Like Tree6Likes
Old 10-09-2004, 11:48 AM   #7951
rc-zombies's Avatar
Originally posted by X2
Lookin' good Zombies. Is that a big capacitor you can see through the front window sticking up?
That's my 7th cell....
that's the stock capacitor from the GTX.
Old 10-09-2004, 12:53 PM   #7952
Super Steve's Avatar
Send a message via AIM to Super Steve
ok took some picture befor going running outside...
It works goooooooooooood...
Super Steve is offline   Reply With Quote
Old 10-09-2004, 12:54 PM   #7953
pic 2
Old 10-09-2004, 12:55 PM   #7954
picture with body and radio!
Old 10-09-2004, 01:00 PM   #7955
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Originally posted by rc-zombies
Finally finished, trimmed and decaled ...
Ready to do battle...
Wow, awesome! Hara's painter will be proud
Anyone know where I can get those "hpi-racing" style decals? I used all of mine already from the v1.1 gears offer.
DOMOisCOOL is offline   Reply With Quote
Old 10-09-2004, 02:45 PM   #7956
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
Default help !
hey i need help finding the right gearing . (stock racing) right know i have a monster geared at 36t and today it just started to smoke and when i took it apart at home it was fryed! ... im running at a track of 80ft X 50ft. ... thanks for the help
Roberto Falcon is offline   Reply With Quote
Old 10-09-2004, 03:01 PM   #7957
racer's Avatar
here's a picture of my car
racer is offline   Reply With Quote
Old 10-09-2004, 03:06 PM   #7958
DOMOisCOOL's Avatar
Default Re: help !
Run a 98t spur and 30-32t pinion
Old 10-09-2004, 03:10 PM   #7959
i ran my 33t pinion and that motor and it got so hot that i think if you would have put a piece of paper on it and it would starting to burn . and my esc got hot! and the battery where wow . to hot to even touch
Old 10-09-2004, 05:15 PM   #7960
rc-zombies's Avatar
Very nice!
Old 10-09-2004, 06:49 PM   #7961
clinttredway's Avatar
Trader Rating: 4 (83%+)
Send a message via MSN to clinttredway
Default Re: help !
I run on a track slightly bigger and I ran 98/32 with a monster stock and it was great.. I ran a 34 first and my motor got way too hot.
Do or Do Not, There Is No Try
clinttredway is offline   Reply With Quote
Old 10-09-2004, 07:03 PM   #7962
josh69162's Avatar
Send a message via AIM to josh69162
Default Body selection
Originally posted by Doug Gaut
I also prefer the Parma Alfa body on carpet. It has great balance and transitions very fast.
Is it just me, or when I look at the body lists from RCCA of who is running what body at the races, I don't see any HPI bodies. Protoform/Parma's bodies can't be that much better than HPI's, can they? I ran a Dodge Stratus Aero 2 (190mm, and I thought way more pros would have HPI's Stratus 2 than they did. There wasn't one HPI body on the list) at the HPI challenge, and it handled wonderfully. Much better than a Lamborghini... What's the deal? And what do you guys think of the Pro4 vs. the TC3? Is it too close to call? Does it all come down to personal preference. I noticed HPI has much more carbon fiber, and AE has more carbon plastic. Thanks in advance.
-Josh
josh69162 is offline   Reply With Quote
Old 10-09-2004, 08:46 PM   #7963
wolfracing's Avatar
To much off power turn in, any advice on how to cure this please.
One way up front, elligy 42's front , standard sway bar and gold springs , with kit oil in shocks at front. Lower arm shock in middle position, and shock mounted 3rd hole out. In an attempt to make the front end stiffer, less weight transfer.
Rear, ellegi 35's, orion 20 wt oil in shocks, removed sway bar, all the rest of the car is kit box settings.
I found with the kit box settings after assembly the car was allmost uncontrollable with waaayyy to much off power turn in.
It's improved a hell of a lot now.
Our track has a shit load of off camber turns as well which makes matters worse, but the other dudes in the club are all going alright, it just seems ths pro 4 all have the same problems.
Any advice is much appreciated.
Wolf
wolfracing is offline   Reply With Quote
Old 10-10-2004, 02:18 AM   #7964
Hey, where did you guys get the carbon bumper-brace?
Looks way cool!
Erlend is offline   Reply With Quote
Old 10-10-2004, 03:11 AM   #7965
Wolfracing, you could try some stiffer springs up front to decrease the weight transition as you come in to the turn, or put all of the weight (if you use it) in the back. Also on the roll centre spacers (under the toe in blocks) you can lower them to get less grip in the front, this will make it easier to drive. Jonathan
jonny69 is offline   Reply With Quote
