Like Tree5Likes
Old 10-11-2004, 09:27 PM   #8026
Send a message via Yahoo to Doug Gaut
Hey cool! Glad to know that!!! Thanks Rob.
Doug Gaut is offline   Reply With Quote
Old 10-11-2004, 09:53 PM   #8027
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
The sway bar that I have on my car is home made and is a copy of the stock ones just thicker gauge wire. It fits in the car with out any other mod....like drilling out the ball link or the diff case. If you go with a bigger gauge wire then you will need to make some modifications so everything fits. The wire I got from my LHS most seem to carry that type of stuff.
When you use the TC3 bars they are little wider then the stock bars so you might need to pinch or squeeze them together so the ends are not so far apart. They fit but the end links are not perpendicular to the lower arm unless you squeeze them together more.....and if the links are not perpendicular then they might not work as well.....this is why I bent my own bar....but TC3 ones are easy to get and make fit.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 10-12-2004, 12:52 AM   #8028
ND
Default Diff Thrust Bearing
Hi guys
I have a question regarding the thrust bearing in the diff. Does anyone make a moulded thrust bearing rather than using just the balls and 2 plates????
ND is offline   Reply With Quote
Old 10-12-2004, 01:09 AM   #8029
Eirik's Avatar
Default Re: Diff Thrust Bearing
Originally posted by ND
Hi guys
Hello ND,
I use the Tamiya trust bearing along with the Tamiya diff screw and Spring and it works awesome!! No modification needed and it's far more reliable than the stock parts! Makes the diff super Smoooooooth!
Eirik is offline   Reply With Quote
Old 10-12-2004, 01:45 AM   #8030
ND
Hey Eirik
Do you have the Tamiya part numbers for the screw, bearing and spring?
Cheers
Neil
Old 10-12-2004, 02:30 AM   #8031
Eirik's Avatar
Hey Eirik
Cheers
Neil
ND,
Tamiya Diff Screw = 9805669
Tamiya Trust Bearing = 9805670
Sorry could not find anything for the spring, but Yokomo spring will fit good as well......
Speedtech should have everything in stock, so you could always ask in his tread!
Old 10-12-2004, 02:35 AM   #8032
blast's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to blast
hey kevin k. what front drive did u use?
Patrick Connors
FTM Grip
You're not fast if you don't have the grip
A Master key can open any lock, but a lock that can be open by any key is an sloppy lock.
blast is offline   Reply With Quote
Old 10-12-2004, 09:38 AM   #8033
Kevin K's Avatar
Im not 100% sure what you mean by this but I had a diff in the front if this is what you are asking.
Old 10-12-2004, 10:19 AM   #8034
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
Kevin K: drop me an email, I have a set-up sheet for you.
tres@tresleonard.com
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 10-13-2004, 05:22 AM   #8035
azenis's Avatar
Default rear suspension questions
couple of quick ones...
i am running my car in stock, and was thinking of reducing rear toe. i have the following blocks - 0, 1, 1.5, 2, 2.5 (fitted to the front) and 3
What would I be best to use? I was thinking 1.5 to start with?
Also when I have my car on my setup station, with the 3.0 block on (havent tried others yet) it measures 2.5 on the left hand side, but 3.0 on the right hand side. anyone else have this happen? It is the same if i flip the gauge over and use the reverse, so i dont think it is the gauge (though it could be out somewhere....)
Also there is a lot of fore and aft movement in my rear a-arms, what is the best way to get rid of that?
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 10-13-2004, 05:25 AM   #8036
azenis's Avatar
oh yeah... i am running CS22s this weekend, have been running ellegi (and have more on the way so will be swapping between them depending on conditions)
Also got a diff in the front
Nige
Old 10-13-2004, 06:30 AM   #8037
Going from 3, to 1.5 rear toe will give you a dramatically free rear end in comparisom to the 3degree blocks. I would try 2, or 2.5 first.
When you tighten the screws to the blocks try tightening them whilst compressing the two blocks togeather, this will remove alot of the slop. I you have differnt amounts of slop either side then your rear toe will be out, just retighten and check again on the gague. Jonathan
jonny69 is offline   Reply With Quote
Old 10-13-2004, 06:41 AM   #8038
blast's Avatar
yes
thank you
Patrick Connors
FTM Grip
Old 10-13-2004, 08:19 AM   #8039
Skill's Avatar
If your toe is out then it is possible you have bent one of your pivot blocks and that is what is also causing the slop in the wishbones.
Skill is offline   Reply With Quote
Old 10-13-2004, 01:13 PM   #8040
StewartFan20's Avatar
Default Woven Graphite Drive Shaft
Anyone know who makes the woven graphite drive shaft? And, where might I get one?
Devil Dog Racing | HobbyTown USA (Kansas City,North) | Fastlane Raceway | Matrix Tires
Someday, I hope to be the man my dog thinks I am.
StewartFan20 is offline   Reply With Quote
