Like Tree5Likes
Old 09-17-2004, 05:52 PM   #7531
blast's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to blast
changing the oil is alot faster than changing your piston if you have other wt. oils. If go with a smaller hole just don't use heavy wt. oil.
Patrick Connors
FTM Grip
You're not fast if you don't have the grip
A Master key can open any lock, but a lock that can be open by any key is an sloppy lock.
blast is offline   Reply With Quote
Old 09-18-2004, 04:33 PM   #7532
robk's Avatar
Trader Rating: 22 (100%+)
I guess i must have been even more tired than i thought when i posted. Yeah, 5wt is a lot closer to what the difference is. That being said, a lot of the setup sheets look like #3 pistons most times (1.1mm??)
I don't know what this really means. Most of the time, the logic seems to be to use the piston to keep you in a usable range of oils. Pack doesn't seem to come into it too much. This could be all wrong, or just a result of laziness. It just seems like sometimes 50 wt and a #2 is the same as 45 wt and a #3 on the track.
i hope somebody smarter than me comes on here and enlightens us.
Old 09-18-2004, 06:08 PM   #7533
pucho's Avatar
Send a message via AIM to pucho
In reality pack is more of an effect on off-road vehicles were they are jumping and landing, but pack would affect the way the shock would react on initial compression.
BTW: TO change the pistons I use a pick and pop the eclip off and pull the shaft quickly down (with out pulling the shaft out of the body) when the piston becomes dislodged from the shaft I pull it off, replace the new piston and pop the eclip back on with the pick
pucho is offline   Reply With Quote
Old 09-18-2004, 11:29 PM   #7534
gijoe64's Avatar
Trader Rating: 30 (100%+)
I just went with the Pro4, I would like to know what is the most important hop-up for this car? I will be racing on carpet this fall with rubber tires. I know alot of guys like to dressup their cars but I am looking for perfromance mod.
gijoe64 is offline   Reply With Quote
Old 09-18-2004, 11:47 PM   #7535
Skill's Avatar
The Pro 4 is a very high spec as standard, and doesn't really need anything to make it go better.
However, you'll be looking at things like ceramic bearings, delrin pivot balls, choice of springs, carbon fibre upper link supports. If your track is quite unforgiving then possibly alloy C-hubs and steering knuckles won't go a miss (for durability purposes). Also, I've heard the carbon fibre shaft is good, I've just bought one but have yet to try it.
Skill is offline   Reply With Quote
Old 09-19-2004, 03:06 AM   #7536
pro4racer's Avatar
hi every1 i got my second pro4 at the weekend and when i got to the part when installing the pivot blocks i realised there were no spacers.
i need these ones as my other pro4 has them and that handles great but without these spacer it handles shite.
i dont really want to buy a whole new pack for 12 quid as only 4 of them will be used and the others wont so there is no point
can any1 help as what to do in terms of getting just them four or contact hpi and tell the
thanks
pro4racer is offline   Reply With Quote
Old 09-19-2004, 08:32 AM   #7537
Skill's Avatar
You'll just have to ring/email HPI and tell them, they're usually quite good so they should send some out to you. Also, if your kits don't have the version 1.1 gears you could ask them about those too....
Old 09-19-2004, 12:12 PM   #7538
gijoe64's Avatar
What about springs, I ordered the Hpi springs
for the Pro-4. I would like to use Tamiya springs. What are the bestfor the Pro-4?
Old 09-19-2004, 01:02 PM   #7539
pucho thanks for the tip I'll give that a try
sportracer is offline   Reply With Quote
Old 09-19-2004, 04:27 PM   #7540
Default Ball STuds
Hi what ball studs does everyone use or do you use the stock ones?
Cheers,
Mossie
Mossie is offline   Reply With Quote
Old 09-19-2004, 05:14 PM   #7541
Spud_J's Avatar
Mossie,
The Schumacher "Ball Grippa" cups are really good on the standard HPI balls - strong and very little play. The RPM ones are good also but personally never tried them
Spud_J is offline   Reply With Quote
Old 09-19-2004, 08:52 PM   #7542
Euge's Avatar
I also threw on some Schumacher Ball Grippas and they really are very nice ball cups.
Anyone running indoor carpet should consider the PRP chassis. I ran it for the first time today and really liked it compared to the stock chassis. My car seemed more consistent. I ran Kevin Kane's setup and it was really good.
Euge is offline   Reply With Quote
Old 09-19-2004, 08:56 PM   #7543
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
anyone have his carpet setup handy? or know what page its on?
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 09-19-2004, 09:07 PM   #7544
azenis's Avatar
Default diff screws
Has anyone had problems with the standard diff screw head breaking off?
My rear diff did this a few weeks ago and I fixed with the associated diff mod. I got a diff for in the front and it was on its 3rd pack (one pack practice and the 2nd race) and the head sheared off this one as well!! It wasnt over tightned or anything!
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 09-19-2004, 09:10 PM   #7545
Euge's Avatar
it was posted by robk, and I think a few questions were answered in subsequent posts. Kevin Kane is usually on this thread or the PRP one. I'm sure Kevin would be more than happy to answer any questions. Sorry for volunteering you, Kev.
Here's a link to robk's post
Kevin Kane's Indoor carpet setup
