Like Tree6Likes
Old 10-17-2004, 12:21 AM   #8086
Skill's Avatar
Thumbs up
Thanks SteveB that was exactly what I was looking for!
Skill is offline   Reply With Quote
Old 10-17-2004, 05:36 AM   #8087
Essnowyt's Avatar
Send a message via AIM to Essnowyt
On the subject of Ackerman:
If you look at a recent HPI setup sheet there is a spot to place spacers in between the Ackerman and the steering mechanism. My question to the community, what type change would this have? Has anyone tried it? Attached is the portion of the set up sheet with the location. The sheet number is SU-185-2 Thanks for the info guys.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 10-17-2004, 05:56 AM   #8088
Carbon_Fibre3's Avatar
maybe bump steer??
just a guess so dont hold me to that
Carbon_Fibre3 is offline   Reply With Quote
Old 10-17-2004, 06:11 AM   #8089
pro4racer's Avatar
hi every1 i just thought id rearrange my electrics in my pro4 and put it oall on the bottom chassis all squeezed 2gether and wanted to know is it ok like this.
or will this cause problems see pic below
pro4racer is offline   Reply With Quote
Old 10-17-2004, 06:32 AM   #8090
Super Steve's Avatar
Send a message via AIM to Super Steve
I would put the ESC closest to the motor and receiver away from the motor.
(so you should probably swap the ESC and receiver positions)
Super Steve is offline   Reply With Quote
Old 10-17-2004, 06:50 AM   #8091
pro4racer's Avatar
ok mate will do that.
is this becoz it might cause glitching and interfeirance
thanks
Old 10-17-2004, 08:28 AM   #8092
ChadCapece's Avatar
I've had best results mounting the reciever on the upper deck right above the servo linkage. The placing the antenna on the deck as well. It gives plenty room for the esc and reduces the chance of cracking the reciever case on a side impact.
ChadCapece is offline   Reply With Quote
Old 10-17-2004, 08:59 AM   #8093
Skill's Avatar
I put my receiver on top of my servo and use the stock antenna mount position, I haven't had any problems with interference and everythings not squeezed in.
Old 10-17-2004, 10:44 AM   #8094
Erik Shauver's Avatar
Snowy.
This is to adjust bump steer. You can either add spacers here, or out at the ball under the steering block (end of the steering rods). In stock trim, there is a slight bump "out."
Erik Shauver is offline   Reply With Quote
Old 10-17-2004, 10:56 AM   #8095
X2
X2's Avatar
Default Bump steer...
Could somebody please explain what the affects of it are?
Thanks!
X2 is offline   Reply With Quote
Old 10-17-2004, 01:08 PM   #8096
Eirik's Avatar
Hello X2,
I have not tried Bump inn, but I feel that bump out gives a more agressive steering response!!
I have found that adding a 2.0mm washer under the ballstud out by the hub (No Bump Out/Inn) makes the car more stable and forgiving to drive!!
Eirik
Eirik is offline   Reply With Quote
Old 10-17-2004, 01:31 PM   #8097
pucho's Avatar
Send a message via AIM to pucho
Default Update on the TiR spool !
Great idea but the consept was executed quite poorly. I have broken two of the outdives in less than 10 packs. one was a side inpact in the main at the start when we where fightinh for position. The other was in practice I rubbed the pipe coming into the straingt. If I would offer the cups in aluminum or springs steel that would rock.
pucho is offline   Reply With Quote
Old 10-17-2004, 02:15 PM   #8098
tc3 racer sc's Avatar
Default Re: Update on the TiR spool !
what up pucho it ur boy reggie do superior has the spool and i see speedtech has it too also i ran the car really good in our shoot out race the car handle lot beeter wth out the sway bars i did the andy moore set up wth gold springs/ pink hpi springs in bck the car was dial and after about 25 runs and alot of banging i finally broke a c/hub ru going to clevland let me know ok cya
tc3 racer sc is offline   Reply With Quote
Old 10-17-2004, 04:09 PM   #8099
ChadCapece's Avatar
Sup Reggie. Now you can come back to Carolinarc b/c we are now running 19turn. If you see Brandon, tell him to come and race again, if he want's a challenge.
Old 10-17-2004, 06:41 PM   #8100
rcdougie's Avatar
Do TC3 steel cvd bones fit on the pro4? Im running a spool and the aluminum ones dont seem to hold up well and im looking for something a little beefier.
rcdougie is offline   Reply With Quote
