Old 09-20-2004, 08:09 PM   #7561
Euge's Avatar
Originally posted by Rookie Solara
When Euge keep saying that I can beat him at indoor carpet.....now I know he is trying to WIN some money from me....way to go Euge...
nah, I got lucky. I'm sure if your car was setup right for carpet foam, you would have done well also. but........just to make it interesting.........how much $$ we talking?
Euge is offline   Reply With Quote
Old 09-21-2004, 12:53 AM   #7562
SpeedTech's Avatar
Hi Guys,
Just a quick post, we should have some square products in stock tomorrow for the Pro4, website should be updated by tomorrow night
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 09-21-2004, 07:29 PM   #7563
TOEBSTER2's Avatar
Just picked up a pro 4. Anyone got a good starting point for a rubber set up besides the kit one. The kit one is probably a mod setup for outdoor.
Crookid Creations
TOEBSTER2 is offline   Reply With Quote
Old 09-21-2004, 07:42 PM   #7564
Entropy's Avatar
The kit setup is ideal for stock too. You prob just need to set the stabilizers and camber link height to tune in more or less steering to your liking.
Entropy is offline   Reply With Quote
Old 09-21-2004, 07:43 PM   #7565
farls3589's Avatar
Send a message via AIM to farls3589
The kit one.LOL
farls3589 is offline   Reply With Quote
Old 09-21-2004, 07:48 PM   #7566
TOEBSTER2's Avatar
ssshhhhhhhhhuuuuuuuuuuutttt up Farley, go to bed!
Crookid Creations
Old 09-22-2004, 01:31 AM   #7567
Spud_J's Avatar
Default Pro4 Wheel Rates
Hi Guys,
Thought some of you may find this interesting / useful. Its a very simple wheel rate table (wheel movement vs spring movement)using some of the commonly used springs. It's something I do for every car I get - just helps me to uderstand the actual wheel rates and you can then work out % front roll stiffness etc. It's not 100% accurate as it's not modeled but just measured out using a vernier......not too far out though!!!
Here is the table for the front
I can pm the excel version to anyone who would like it to add in different springs etc.
Spud_J is offline   Reply With Quote
Old 09-22-2004, 01:32 AM   #7568
Spud_J's Avatar
......and the table for the rear
Old 09-22-2004, 03:18 AM   #7569
Default Wheel Rates
What do the wheel rate numbers actually mean? What does a higher wheel rate when compared to a lower wheel rate indicate?
Is there a web site that I can read about wheel rates?
Cheers,
Mossie
Mossie is offline   Reply With Quote
Old 09-22-2004, 04:12 AM   #7570
Spud_J's Avatar
The wheel rate is the actual "spring" rate at the wheel. The wishbone acts as a lever on the damper & spring and this leverage changes depending on which tower and wishbone holes you use. So, a higher wheelrate is stiffer.
You can see from the table that on the front, a 17.5lb Xray white spring on hole 2 on the tower and 1 on the wishbone gives very nearly the same wheel rate as a 22.5lb Xray dark blue spring on hole 1 on the tower and hole 2 on the wishbone, this is because ther is more leverage acting upon it in this configuration.
Now, there are many other factors like progressive rate changes depending on the damper angle, dynamic loads etc but this table is just a very simple reference so you can compare one spring and location to another and relate it to the wheel rate.
I dont know of any specific websites mossie but I'm sure a search on google will take you to plenty. Or if you really want to get seriously technical buy yourself a copy of the book "Race Car Vehicle Dynamics" by Milliken & Milliken........be prepared to be baffled though!!!!!
Old 09-22-2004, 04:24 AM   #7571
JohnB's Avatar
R/C Tech Charter Subscriber
VERY NICE Spud!! Well done. We appreciate it.
JohnB is offline   Reply With Quote
Old 09-22-2004, 04:30 AM   #7572
Thanks spud. I understand now!
Cheers,
Mossie
Old 09-22-2004, 05:06 AM   #7573
Spud_J's Avatar
Hey no probs, glad you like it. Just remember that this does not take into account roll bars etc, just purely the main spring. I use these figures in my setup sheet which then tells me the % front roll stifness.
You calculate this by:
Front wheel rate / (front + Rear wheel rate)*(100)
I.E, say the springs and positions you are using give the following wheel rates...
Front wheel rate = 180g/mm
Rear wheel rate = 165g/mm
So
180 / (180+150) = 0.545 * 100 = 54.5%
That tells you that the front of the car is 54.5% of the total cars roll stiffness - simply the front is slightly stiffer than the rear.
In an absolutely ideal world, with good weight distribution, sensible roll centers, CofG etc (*can opening, worms everywhere!!!!*) around 50% front should equal a near neutral car, less than 50% front should equal lots of front end and greater than 50% front should equal gradual push or more rear grip.
I like a very aggressive car, so, depending on the tyres I usually start around 46 - 48% front and fine tune with damper oil, roll bars, ride hight etc.....
Old 09-22-2004, 05:11 AM   #7574
How do you calculate the total ammount of wheel rate?
sturla is offline   Reply With Quote
Old 09-22-2004, 05:47 AM   #7575
Spud_J's Avatar
Sturla,
Im not 100% sure what you mean by total wheel rate but if you run a HPI Pro4 then they are already calculated in my table!
If not, a simple way is to take the spring off and put the damper back in place. Next measure with a vernier the length of the damper rod - say between the ballcup and the body. next move the upright up exactly 5mm, measured at the centerline of where the wheel would sit (hudy droop blocks work well) and measure the damper rod again.
Say if your first measurement was 8mm and your second measurement was 5mm that then means that for your wheel to move 5mm the spring has only moved 3mm. Then divide 5 by 3 which = 1.66
This figure of 1.66 is the motion ratio of wheel to spring.
Them divide your sring rate - say 30lb by 1.66 that then gives you a wheel rate of 18.07lb/in or 322.69g/mm if you prefer metric.
You can repeat this with all the variations of damper position and come up with a table for your specific car
Hope that helps
