Old 12-23-2003, 10:07 AM   #766
Erik Shauver's Avatar
Erik Shauver is offline   Reply With Quote
Old 12-23-2003, 10:12 AM   #767
rc-zombies's Avatar
yup...
done all those in the Past..no luck..
I've inquired with RcModel and HobbyMania in HK...still waiting for reply.
Have plenty of the GT7 diodes.. that's what I'm running now.
If I can't find a Twister..I'll stick with the black dyed GT7 and have the stealth look..
Old 12-23-2003, 10:12 AM   #768
Old 12-23-2003, 10:16 AM   #769
Old 12-23-2003, 10:19 AM   #770
Old 12-23-2003, 10:19 AM   #771
pucho's Avatar
Send a message via AIM to pucho
Originally posted by Erik Shauver
Hmm... I know Ultimate Hobbies carries the Hot Bodies line, might have to "educate" the staff that they can order the Twister from the Hot Bodies distributor. I know I have seen the Hara insert line sold somewhere locally (SoCal). I'll have to keep it in mind next trip to the hobby shop.
Erick:
As far as rear tow goes on the car will there be aditional pivot blocks with say 1*, 1.5*, and 2.0*? I know the car comes with the 2.5*, and 3.0.
pucho is offline   Reply With Quote
Old 12-23-2003, 10:19 AM   #772
rc-zombies's Avatar
May have to give them a call...
I've also ordered direct from HotBodies/RickyRcCar before...but don't want to pay Full retails price for it though... no rush to get one yet... since my car hasn't shown.
so... no comment on the Pro4 mini...hmmm...something must be in the works...
Old 12-23-2003, 10:22 AM   #773
rc-zombies's Avatar
Originally posted by pucho
Erick:
it's either new pivot blocks...or the same what Yokomo did...they came out with 0.50 & 1deg. rear hubs. probably cheaper to go with the graphite hubs than CNC aluminum parts.
Old 12-23-2003, 10:32 AM   #774
Old 12-23-2003, 10:33 AM   #775
rc-zombies's Avatar
pucho: The additional pivot blocks should be out very soon (now hopefully in Japan). As options: 0, 1.0, 1.5, and 2.0 will be added, in addition to the 2.5 and 3.0 degree blocks already available. On carpet with foams, we experimented a bit with parallel front blocks (a 0 degree block up front). If memory serves me, the part numbers should be in the 75151 to 75162 range (will check next time I'm at work). To adjust the block height, use the 75144 Pivot Block Spacer Set. It includes 0.5mm, 1.0mm, and 2.0mm spacers. They are stamped for easy installation.
Cool...aluminum blocks makes it easier to make adjustments.
Old 12-23-2003, 12:42 PM   #776
big_G's Avatar
R/C Tech Charter Subscriber
Default Pro 4
As in previous posts - the Pro 4 builds like a dream.
Tips
Have a good Allen Driver (2mm)
Use a 3mm tap on some of the graphite parts (gearbox etc) only do not tap all the way - let the screws tap some of their own thread.
Take time on shimming the gearboxes and outputs as per the instructions.
Enjoy
Here's a start of some pics - not finished totally yet!
big_G is offline   Reply With Quote
Old 12-23-2003, 12:43 PM   #777
big_G's Avatar
Default Pro 4 pic2
Pic 2
Old 12-23-2003, 12:44 PM   #778
big_G's Avatar
Default pic 3
Pic 3
Old 12-23-2003, 12:45 PM   #779
big_G's Avatar
Default pic 4
Pic 4
Old 12-23-2003, 12:45 PM   #780
big_G's Avatar
Default last one
Last one for now!
