Like Tree5Likes
Old 09-19-2004, 09:10 PM   #7546
Send a message via Yahoo to Doug Gaut
Wes, go to the Team PRP thread. Its on there but keep in mind its for a 3mm chassis plate so you will need to adjust your roll center blocks up .5mm all the way around and also on the inner camber link ball stud as well to keep the same geometry.
The setup works great. As well as the 3mm chassis plates on carpet!!! Hope you guys can make it up to Hutch soon. Its Pro4 country up here. We are up to 8 now.
Doug Gaut is offline   Reply With Quote
Old 09-19-2004, 09:12 PM   #7547
Thanks Euge. I was not sure how to post it here.
Old 09-19-2004, 09:17 PM   #7548
Euge's Avatar
No problem, Doug. There are more and more Pro4 drivers at our track every week. I'm still pretty new to this car, but it's the best car I've had yet. A couple of rubber tire guys also picked up the car and they told me how happy they are with it as well.
Euge is offline   Reply With Quote
Old 09-19-2004, 09:18 PM   #7549
azenis's Avatar
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 09-19-2004, 09:33 PM   #7550
Azenis, with a 2.5mm chassis versus a 3mm chassis, if you add .5mm to the pivot support to get the same roll center geometry the gearbox is still .5mm lower on the 2.5mm chassis versus the 3mm chassis so if you are trying to duplicate a setup for a 3mm chassis you will need to add .5mm to the inner ball stud.
Old 09-19-2004, 09:41 PM   #7551
azenis's Avatar
so it is my bad i for some reason i thought the box screwedd to the pivot blocks but i was thinking of my other car lol
Nige
Old 09-19-2004, 10:51 PM   #7552
Trader Rating: 37 (100%+)
Has anyone had problems with the standard diff screw head breaking off?
azenis....i had this happen to my front diff screw head the first weekend i ran the car. i don't remember if i took a hit but in the end i just switched out to the AE screw and everything is fine now.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 09-20-2004, 07:58 AM   #7553
Solara's Avatar
Trader Rating: 16 (100%+)
Great race on Trackside yesterday, and I personally saw those ROBK/KevinK setup PRO 4 at the track..........and that is INDEED very close to perfect setup for tight carpet track..........and EUGE was suddenly running against those A-main Team Driver with that setup, and he was FLYING (he won't even believed that RobK's/Kevin's setup work so great untill he saw it himself...)
I think I will have to dished out the extra $400 to upgrade my outdoor pro 4 to the indoor PRP pro 4 or should I said Robk/KevinK 2004 edition PRO4...........
P.S. Who told me running electric is cheaper then Nitro........?
Old 09-20-2004, 08:24 AM   #7554
Euge's Avatar
well, the electricity is free.
thanks rookie. the car was really good with that setup. definitely the best car I've ever driven.
Old 09-20-2004, 08:41 AM   #7555
Solara's Avatar
Seeing you drive (like a Team Driver) made me feel bad........I think I better stick with NITRO afterall....LOL
Thanks for the Arm Cutting 101 (also thanks RobK to do the exact same thing..)........and cutting the arm for free (instead of $5 a piece that I was stupid enough to let something charged me like that...)
I will try to get better and see you all at RSJ soon....good luck on the next summer sizzler next week, go team Pro 4.
Old 09-20-2004, 12:25 PM   #7556
Solara's Avatar
Robk and Kevin............I am reading your previoiusly setup and trying to put them on the HPI setup sheet, there are several items are missing...
(1) Front camber
(2) Rear camber
(3) how many turns out for the front diff
(4) how many turns out for the rear diff
(5) Droop? Front and rear?
(6) Any spacer below the front outside camber upper ball stud?
(7) Any spacer below the rear outside camber upper ball stud?
You can post the latest (yesteday) trackside setting....for the updated setup..
BTW.....how's the RSJ gang did yesterday? I took off early cause wife can't stand me racing with the front 1-way instead of the front diff........LOL
Old 09-20-2004, 12:34 PM   #7557
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Rookie.....Here is the rest of the info..
1.....front camber 1deg neg.
2.....rear camber 1.5 deg neg
3.....front diff is tighter then the rear....not sure how any turns out
4.....rear diff is looser then the front not sure how many turns out
5......front droop 1.5mm over ride height rear droop 2mm over ride height
6 & 7.....None
Well Euge ended up winning the B-main Rob king was 3rd or 4th in the B-main. Brian Jucha ended up winning the A-main and I was second. It was a good day lots of pro-4's at the track now.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 09-20-2004, 01:19 PM   #7558
Way to go Kevin!!!
Old 09-20-2004, 01:31 PM   #7559
JohnB's Avatar
R/C Tech Charter Subscriber
I finally got my car pretty good this weekend. I previously was loose going in/off power, but good every place else. Going to Dbl Purple front tires helped as well as 60 wt. oil in front and no sway bar in rear. This is on a 100'x36' carpet track. Here's what I ended up with.
Front
#5 pistons - 60wt oil – Assoc. Purple Springs
Mount: top 2nd hole in from outside, inside on a-arm
0 deg toe block w/ 2mm shim’s under both (zero degree anti squat)
2 deg castor blocks
Camber link: inside mounted on inside on w/ 0* camber and 1mm under ball stud.
Stock Sway bar with 3mm showing on the tips
Ride height: 4mm
Rear
#3 Pistons - 40wt oil – Assoc. Copper springs
Mount: top 3rd hold in from outside, middle on a-arm.
1.5 deg toe block w/ .75mm under both blocks (zero degree anti squat)
Inner camber link on outside hole, outside hole on hub also. 1.5 mm under
Inner camber link ball stud. –1* camber and short wheelbase
No sway bar.
Ride height: 4mm
Droop: About 1mm over ride height.
Steering: Forward hole on rack and rear hole on spindle.
Diffs: rear just tight enough not to slip while holding one tire and spur gear. Front diff tighten all the way then 1/8 turn out.
Purple rear tires, Dbl purple front.
Reedy PT 10x1 geared 98/25 w/ 42mm tires. Motor ran at 135* after 5 min.
Tekin G-10 Pro Speed Control w/ Thrlt at 7 and LIM2 at 90 (TONS of rip out of the corners!!!!).
Over all I'm very pleased. A small problem with traciton rolling in a couple corners. That is why I ended with such a small amount of droop (trying for a quick fix at the track).
take care
john
JohnB is offline   Reply With Quote
Old 09-20-2004, 06:54 PM   #7560
Solara's Avatar
6 & 7.....None
When Euge keep saying that I can beat him at indoor carpet.....now I know he is trying to WIN some money from me....way to go Euge...
And of course, good to see you and Brain (the PRO 4s) took over the 1 and 2.........not to mention, I heard Brian just finished building his brand new pro 4 about 1/2 hour before the qualifier...and that PRO 4 was never hit the track before, talk about the PRO driver...
Thanks Kevin...I will completed that setup sheet and save it for the RSJ, AJ and the Trackside setup....
For you and Euge....do you guys remember the sound that coming out from my car I was turning and acceleration...and when we were all thinking my front rim was rubbing against the shock plate....guess no more, those noise are from the 1-way, I was still using the old V1.0 diff (too lazy to do the upgrade) and all 4 screws were lose at the beginning of my last qualifier...then the diff gear fell off, and stripped about 1/2 of the gears, the entire 5 minutes, I was driving RWD........no wonder my car was kinda lose at the rear at no reason and sometimes it has traction, sometime it doesn't....
Man, front diff is the way to go..................no more 1-way.
