Hpi Pro 4
#7726
I've never had a problem with mine running futaba 3pjs 133 receiver 75 mgh putnam monster two pieces of servo tape under receiver and esc.
#7727
I run a Pro4 w/ monster stock pro, Gt7, and Futaba 3PDF, I have had no glithec once so ever. I love the monster stock pro in my pro4.
#7728
different diff grease, 48p gears, gearbox shaved, different tooth one-way gears, and dinbal japanese bearings, overdrive, underdrive, diff gear break-in
#7729
thanks rc-zombies
#7730
back to the ntc3 bumper solution:
this is not a good idea of you race on an asphalt track that uses pipes or track-dome. The bumper will actually increase the impact of the crash, because it will wedge into or under the pipe. The stock bumper has a design that will make your car airborne in a wreck, which will atleast give you a chance to recover from the crash. Also, if you have anykind of track dome style pipe( the inside of the turn is a slope with a 30 degree angle) the extra width of the ntc3 bumper may lift the inside tire off the ground and you will lose traction. In a way this is logical theory, but you should notice a difference in your Pro 4's reaction to the wreck.
#7731
Originally posted by Hebiki
what radio system are using if you dont mind me asking? ive never glitched with my ko system. i was getting hit, but it was caused by the motor. not by other signals. so im thinking there's something in the trinity monster pro's thats causing it. but i wanna get more responses from people before i make my decision.
#7733
Originally posted by JohnB
Have you guys with glitch problems CA glued your battery slots on the chassis? Could be one cause, or at least at to a problem.
#7735
Originally posted by Nexus
Has anyone tried using the Hara DHI cup setup for carpet/rubber tires with any success?
I tried it last year and it was really good! Only thing I changed was the springs as the DHI setup was really soft because of the low traction conditions.... I used Losi purple front and Losi green rears.
It is a really good starting setup and I am sure you would like it!!
Cheers Mate
#7740
Originally posted by artwork
Might sound silly, but does anyone know the gf/mm to lb/in conversion? I want to list the HPI springs in lb/in like the rest of my springs. Or if someone has already done the conversion on the spring set already, that would be very helpful.
Thanks,
Thanks,
