Like Tree5Likes
Old 10-17-2004, 07:18 PM   #8101
lazyboy's Avatar
Send a message via AIM to lazyboy
Originally posted by rcdougie
Do TC3 steel cvd bones fit on the pro4? Im running a spool and the aluminum ones dont seem to hold up well and im looking for something a little beefier.
yes they do, my friend put some on his car today. went on with no binding or problems at all
lazy
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 10-17-2004, 08:08 PM   #8102
pucho's Avatar
Send a message via AIM to pucho
Default Re: Re: Update on the TiR spool !
Originally posted by tc3 racer sc
what up pucho it ur boy reggie do superior has the spool and i see speedtech has it too also i ran the car really good in our shoot out race the car handle lot beeter wth out the sway bars i did the andy moore set up wth gold springs/ pink hpi springs in bck the car was dial and after about 25 runs and alot of banging i finally broke a c/hub ru going to clevland let me know ok cya
Reggie! Hey I'm not sure TQ ordered mine. If i had to guess I say they don't but they can get it for you. I'm glad the car is working out for you. I'm having some relibility issues but I'm not giving up just yet. Cleveland is a big maybe. I'm starting a new job in a couple of weeks and I doubt that they are going to give me the time off. Hope you can make it down soon. Ill be turning wrenches for A-Lo at the Worlds so if you make it down look me up. We are also having our regional race at Superior that would be a good race to make down to. Take care.
pucho is offline   Reply With Quote
Old 10-17-2004, 08:12 PM   #8103
RCGaryK's Avatar
Originally posted by Erik Shauver
This is to adjust bump steer. You can either add spacers here, or out at the ball under the steering block (end of the steering rods). In stock trim, there is a slight bump "out."
Hey Erik, missed you in Chicago. You you going to be in the office tomorrow? I need to ask you some questions, is one time better than another to call?
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 10-18-2004, 04:02 AM   #8104
Yes they do.
Downforce is offline   Reply With Quote
Old 10-18-2004, 07:18 AM   #8105
clinttredway's Avatar
R/C Tech Charter Subscriber
Trader Rating: 4 (83%+)
Send a message via MSN to clinttredway
Default Need some help
I am about ready to throw this car in the trash...
For the life of me, I cannot keep a battery in the car...
The slots are filed, the cells have shrink wrap on them, I even put dbl sided tape on the underside of the strap...
just venting.. I really don't want to tape in the cells.. but if thats what it takes...
Do or Do Not, There Is No Try
clinttredway is offline   Reply With Quote
Old 10-18-2004, 07:29 AM   #8106
Default Re: Need some help
Throw the factory battery strap/bar away. Tape them in w/ strapping tape.
Old 10-18-2004, 07:31 AM   #8107
artwork's Avatar
Trader Rating: 56 (100%+)
Man I hear ya...I felt the same way yestarday at the track. So what I tried to fix the issue is really very simple. I asked this question a while back and someone posted a great solution.
Here is the solution:
get a body post and mount it (on it's side) to the chassis on the outside of the battery slots. If you look at your chassis you will notice that there are two countersink holes. Simply use a rear body post or other plastic material and screw it to the chassis. Becareful not tweak the chassis with those two screws, and do not use any metal or graphite material as those tend to conduct electicity.
Seemed to work very well...
Look back in the thread you will find the solution in here.
Hope this helps,
Art
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 10-18-2004, 07:31 AM   #8108
myclod's Avatar
Send a message via AIM to myclod Send a message via Yahoo to myclod
yeah i strap mine in using tape like pan car guys use...i left in the battery holddown posts just as a precaution to prevent shifting, never had a problem
myclod is offline   Reply With Quote
Old 10-18-2004, 07:39 AM   #8109
cartmen34's Avatar
clinttredway,
I've been using tape, and this past weekend tried the strap. I had the same trouble as you. Even using screws and washers to screw down the strap didn't solve the problem.
Even though artwork's solution sounds like a winner, I'm not sure I want to add any more weight to that side of the chassis, even if it is just a few screws and some plastic bits.
I'll be going back to the tape method.
cartmen34 is offline   Reply With Quote
Old 10-18-2004, 07:41 AM   #8110
I got so frustrated that I didn't finish my day..
thanks for the info guys..
Old 10-18-2004, 07:44 AM   #8111
clinttredway:
Buy the strapping tape from here: http://www.team1rc.com
It's under miscellaneous. I reuse the same piece all day..... No problems. It saves weight. It's very easy. I really don't understand why people think taping in cells is a pain. Taping in cells would be a hell of a lot easier than what you are going through. It is the perfect solution.
Bodido is offline   Reply With Quote
Old 10-18-2004, 07:46 AM   #8112
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i have a small piece of tube screwed to mine.... ill try to post a pic later.
what i used to use on another car was to use 2 screws and some of those plastic Associated shock nuts. they stick up tall enuff to keep them in, but they are plastic, so as not to short on the batt bars.
im not real fond of the tape, as on my R3 the cells dont fit real well, and they still shift around if i catch a board....
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 10-18-2004, 07:47 AM   #8113
myclod's Avatar
you can also save yourself a few bucks...i get mine from walmart for like 1.99 a roll, just make sure you use the stuff that has fiberglass reinforcement
Old 10-18-2004, 07:50 AM   #8114
Send a message via Yahoo to Doug Gaut
Clint, taping is the way to go. Speedtech and KT Hobbies both have tape as well. I believe the tape that KT sells is the Team1rc stuff. Its much easier to get the car balanced right to left without the battery strap and related parts. Make sure you take a small file and round the edges off REAL good on both sides of the chassis where the tape goes though. I use the KT Hobbies tape and it works great. I too use the same piece all day. I just fold both ends over just a little to have something to grab hold off to remove it.
Doug Gaut is offline   Reply With Quote
Old 10-18-2004, 07:53 AM   #8115
Tamiyadriver, your Pro4 looked real good in the main Sat night! You guys had a great race going till you caught that board trying to avoid running over the leader. Hope you guys come back soon.
