Like Tree5Likes
Old 10-10-2004, 06:04 AM   #7966
wolfracing's Avatar
I'll try that , thanks man.
wolfracing is offline   Reply With Quote
Old 10-10-2004, 04:17 PM   #7967
BrettBowen's Avatar
Send a message via AIM to BrettBowen
Default Diff Screws
Hey guys... I keep breaking the heads off of the diff screws on my Pro-4. The thing runs great, but i broke 4 screws the exact same way this weekend.... does anyone have any ideas of why this is happening? The Diff isn't too tight.. im not hitting anything. I will just be running then all of a sudden....2 wheel drive.. Has anyone had this problem?? I am putting it together just as the directions say to... I've built a lot of diffs and never had a problem... Help!!
Thanks in advance,
Brett
BrettBowen is offline   Reply With Quote
Old 10-10-2004, 04:24 PM   #7968
Lost Aggresiva's Avatar
Default Re: Diff Screws
I've had a problem with that too. When I was building the diff, I kept tightening the nut until it locked. Guess I'm too used to building associated diffs.
On another note, has anyone had any problems with certain rims on the rim? I tried putting Schumacher rims on the car this weekend. 3 corners of the car were fine with it, but the right rear locked up when I tightened down the nut. Weird.
Lost Aggresiva is offline   Reply With Quote
Old 10-10-2004, 04:35 PM   #7969
Default 3mm Chassis
Just a quick question guys, when moving to a 3mm chassis from the stock chassis do you add or remove spacers?
Cheers,
Mossie
Mossie is offline   Reply With Quote
Old 10-10-2004, 05:06 PM   #7970
Trader Rating: 37 (100%+)
Thanks in advance,
Brett
brett.
many of the people on this forum have switched to using the AE TC3 Diff screw, spring, and T Nut. If you read thread this thread you can find information on it....
in short just replace the HPI parts with the ones i mentioned.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 10-10-2004, 05:25 PM   #7971
Default Re: Re: Diff Screws
I've got one question about that that's probably been anwered already, but I don't have enought hours in a day to back through this whole thread.
Do you need to replace the stock HPI outdrive to use the T nut? I'm a bit stumped on this part. See as how the outdrive is molded to take the nut in it. Any help would be greatly appreciated.
Old 10-10-2004, 05:26 PM   #7972
azenis's Avatar
I have busted te heads off two screws, one rear and one front one that was only 1 race old! The Assosiated mod is very very worthwhile!
brett.
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 10-10-2004, 05:29 PM   #7973
azenis's Avatar
Here is the diff mod
Nige
Old 10-10-2004, 05:31 PM   #7974
No...the only parts you need to replace are the diff screw, white t-nut, and spring. the AE TC3 diff rebuild set has everything you need.
you can build it like the pic he attached....where you need to dremel the HPI outdrive.
or
just build it the normal way using the AE parts.
i have watched people use both ways with success.
Old 10-10-2004, 06:12 PM   #7975
Default Re: 3mm Chassis
Cheers,
Mossie
Does anyone know the answer to this?
Old 10-10-2004, 06:13 PM   #7976
racer's Avatar
Originally posted by Erlend
Hey, where did you guys get the carbon bumper-brace?
Looks way cool!
the bumper brace is made by Square
here is the link:
Square
racer is offline   Reply With Quote
Old 10-10-2004, 06:49 PM   #7977
Kenneth Tan's Avatar
Default Re: Re: 3mm Chassis
I would presume that you are moving from a 2.5mm (stock) chassis to a 3mm chassis. Then you should remove 0.5mm from your current settings.
Kenneth Tan is offline   Reply With Quote
Old 10-10-2004, 06:57 PM   #7978
thanks will do.
Cheers,
Mossie
Old 10-10-2004, 07:24 PM   #7979
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
or
I just finished the diff mod last night. Is it just me or I had to tighten the screw a lot to get it at least a bit tight?
DOMOisCOOL is offline   Reply With Quote
Old 10-10-2004, 07:55 PM   #7980
ChadCapece's Avatar
What's the best way to make a spool out of the standard diff? I've super glued the diff halves to the gear, and driven a long button head screw through the whole assembly. Is there a better way?
ChadCapece is offline   Reply With Quote
