Like Tree5Likes
Old 10-15-2004, 01:01 PM   #8071
clinttredway's Avatar
R/C Tech Charter Subscriber
Trader Rating: 4 (83%+)
Send a message via MSN to clinttredway
I just changed to losi white & black springs and the car has become more aggressive... I like it, but I would like to tone it down just a hair...
*adding*
plus, I just got the car and I am playing with the setup..
Do or Do Not, There Is No Try
clinttredway is offline   Reply With Quote
Old 10-15-2004, 01:08 PM   #8072
cartmen34's Avatar
*adding*
I'm not sure what a losi white and black are in terms of weight, so I'll just say this.... which you probably already know, but...
Typically, the softer you go on a corner, the more traction it will have. It's allowing more weight to transfer to that corner, so that corner sticks a little more.
You also have to consider what you want the car to do.... less agressive off power? on power? neutral power? ... I could go on....
Edit:
If you like the idea of running a swaybar, but want just a slight change, run the smallest wire swaybar in the front of the car. that should tone it down a little.
cartmen34 is offline   Reply With Quote
Old 10-15-2004, 01:10 PM   #8073
white = 30lb and black = 25lb
when I got the car it had assoc purples on all 4 corners... and so I switched the springs and I like it alot better... I guess I am thinking out loud.. err.. on here... lol... has been a long week!
Old 10-15-2004, 01:16 PM   #8074
cartmen34's Avatar
'das cool. Everybody's got to work ideas out somehow!!
in your case, go softer in the rear.
Oh and one more thing...
If you are going to be switching between spring makers, do yourself a favor.....and stop.
I've noticed a difference between a 20lb losi spring and a 20lb AE spring when they are on the track. It's got something to do with the spring material and the way they are manufactured. The losi's feel slightly more progressive than AE springs do.
Either that, or, go to each manufacturers site and get the spring weights for each spring you have. That way you are at least in the ballpark as far as weights go.
Good luck tuning and testing!!!
Old 10-15-2004, 01:19 PM   #8075
If you are going to be switching between spring makers, do yourself a favor.....and stop. I've noticed a difference between a 20lb losi spring and a 20lb AE spring. It's got something to do with the spring material and the way they are manufaturered.
I am moving towards KevinK's setup and he listed either HPI or Losi springs... never used AE springs before, thats what was on the car when I got it...
Yup, just going to change things and see how they work or don't work
i appreciate the info
Old 10-15-2004, 06:35 PM   #8076
josh69162's Avatar
Send a message via AIM to josh69162
Default Toe in/out
This is a little off topic, but I figured while you were on the topic of set-ups:
What is the difference between toe-in/toe-out. I know how the wheels angle and stuff, but what does it do physics-wise to the car? I've messed around with it a little bit, and I tend to like toe-out more, but since I don't know anything about it, I don't know why. Thanks in advance, sorry for barging in like this.
-Josh
josh69162 is offline   Reply With Quote
Old 10-15-2004, 07:26 PM   #8077
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
Quick and dirty:
Toe-out tends to give a more steering and will cause the car to wonder on the straight a little.
Toe-in will make the car a little easier to drive and track straighter...
Most run from -1 to +1, to much in either direction will do some strange things.
It can be a good tuning aid and quick fix.
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 10-15-2004, 07:56 PM   #8078
Aurra Sing's Avatar
off the top of my head,
Front Toe-in: more stable, less steering response, more mid corner steering
Front Toe-out: less stable, more steering response, less mid corner
For dialing in a car I play around with the bigger things such as tires, springs, droop, caster, oil, shock mounting positions. Toe-in shouldn't be the top priority when you are thinking of changing the setup. I always keep it at 0deg and only change it if it's necessary or for fine tuning.
Aurra Sing is offline   Reply With Quote
Old 10-15-2004, 10:13 PM   #8079
cartmen34's Avatar
What he said. It's a last resort adjustment in my book.
Old 10-15-2004, 10:16 PM   #8080
josh69162's Avatar
I thought swaybars were. Have I been misled?
-Josh
Old 10-15-2004, 10:47 PM   #8081
Aurra Sing's Avatar
-Josh
in R/C, you'll get a million different answers from a million differnt people... IMO sway bars have more affect than front toe
Old 10-15-2004, 11:50 PM   #8082
Skill's Avatar
Does anyone know what the different ackerman positions do? Is the stock setup in the middle or at 1 end of the scale? Which hole do you use for the most effective ackerman and for the least effective ackerman?
Thanks,
Steve
Skill is offline   Reply With Quote
Old 10-16-2004, 09:19 AM   #8083
Trader Rating: 37 (100%+)
Thanks,
Steve
steve.
checkout this link.
http://www.rctek.com/handling/ackerm...principle.html
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 10-16-2004, 10:35 AM   #8084
Skill's Avatar
Nexus, thanks for the information, what I actually meant was which postition on the steering plate for the Pro 4 will give the greatest/least askerman affect.
Old 10-16-2004, 12:17 PM   #8085
Skill The following was posted ages ago on this thread
Ackerman
The settings go in this order from most aggressive feel to least aggressive: 1, 3, 2, 4. 1 and 2 are with the slanted edges of the plate facing forward, and 3 and 4 have the slanted edges pointing to the rear. The main difference is that 1 and 3 have a lot of initial steering, but 1 has more steering at full throw. 2 and 4 will calm down turn in quite a bit, possibly even causing understeer. The 90 degree arm is just an extra part on the tree, so that that plastic mold is more versatile (as in if we decide to ever turn the servo 90 or something similar).
This cleared it up for me.
Steve B is offline   Reply With Quote
