Like Tree86Likes
Hpi Pro 4
Old 09-25-2004, 03:38 PM
  #7606
Trader Rating: 42 (100%+)
Originally posted by VenomWorldOrder
ok done just place the details i included on the email on the pdf and on the xcel sheet as i didn't do it.
can you make one in inches instead of millimeters for tires size?
Nexus is offline
Old 09-25-2004, 05:55 PM
  #7607
Registered User
Default derlin outdrives sucks?
I put brand new derlin outdrives and v1.1 gear set on front and rear for today's race. Look what happen to my derlin outdrive melted with diff ring. $50 bucks wasted for just half of first race.
What can cause this? My gears are still good. no wear.
Aku-Man is offline
Old 09-25-2004, 06:05 PM
  #7608
coastaltony's Avatar
Damn, call HPI ASAP If it's a problem, they will fix it You want to see problems, look at the Weather Channel, I live in West Palm Beach, FL
coastaltony is offline
Old 09-25-2004, 06:11 PM
  #7609
Registered User
I'll try.
Aku-Man is offline
Old 09-25-2004, 06:19 PM
  #7610
Trader Rating: 17 (100%+)
Can you guys enjoy a good weekend WITHOUT a hurricane? Man..I hope you guys are OK, please lock the PRO 4 in your trunk and drive NORTH.....
Solara is offline
Old 09-25-2004, 09:17 PM
  #7611
racer's Avatar
Default Re: derlin outdrives sucks?
did you put the spacer that goes around the bearing?
seems like you used a larger bearing.
looks as if the diff rings were not seated correctly and started to spin inside the ball diff.
racer is offline
Old 09-26-2004, 12:09 AM
  #7612
That’s what happens when you don’t tighten the diff correctly. If the diff is slipping this causes heat which melts the hubs. Another guy that works for HPI was running his diff loose. I told him to tighten them; he didn’t and guess what happened.
Where did you buy a $50 set of $20 delrin out drives?
Thad Garner is offline
Old 09-26-2004, 12:18 AM
  #7613
Registered User
I see....
I bought 2 sets from UK + shipping like 1 or 2 months ago.
Aku-Man is offline
Old 09-26-2004, 12:21 AM
  #7614
Registered User
I tight the diff good, but the diff come out loose after few laps with 10Tx1.
Aku-Man is offline
Old 09-26-2004, 02:06 AM
  #7615
Trader Rating: 55 (100%+)
i had the same problem, diffs would back off within a few laps..
carefully gluing the nut into the little plastic 'T shaped' housing has totally fixed the problem for me.
tones is offline
Old 09-26-2004, 02:50 AM
  #7616
VenomWorldOrder's Avatar
wow! thanks for warning all of us before making our derlin diffs.
can i just confirm the following, for the AE diff mod all i ned is:
-THE LONG SCREW,
-NUT,
-PLASTIC NUT HOLDER
-SPRING.
is this correct? also does the nitro diff parts work?
VenomWorldOrder is offline
Old 09-26-2004, 03:23 AM
  #7617
Trinity2's Avatar
Unhappy
What`s up Thad.
I`m a little worried about with my Pro4.
I had training session last night with newest 1.1 gear set up front and after 3th run there was that same sound when i drove earlier those old gears.
So, after that thing i opened front and chech what made that sound.
Guess what, there was a terrible mess of gears.
Any suggestion??
Trinity2 is offline
Old 09-26-2004, 03:31 AM
  #7618
Trinity2's Avatar
-THE LONG SCREW,
-NUT,
-PLASTIC NUT HOLDER
-SPRING.
There was a good picture with those AE parts earlier.
That rear diff problem was my pain in the ass too.
So, i made that AE diff mod with original outdrives and now it works fine
Now i still have to solve that front gear set problem
Trinity2 is offline
Old 09-26-2004, 05:03 AM
  #7619
all you need to do is compress the spring a couple of times with pliers ,you won't have a problem .
sportracer is offline
Old 09-26-2004, 05:16 AM
  #7620
black-knight's Avatar
Originally posted by Trinity2
What`s up Thad.
Any suggestion??
yes... stop hitting things lol
black-knight is offline
