Old 10-13-2004, 01:31 PM   #8041
big_G's Avatar
R/C Tech Charter Subscriber
HPI make it and part number is on the web site.
Most LHS are stocking this part
big_G is offline   Reply With Quote
Old 10-13-2004, 02:24 PM   #8042
azenis's Avatar
Thanks Skill and Jonny69
The block doesnt appear to be bent, I will see what happens when i fit the 2.0 up tonight
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 10-14-2004, 02:42 AM   #8043
Carbon_Fibre3's Avatar
Hey Pro 4 ppl, i am just gettin my pro 4 ready for its virgin run this weekend, and was chekin to make sure teh car had equal lock both ways. obviously this can be adjusted via end point adustment.
\but basicaly teh problem is i cant get equal lock left to right
right lock i can get upwards of 24 deg
left lock i can only get like 11 possible less
What im asking is where abouts do you pro 4 guys have our servo arm.. directly up? leanin towards centre of chassis? or leanin out of the chassis
once i have the servo arm positiond, should i tune the length of the steering arm length?
because i can acheive good lock boht ways.. or i can see how i could.. but then the ackerman would be screwed side to side
maybe im overly confusing myself.. i dunno?
Rob Storey
Carbon_Fibre3 is offline   Reply With Quote
Old 10-14-2004, 02:42 AM   #8044
sorry doulbe post
Old 10-14-2004, 02:48 AM   #8045
Entropy's Avatar
Just run it stock. And leave the worrying to the pros
Entropy is offline   Reply With Quote
Old 10-14-2004, 02:56 AM   #8046
i thought it was stock, which is why i raised the question in the first place..
bak to the destruction manual. thanks for you help
Old 10-14-2004, 03:01 AM   #8047
Entropy's Avatar
Most ppl do not have problems with the steering, except perhaps the knuckle hitting the hubs but thats probably too much steering for you own good
Helps to have a caliper handy to measure the linkages/turnbuckles.
Remember to try to center the steering as much as possible and center the servo with the transmitter and electronics on before mounting the servo arm onto the servo. At least you get a nice centralized starting point to work out the EPAs.
Old 10-14-2004, 03:04 AM   #8048
pucho's Avatar
Send a message via AIM to pucho
I placed my arm at 90* and the adjusted the drag link, I them used a Hudy set ukp station to make sure it was all peechee.
pucho is offline   Reply With Quote
Old 10-14-2004, 06:36 AM   #8049
robk's Avatar
Trader Rating: 22 (100%+)
Carbon_Fibre3:
You may need to cheat the servo arm slightly to the left side of the car. At neutral, my servo arm is a few degrees past 90* toward the left side of the car.
Old 10-14-2004, 07:05 AM   #8050
coastaltony's Avatar
Look at this
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 10-14-2004, 07:07 AM   #8051
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
FYI: Kevin K set-up from last weekend at the Gate!
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 10-14-2004, 07:09 AM   #8052
clinttredway's Avatar
Trader Rating: 3 (80%+)
Send a message via MSN to clinttredway
Thanks Tres... BTW - I think I can finish my Flash Setup sheet if you are still interested...
Do or Do Not, There Is No Try
clinttredway is offline   Reply With Quote
Old 10-14-2004, 07:15 AM   #8053
Tres's Avatar
clinttredway: yes, I forgot to ask you that when I did your Race Plates.
Tre's
www.tnt-fx.com
Old 10-14-2004, 07:17 AM   #8054
kewl.. I will finish it.. I made some changes and re worked how the setup sheet works..
should have it for you tomorrow...
Old 10-14-2004, 10:29 AM   #8055
gijoe64's Avatar
Trader Rating: 27 (100%+)
hello, I am confused on what springs to use. Hpi has many types of springs. I purchaced the Pro 4 pro springs, In Kevins setup
he uses HPI Green, but HPI has 2 different set of green springs
is it possible if you could put HPI part number next to the spring it
makes it easer to determine what spring to use. I would like to
use HPI spring but they have so many that it is kind of confusing for me.
gijoe64 is offline   Reply With Quote
