Old 10-08-2004, 07:53 AM   #7906
rc-zombies's Avatar
Originally posted by clinttredway
I will be running my pro 4 for the first time tomorrow (on carpet) and I was wondering if Thad's carpet setup is the best place to start?
I run on a med-hi bite track.
thanks
You may also want to check out Hara's DHI carpet setup..
Old 10-08-2004, 07:55 AM   #7907
clinttredway's Avatar
R/C Tech Charter Subscriber
Trader Rating: 3 (80%+)
Send a message via MSN to clinttredway
thanks! will do. Tomorrow is testing and getting used to the car... plus, I can't race anyway...
anyone using the new delrin outdrives? comments on them? are they worth it for stock racing?
Do or Do Not, There Is No Try
clinttredway is offline   Reply With Quote
Old 10-08-2004, 07:55 AM   #7908
rc-zombies's Avatar
Originally posted by Skill
I've just bought a titanium screw set for my Pro 4, do I need to lube the ones which screw into aluminium or can I threadlock them like steel screws?
Also, I've heard not to put them in the pivot blocks because they bend quite easily, is this true?
the grey grease will work fine... I've bent several screws already on the Pivot blocks... you can try them there and see what happens...
Old 10-08-2004, 07:57 AM   #7909
rc-zombies's Avatar
yes... makes for a very smooth diff.
Old 10-08-2004, 07:57 AM   #7910
Send a message via Yahoo to Doug Gaut
Clint, I have tried Thad's, Hara's and both of Kevin Kane's setups. Unless your track has nats style grip I would not suggest Thad's or Hara's. Go with Kevin Kane's setup. Now his first setup is more for a standard club race type bite which is what I have been racing on. The car carries tremendous amounts of corner speed and has great on-power steering. When I tried his second setup which he posted mid to late last month the rear of the car felt loose and I lost too much mid corner bite in the rear. I feel this setup would be better at a large turnout club race or at an established track that has great bite but not ludricous nats type bite. I hope this helps.
I also prefer the Parma Alfa body on carpet. It has great balance and transitions very fast.
Doug Gaut is offline   Reply With Quote
Old 10-08-2004, 07:58 AM   #7911
cool.. will need to get a set at some point..
thanks rc!
Old 10-08-2004, 07:59 AM   #7912
Thanks, I will look for Kevin's first setup as we have an established track but not insane grip. plus, I am looking for more of a base setup to work from...
Old 10-08-2004, 08:00 AM   #7913
Delrin diffs are SWEEEEEEEEEEEEEEEEET!!! They show no wear and I have been running them for weeks with a 19t motor.
Old 10-08-2004, 08:03 AM   #7914
awesome.. they are on my list of things to get... first I want to get used to the car...
how far back was Kevins setup posted...??
Old 10-08-2004, 08:06 AM   #7915
Clint, here is his first setup I spoke about.
Ok here is a setup to start with on Foam tires carpet.
Front
#3 pistons
45wt oil
HPI Pink Springs #6759 30.2 LBS Or Losi White 30 lbs
1 Hole in on the shock tower from all the way out
Inside hole on the lower arm
1 deg toe block
2mm shim under the rear front block
1.5mm shims under the front block.....Anti Dive for the front arms
6 deg castor blocks
1 hole for akerman plate
Forward hole on the steering knuckle
Inner hole for upper ball stud....1mm under ball stud
Black Sway bar....1.6mm with 2.7mm showing on the tips
1 degree camber
droop is ride height + 1.5mm
Rear
#3 Pistons
40wt oil
HPI Red Spring #6754 24.2 Lbs Or Losi Black 25 lbs
All the way out on the rear tower "stood up"
1 in on the lower arm
2 deg toe block
1 mm shim under rear rear block
1.5mm shims under front rear block....Anti-squat in the rear
Standard location for for arms as far as wheel base goes....this is a track dependent adjustment. Play with it and see how you like it
Rear hub stock spacing....big shim in the rear
Hub ball stud on the inside hole
Inner ball stud on the inside hole
.75mm under inner ball stud
Silver sway bar....1.4mm with nothing extra past the link
5mm rideheight all the way around......
1.5 deg camber
droop is ride height + 2.0mm
Tires TM Racing Plaid2's and Magenta's 2.30"dia
33/104 with Binary Stock motor with 100 ft Straight
Losi Alfa Body
Old 10-08-2004, 08:07 AM   #7916
thanks!
Old 10-08-2004, 08:12 AM   #7917
Clint, here is the second setup that is more for a higher bite situation. Kevin, I and some of the guys I race with are running the PRP HTS chassis which is a 3mm upper and lower chassis plate but the other guys that I race with that have the stock plates are just adding .5mm to the pivot blocks and to the inner camber link ball studs to obtain the same suspension geometry and doing that works real well. Hope this helps. If you have any questions just hollar. You might also go to the Team PRP thread for more setup tips.
Here is the setup that I was running so everyone with a HTS chassis can try it out and see how they like it.....
Front....
6 deg castor blocks
1 deg camber
inside hole for camber location
2mm under inside camber ball stud
1 hole in from all the way out on the shock tower
45wt oil
#3 piston
Hpi pink spring #6759 30.2 LBS
Outside hole on lower arm
Forward hole on steering knuckle or Losi hub Mod.
#1 akerman location
0 deg arm mount block with 1.5mm spacing under it
2mm spacing under front rear arm mount....gives the car kick down
1.5mm droop over ride height
5mm ride height
Black sway bar with 2.8mm showing
Rear
1.5deg camber
1mm under inside camber ball stud
inside hole on hub
Shocks in the outside hole on the tower
shocks in the middle hole on the lower arm
40wt oil
#3 piston
HPI red spring #6754 24.2LBS
Rear arm spaced with 3mm in front of the arm and 1mm behind the rear of the arm.
Rear hub spaced with thin shim in front of the hub and thicker shim at the rear of the hub(kit stock spacing)
2 deg arm mount
1mm shim under front arm mount...gives a little anti-squat
5mm ride height
2mm droop over ride height
Silver sway bar with 1.5mm showing
Body Losi Alfa
Motor KT Hobbies EPIC Roar Stock aka Kraig Tuned Limited Ed.
Geared 34/104
Tires TM racing Plaid2 fronts and Magenta Rears
Tire Size 2.26 dia
Edit....I was also using 2 center post one in the front and one in the rear with the middle spot open.
Old 10-08-2004, 08:14 AM   #7918
I have the stock chassis for now...
Old 10-08-2004, 08:16 AM   #7919
Nothing wrong with that. Just add .5mm to get the same settings as these setups call for and you will be fine. Glad you went PURPLE!!!
Maybe someday we will get down that way for a race. I think you guys are like 6 hours away.
Old 10-08-2004, 08:22 AM   #7920
It was just by chance that I was able to get the Pro4..
Some Oklahoma racers are supposed to coming down this week for some racing... too bad I can't race, but I will practice at least..
