar
Thanks Kevin I'll check it out.
Crookid Creations
Old 11-01-2004, 05:42 PM   #8361
Solara's Avatar
Trader Rating: 16 (100%+)
I am having some trouble about the heavy duty RPM ball cup that I am planning to replace onto the PRO 4....I tried a pair of those RPM cup and seems like they are very tight (compare to the stock HPI one).........the whole suspension seems like in lock position up into air (I didn't mount the stock yet)
Did I used the wrong RPM cups....? I used the black heavy duty one, I believed that is the same one that HARA use, and I don't think there are other size from RPM...
Please advise....thanks
Old 11-01-2004, 05:53 PM   #8362
coastaltony's Avatar
Way back someone mentioned using something to spread the opening a little. Try a little experimenting. The Schumacher Ball Grippa's are real nice. Part number is U1704K
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 11-01-2004, 06:26 PM   #8363
Aurra Sing's Avatar
You have to "break in" RPM ball cups. The way I do it is pop a ball connector on (by itself) and spin the connector in the cup's socket with a dremel. After a few seconds the plastic will warm up and be broken in.
Then again, i've never tried it with HPI connectors. They might be bigger than what I was using..
Aurra Sing is offline   Reply With Quote
Old 11-01-2004, 07:29 PM   #8364
Super Steve's Avatar
Send a message via AIM to Super Steve
Hi guys...
bad news!~
I am getting out of rc...
I'll get the most out of it if i part it out, so unless someone gives me an ok offer for everything, I am parting out the NIP parts and hop ups!~
Email me at steven.chun@rogers.com if you want to buy a specific part...
I got lots of hop ups and stuff so let me know!
Super Steve is offline   Reply With Quote
Old 11-01-2004, 07:43 PM   #8365
Nipple's Avatar
torque = force x distance. So bigger pinion and spur will have harder and faster accerleration provided the motor can produce that amount of torque.
We all know the motor draws a lot of Amps during acceleration and this produce lots of heat. So I think the motor is now cooler due to the faster acceleration where time needed for the high amp draw is less.
Nipple is offline   Reply With Quote
Old 11-01-2004, 07:45 PM   #8366
Nipple's Avatar
I truly agree. I got mine from KT Hobbies.
Old 11-01-2004, 08:27 PM   #8367
Nipple,
Technically, torque = force x radius , work = force x distance
USVTA Member #211
Old 11-01-2004, 08:30 PM   #8368
BerNardLee's Avatar
Default Front Bevel Gear
About the gear cracked problem, I believe somebody has mentioned in this tread before but in order to save some time fo me, can someone can tell me any solution for it.
I have the version 1.0 and also version 1.1, both also having the same problem.
BerNardLee is offline   Reply With Quote
Old 11-01-2004, 08:37 PM   #8369
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
Default Re: Front Bevel Gear
hi bernard,
either we change to a front diff or we avoid banging the track barriers (very difficult to do so)
i was thinking of putting a front diff in next time i go to bk's track again...
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 11-01-2004, 08:40 PM   #8370
Solara's Avatar
Yeah....I should have listen, but back then....getting some of those cup I have to FLY to UK to get them, not untill I know KT is carrying them....
I think I will just order from KT and be done with it....thanks
