Like Tree6Likes
Old 09-27-2004, 11:00 AM   #7651
I have a quick question...why does the Pro4 have adjustable (by replaing the pivot block) front toe blocks, as well as front toe tie rods?
If you screw the droop screws right out (anticlockwise), and then move the suspension up and down you can see the wheel change toe in,out because of the angle of the hingepin, by changing the ngle of the hingepin (inboard toe) you are allowing the "effective" toe in at each point if the suspension travel to be different. If you do not understand what I mean try it. Jonathan
jonny69 is offline   Reply With Quote
Old 09-27-2004, 11:00 AM   #7652
artwork's Avatar
Trader Rating: 62 (100%+)
Thanks for the responces, but...(not discounting what you are saying, I just cannot get my arms around why)
This seems too easy...am I missing something? It would seem like no advantage to having the inboard toe blocks, there has to be something else.
artwork is offline   Reply With Quote
Old 09-27-2004, 11:07 AM   #7653
Registered User
"The inboard toe is adjustable so you can control how aggressive the cars feels mid corner due to a bit of roll steering.The more inboard toe, the more aggressive the steering will feel. So for instance, 0 degree of inboard toe at the blocks will have less steering mid corner than the 2.5 block."
Aku-Man is offline   Reply With Quote
Old 09-27-2004, 11:13 AM   #7654
artwork's Avatar
OK I see...so this adjustment is a fine tune for front toe.
Thanks for all of the responses.
Art
Old 09-27-2004, 11:16 AM   #7655
Registered User
but don't mix inboard toe as wheel toe. They work independently.
Old 09-27-2004, 12:05 PM   #7656
gijoe64's Avatar
Trader Rating: 30 (100%+)
Does anyone have a carpet setup for rubber tires. I will be racing with rubber tires this season. Thanx
gijoe64 is offline   Reply With Quote
Old 09-27-2004, 12:07 PM   #7657
rc-zombies's Avatar
Try Hara's set-up from the DHI race. can be found on the HPI website.
Old 09-27-2004, 02:58 PM   #7658
lazyboy's Avatar
Send a message via AIM to lazyboy
can some one tell me the part number for a simkit, that is availble for the pro4? i know there is one out there, i just can seem to place my fingure on it...and if u have the pivot block and toe block parts numbers that would be greatly apprecatied also.
thanks lazyboy
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 09-27-2004, 03:14 PM   #7659
artwork's Avatar
thanks lazyboy
Check out this link...all of the stuff you are looking for is on here.
http://www.allspeedhobbies.com/catal...ath=35_130_131
Sanwa | R1 Wurks | Avid | 2mm Designs
Old 09-27-2004, 05:25 PM   #7660
lazyboy's Avatar
thanks bro
Random Guy
FT B4
Trackside hobbies
Old 09-27-2004, 07:44 PM   #7661
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Anyone know a place that has 1 and 2 degree blocks in stock?
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 09-27-2004, 08:05 PM   #7662
Registered User
Tower Hobbies
1 degree block
2 degree block
Old 09-27-2004, 08:24 PM   #7663
USVTA Member #211
Old 09-28-2004, 04:05 AM   #7664
Default KAI Chassis
Hi,
Has anyone got any of these at this link. Sorry its in another language (Japanese?). What do you think.
http://www2u.biglobe.ne.jp/~kmodels/
Cheers,
Mossie
Mossie is offline   Reply With Quote
Old 09-28-2004, 06:06 AM   #7665
gijoe64's Avatar
Default Re: KAI Chassis
Originally posted by Mossie
Hi,
Cheers,
Mossie
it is impossible to get KAI chassis, they will not sell to the US. Good luck
