Old 10-22-2004, 09:03 AM   #8191
Send a message via Yahoo to Doug Gaut
The PRP comes with a 3mm upper and lower deck with additional cutouts in the bottom to remove weight. It is a complete redesign. In addition to the two chassis plates you get side impact protectors with aluminum standoffs and hardware, the Truspin plate that sandwiches the spur gear between the plate and the aluminum input mount for better gear mesh and no flex, titanium hinge pins that are longer to accomodate a longer wheelbase or shorter wheelbase if so desired and a set of roll center adjusters. I have yet to loose a spur gear in 6 months of racing, still running the stock gear but I have had the Truespin plate on the car the entire time.
The Pro4 is race ready out of the box. You dont have to have all the bling like delrin diffs, alum caster blocks,etc. For carpet I would suggest 3mm chassis plates and a BRP bumper then go have fun!!
Doug Gaut is offline   Reply With Quote
Old 10-22-2004, 09:26 AM   #8192
Ive had my pro 4 since they came out still running the original spur no tru spin just tighten the screws down in hex pattern . BMI chassis already has the battery slots beveled all you have to do is seal the chassis.
sportracer is offline   Reply With Quote
Old 10-22-2004, 10:22 AM   #8193
kentech's Avatar
Arrow Pro 4 ready for Worlds
Masayuki Murai's (HPI Japan) worlds car.
http://www.hpiracing.co.jp/cgi-bin/w...cu3_diary.cgi?
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 10-22-2004, 10:28 AM   #8194
Trader Rating: 36 (100%+)
nice pics...i guess i'll be the first to ask...
what's that center post...a 5th body post?
from the hpi europe site...
75175 - PRO 4 SPRING SET (ID14mmxL25mm/7 PAIRS)
Now available for the National Champion HPI Pro 4 touring car is a complete range of racing springs, now in one convenient package. The Pro 4 Spring Set contains 7 pairs of springs specifically tuned by our Team Drivers for the Pro 4, ranging from 273 gf/mm to 400 gf/mm, and color coded for easy identification. Racers need a wide range of tuning options to perfectly match the suspension to track conditions for faster lap times, this will be a popular spring set for Pro 4 owners.
Package contains:
#6542 - 14x25x1.4mm 6 coils (blue / 2pcs) 273 gf/mm
#6543 - 14x25x1.5mm 6.5 coils (silver / 2pcs)(Kit Part) 302 gf/mm
#6544 - 14x25x1.5mm 6 coils (gold / 2pcs)(Kit Part) 340 gf/mm
#6545 - 14x25x1.4mm 5.75 coils (white / 2pcs) 363 gf/mm
#6546 - 14x25x1.4mm 5.5 coils (yellow / 2pcs) 388 gf/mm
#6547 - 14x25x1.5mm 5.25 coils (red / 2pcs) 400 gf/mm
#6548 - 14x25x1.5mm 6.25 coils (pink / 2pcs) 320 gf/mm
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is online now   Reply With Quote
Old 10-22-2004, 10:33 AM   #8195
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
yeah!
Roberto Falcon is offline   Reply With Quote
Old 10-22-2004, 10:34 AM   #8196
X2
X2's Avatar
Yup, works well, ive used one since forever.
It helps supports the shell and helps stop the front wheel arches from starting to crack.
X2 is offline   Reply With Quote
Old 10-22-2004, 10:34 AM   #8197
Yes, it is a 5th body post.
A quite common mod in nitro touring, and now in electric touring.
It helps to support the body under high speed/high downforce!
Erlend is offline   Reply With Quote
Old 10-22-2004, 10:35 AM   #8198
nice paint job but those head lights and grills are ugly
Old 10-22-2004, 10:37 AM   #8199
X2
X2's Avatar
Have to disagree with you there, I think they look sweet!
Make the shell look mean
Old 10-22-2004, 10:42 AM   #8200
no way. makes it look like they spend to much time on it. i think the original lights look way better.
Old 10-22-2004, 10:55 AM   #8201
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Just curious as to which body that is. It kind of looks like a 2 1/2 door sedan. Plus I haven't seen to many trunk lids look that long.
Kraig
KT Hobbies
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 10-22-2004, 10:59 AM   #8202
it looks like a mazda 6 . but im not sure
Old 10-22-2004, 11:01 AM   #8203
rc-zombies's Avatar
They don't paint there own bodies....they're painted by guys from Brain Grafix or TD designs... and all they do all day is paint bodies for racers.
Old 10-22-2004, 11:02 AM   #8204
rc-zombies's Avatar
looks like the ride Acura TSX or TL...
Old 10-22-2004, 11:16 AM   #8205
tunerjetta29's Avatar
Default Anyone race at So Cal??
Have any of you guys raced at So.Cal Raceway with your Pro 4? Im curious as to what type of tires/foams work best? And how are the pro 4's keeping up at So.Cal?
Also does anyone know where online i can get a orion/ hara Revolution motor?? Cant seem to find either the twister ESC's or Hara Revolution motor in the U.S. I have a regular 10x1 revolution but its not as pretty
tunerjetta29 is offline   Reply With Quote
