Old 10-25-2004, 09:35 AM   #8266
Regional Moderator
kansasracer's Avatar
Default Re: Re: Pro 4 rubber on carpet
Originally posted by StewartFan20
Car works great with rubber tires on carpet. I hav a pro4 that I run in stock rubber with a BMI chassis. So far it is the car to beat. Very hooked up.
That's it, now I have to bring the 415, and not break it..
I am watching.....always watching....
kansasracer is offline   Reply With Quote
Old 10-25-2004, 09:43 AM   #8267
StewartFan20's Avatar
Default Re: Re: Re: Pro 4 rubber on carpet
Please do. Last Saturday, we had 8 in stock rubber. Not a bad turnout, but the more the merrier.
Devil Dog Racing | HobbyTown USA (Kansas City,North) | Fastlane Raceway | Matrix Tires
Someday, I hope to be the man my dog thinks I am.
StewartFan20 is offline   Reply With Quote
Old 10-25-2004, 09:48 AM   #8268
Regional Moderator
Yeah, but Wed are better for me....
Now if I can keep the servo saver on, we will be all set!!
Old 10-25-2004, 10:59 AM   #8269
tunerjetta29's Avatar
Erik Shauver: Is there a part number for the 2 hole 1.3mm pistons? That seems to be what is i a few setup sheets, so i would like to get some. Thanks for the info!
tunerjetta29 is offline   Reply With Quote
Old 10-25-2004, 12:20 PM   #8270
Sluggo's Avatar
Send a message via AIM to Sluggo Send a message via MSN to Sluggo Send a message via Yahoo to Sluggo
Thumbs up
Thanks ........ I'll get right on that...(placing order)~~> one diff please.....smooth not crunchy! lol
Sluggo is offline   Reply With Quote
Old 10-25-2004, 12:34 PM   #8271
ChadCapece's Avatar
Erik, how soon will the hpi pro 4 spool be available? I didn't see it on the hpi usa site.
ChadCapece is offline   Reply With Quote
Old 10-25-2004, 02:51 PM   #8272
Erik Shauver's Avatar
tunerjetta29: try #2958A32 at McMaster-Carr
Pro4Capece: Those should be on the "any day now" list. That could mean tomorrow or next month
-E
Erik Shauver is offline   Reply With Quote
Old 10-25-2004, 03:48 PM   #8273
robk's Avatar
Trader Rating: 22 (100%+)
Erik S:
Any idea who is coming out to the Indoor Champs this year?
Old 10-25-2004, 03:58 PM   #8274
Solara's Avatar
Trader Rating: 16 (100%+)
Rob.....I am trying my best to get to the RSJ new track, but I just got the front ball diff........and I have a question for you.
I remembered back then you guys mentioned there is a AE TC3 diff mod on the PRO 4 ball diff....? like using some TC3 screws or something....can you recall that for me..? I want to build my diff right since they are new....and I don't know where to find it on this thread...
Thanks and hope to see you guys this SAT....
Old 10-25-2004, 05:04 PM   #8275
Sluggo's Avatar
correct me on this if I'm wrong ok........
0* pivot block part number in the manual is 75152
I can't find no such thing. I found it under 75156 is this the right number????
Old 10-25-2004, 05:58 PM   #8276
blast's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to blast
i did Kevin Ks set up with stock chassis it worked great i do have a BMI chassis on order.
Kevin thanks
Patrick Connors
FTM Grip
You're not fast if you don't have the grip
A Master key can open any lock, but a lock that can be open by any key is an sloppy lock.
blast is offline   Reply With Quote
Old 10-25-2004, 06:13 PM   #8277
robk's Avatar
Rookie:
You'll need the plastic T-nut , diff screw, spring and thrust bearing parts (washers, balls) from Associated. You can simply substitute them for the corresponding HPi parts. The T nut may be hard to find if you look at Tc3 parts, but the offroad cars use it too, and it might be easier if you look at the offroad diff parts too.
Old 10-25-2004, 06:52 PM   #8278
Aurra Sing's Avatar
Tamiya diff screw, thrust bearing, and nut combo works as well. I like the tamiya parts better becaause theres no dremelling needed and you can use the HPI spring.
Aurra Sing is offline   Reply With Quote
Old 10-25-2004, 06:57 PM   #8279
ChadCapece's Avatar
Default Urgent
Speaking of TC3 diffs.
Erik: Will the TC3 front spool fit in my Pro 4?
thanks
Old 10-25-2004, 07:45 PM   #8280
robk's Avatar
If you put the Tc3 parts in just to replace the HPI parts, they fit fine. If you want to swap sides on the diff, then you have to dremel.
