Like Tree5Likes
Old 09-14-2004, 09:55 AM   #7486
Solara's Avatar
Trader Rating: 16 (100%+)
Originally posted by brushless
I know it's a lot. It shouldn't be like that. I want to fix it but I don't know what else to check.
Check your servo setting...make sure your RIGHT TURN is set the same amount of turn % just like your left....
Old 09-14-2004, 09:56 AM   #7487
brushless's Avatar
That's the other thing I checked too. I made the EPA for left and right steering exactly the same with no change.
brushless is offline   Reply With Quote
Old 09-14-2004, 11:37 AM   #7488
Skill's Avatar
Make sure there is no binding anywhere in the steering and that if you are running sway bars that they are in the centre of the gearbox, I've heard that the slightest bit they are out can make the car handle unevenly. Also, try swapping your tyres round side to side...
Skill is offline   Reply With Quote
Old 09-14-2004, 12:15 PM   #7489
Solara's Avatar
Well, that is 1 thing, but I also use my eye to actually see it and make sure the servo does go all the way to left or right....most of the time, I take the 2nd methrod over the Radio % number...cause there are always something in between the servo, radio and the steering itself will make the differnet.
Old 09-14-2004, 12:32 PM   #7490
brushless's Avatar
I used the radio settings and eyed it too. I had to turn the left down to about 75% before it matched the right at 100%.
Old 09-14-2004, 01:16 PM   #7491
Send a message via Yahoo to Doug Gaut
I would double check your swaybars as Skill says. They cannot have ANY play up and down in the groove. I had one side that the set screw caught the bar and one that didnt and had somewhat the same handling issue. I took the setscrews back out and installed them at an angle towards the gearbox more which then they tightened down on the bars correctly. You only want an extremely small amount of play so that the bars can move side to side but not up and down otherwise they will not work properly. I even added dubro stops on either side of the gearbox to stop any side to side play as well.
Doug Gaut is offline   Reply With Quote
Old 09-14-2004, 01:23 PM   #7492
brushless's Avatar
I don't use sway bars.
Old 09-14-2004, 03:31 PM   #7493
azenis's Avatar
Originally posted by azenis
Well I built the diff last night, would really love some tips for running it in though...
thanks
Anyone??
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 09-14-2004, 03:38 PM   #7494
rc-zombies's Avatar
thanks
Anyone??
As far as set-up... I use the same set-up if using a front one-way...
you'll have to slightly change your driving style. you won't be able to corner as fast..but will be able to break much later before the turn.
Old 09-14-2004, 03:41 PM   #7495
azenis's Avatar
Ahh yes but isnt there a proceedure for breaking the diff in?
Nige
Old 09-14-2004, 03:43 PM   #7496
rc-zombies's Avatar
I just run a couple of packs on the car and re-adjust the diff if needed.
Old 09-14-2004, 03:43 PM   #7497
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
There is no real procedure. I usually just run the car up and down the street to "break it in". Then make adjustments afterwards.
DOMOisCOOL is offline   Reply With Quote
Old 09-14-2004, 04:05 PM   #7498
azenis's Avatar
Thanks guys
One other thing, anyone with a GT7 in thier Pro4 can you send me a pic of your setup or let me know how you have mounted the Capactitor ? The wires it is on is too short and too long to put it anywhere useful, and the wired in shottky diode is as much a pain as it is a good thing! Just trying to tidy my install of it all while the car is pulled down.
Nige
Old 09-14-2004, 04:24 PM   #7499
DOMOisCOOL's Avatar
Azenis, I will take a pic of my setup with the GT7 for you in an hour.
Old 09-14-2004, 04:26 PM   #7500
azenis's Avatar
Thanks DOMIisCOOL
I think I may need to shorten the motor wires somewhat too, its a bit of a mess
Nige
