Like Tree5Likes
Old 10-27-2004, 12:53 AM   #8296
Skill's Avatar
hpipro321,
If you are talking about the plastic spacers which go underneath the battery bar then many people recommend not using them anyway as it keeps the batteries in better without them.
Skill is offline   Reply With Quote
Old 10-27-2004, 12:55 AM   #8297
VenomWorldOrder's Avatar
Default PRO 4 ROLLOUT CALCULATOR FOR FOAMS!
check out the pro4 rollout calculator on my site. provided by a fellow pro4 racer/tc3 racer
www.rcunderground.net
follow the obvious link on the front page
VenomWorldOrder is offline   Reply With Quote
Old 10-27-2004, 07:27 AM   #8298
Trader Rating: 37 (100%+)
Default Re: Question for Nexus on setup
Originally posted by Sluggo
Hey Nexus.....that setup you gave me was there any end measurment on the front and rear swaybars??? Also what spacers are you running behind the rims?? I couldn't get any HPI springs and the Losi springs are a bigger diam. So I found some Associated TC3 with the same rate that fit, they gonna be ok?
sluggo...
i double checked my car setup from the main when it ran best...
the front swaybar is black - 2mm showing on tips
no rear sway bar
i used both the thick and thin spacers provided in the kit behind the wheels.
rear spring - losi purple 20lbs
after running the car i probably would keep the losi black 25lb spring...but both worked fine.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 10-27-2004, 07:56 AM   #8299
sluggo...maybe this will be easier to see.
i will try and convert Kevin K's 2 original setups as well....
Old 10-27-2004, 04:34 PM   #8300
Sluggo's Avatar
Send a message via AIM to Sluggo Send a message via MSN to Sluggo Send a message via Yahoo to Sluggo
Thumbs up
thanks Nexus yes I can see it mint......... gonna try to run friday night I'll let ya know how it works out
Sluggo is offline   Reply With Quote
Old 10-28-2004, 06:44 AM   #8301
KINGZJ's Avatar
Send a message via AIM to KINGZJ
I have a bent front cvd bone. Is their a mip shiny one that will fit in the front?
KINGZJ is offline   Reply With Quote
Old 10-28-2004, 06:44 AM   #8302
pro4racer's Avatar
hi guys
is there any cahnce some one could help me.
i race on a wooden floor in the uk on fridays and need help setting up my pro4 its got grip on the from maybe to much but the back slides out like a drifting car.
some one else at my club has a pro4 hes helped me a bit but not as much as i would have liked but then he cant go giving hes complete setup out now can he.
i use shumacjer minipins yellow and blue compound race in stock if that helps
thnaks in advance
pro4racer is offline   Reply With Quote
Old 10-28-2004, 06:48 AM   #8303
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Jesse, MIP shiny's for the TC3 are a direct fit. I have them on the front of my car
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 10-28-2004, 02:27 PM   #8304
robk's Avatar
Trader Rating: 22 (100%+)
Pro4racer
There's a couple things to try:
Longest camber links possible- it will keep the tires upright, and won't suddenly break traction.
shorten the wheelbase-will add rear traction
Try moving the lower shock positions in one hole- that will soften the suspension overall.
Run o-rings under the upper chassis plate screws-should help add more flex and grip to the car
One thing to think about is the hinge pin mount heights (roll center) on your car. Raising the roll center should allow you to run super soft springs and get some mechanical traction. Of course, i haven;'t raced on a wood floor, so i could be completely out of line
Old 10-28-2004, 02:47 PM   #8305
pro4racer's Avatar
thanks robk for the advice on that i will try it this friday and let u know how well i get on.
on another note i just saw that theres a new version of a yoke sd out and it has machined gear boxes do u ever think hpi will bring these out for the pro4
thkns
Old 10-28-2004, 02:48 PM   #8306
Raaaaab,
you got PM
USVTA Member #211
Old 10-28-2004, 02:56 PM   #8307
pro4racer's Avatar
hi just see this pic on the hpi usa web site and on the camber link mount (inner) there seems to be carbon fibre plates added wots this for and wot differance does it make.
Old 10-28-2004, 03:00 PM   #8308
rc-zombies's Avatar
they are made by Excel.. cost about $20.00 for 4pieces and 2mm thick.
it add strength to the camber mounts.
Old 10-28-2004, 03:07 PM   #8309
pro4racer's Avatar
ok thanks
so does every1 know if hpi will bring out machined gear boxes for the pro4 as i think they should doesent make a differance apart from easier maintence.
wot do u think
Old 10-28-2004, 03:10 PM   #8310
rc-zombies's Avatar
I'm hoping too that HPI comes out machined bulkheads... similar to the new Yok SD world's Edition.
I don't think it will be easier maintenance... you'll have to take the one or the entire bulkhead out to access the diffs. But it will sure look with Purple aluminum bulkheads.
