Hpi Pro 4
#8011
Trader Rating: 32 (100%+)
Re: oh boy
Originally posted by robk
Kevin won the B. I pretty much crapped out. My car was really good, and I had a chance to do a 20 lap run, but I stepped on it. Euge (Eugene Sia) actually kicked ass for his first big race! Drove great all weekend.
#8012
Modified
Hi,
Im going to start running mod on a tight concrete track, are there any parts I should add (delrin outdrives?) to the car or any setup changes that are different to stock?
Cheers,
Mossie
Cheers,
Mossie
#8013
Yeah, you need to make the upperdeck mod, run a front spool, and get the BRP front TC3 bumber.
#8016
Thad or Eric...swaybars question.
I noticed on some of the carpet setups you note a 2mm front swaybar.
Did this come from another kit or different car? Or was it a one off?
I am trying to locate a 1.8mm and 2mm swaybar that would work..Any one have any suggestions?
I would rather not bend one out of wing wire.
Jamie
Jamie
#8017
Senna and Tres....I will post it later tonight. Tres....I will PM it to you aswell maybe you can add it to a Setup sheet and post it for everyone to see clearly.
#8018
Hey guys, just wanted to let everyone know that the new rebuildable spool for the Pro4 is instock
The spool sells for $49.99 and comes with an extra set of delrin cups.
Should be on the website sometime tomorrow www.schumacherusa.net
Sup Kevin!!!
Sup Kevin!!!
#8019
Halloween Classic setup
Here is what I ran....if I left anything off let me know...
Front....
#2 hole on the shock tower
#1 hole on the arm
2mm under the inner ball stud
1.5mm under front pivot block
2mm under rear pivot block....gives 1/2mm anti dive.
0 deg pivot block
6 deg castor block
#2 hole on steering knuckle
#1 hole on steering plate
.078" sway bar custom bent
2mm showing on sway bar
#2 hole for inner camber ball stud
1.5 deg camber
.5 deg toe in
2mm of droop
4.5mm ride height
#3 piston
45 wt trinity oil
HPI 6759 pink spring 540 gF/mm (30.2lbs)
stock bladder with foam
TM Racing Plaid 3 tires 2.30 Dia
Rear....
#4 hole on shock tower
#2 hole on arm
2mm under inner ball stud
1.4mm sway bar
1mm showing on sway bar
#2 hole on inner camber location
#2 hole on hub carrier
Hub spaced with thin washer in front and thicker washer in rear(stock washers)
1.5deg arm mount
.5 mm spacing under front and rear arm blocks
1deg camber
4.5mm ride height
2mm of droop
#3 piston
40wt trinity oil
HPI 6756 green spring 480 gF/mm (26.9 Lbs)
Stock bladder w/ foam
TM Racing Black 2.30dia
104t spur
32t pinion
New EPIC ROAR stock hand out motor
Mazda 6 body used with stock wing cut down a little and no inner plates
2.5 OZ of weight added near and around the motor area
Futaba 9550 servo
Novak GTX
Delrin Outdrives used front and rear
Used PRP HTS 3mm Chassis and Top Plate with two center posts and wheel base extended 2mm over stock HPI chassis.
Front....
#1 hole on the arm
0 deg pivot block
6 deg castor block
1.5 deg camber
.5 deg toe in
2mm of droop
4.5mm ride height
#3 piston
45 wt trinity oil
Rear....
#2 hole on arm
1.4mm sway bar
1.5deg arm mount
1deg camber
4.5mm ride height
2mm of droop
#3 piston
40wt trinity oil
104t spur
32t pinion
Futaba 9550 servo
Novak GTX
#8020
Re: oh boy
#8022
Nexus....I would say high bite. But its really not that far of from what I run week to week. A little stiffer rear spring and a little less toe-in in the rear.
#8024
Jamie, you will need to go to the local hobby store or hardware store and buy some piano wire the desired size and bend your own as there are no other sizes on the market right now. Its not too hard to do if you have a nice pair of vise grips and some time to make sure all the bends are correct. If you go much bigger than the 1.6mm stock one you will need to drill out the gear case where the bar goes though with the retainer installed and the set screws backed off and also drill out the aluminum balls for the wire to go though.
