Old 09-09-2004, 08:21 AM   #7456
rc-zombies's Avatar
Originally posted by rudster
Hi rc-zombies
Why do you say the aluminum input shafts are better than the TI ones.
See what racer said.. Plus aluminum is lighter than Ti.
Old 09-09-2004, 08:22 AM   #7457
rc-zombies's Avatar
Originally posted by DOMOisCOOL
Shoe-Goo will be the best. It holds excellent, yet it could be easily taken off (flat sided screwdriver).
I shoo goo mine as well.
Old 09-09-2004, 09:03 AM   #7458
StewartFan20's Avatar
Default Ball Cups
Does anyone have issues with excess play in the ball cups? It seems as though there is a lot of slop in the stearing linkages of my Pro4.
I have seen posts on this thread where people have used other manufacurers balls and I was wondering if this was done to reduce or eliminate the slop in the ball cups.
Devil Dog Racing | HobbyTown USA (Kansas City,North) | Fastlane Raceway | Matrix Tires
Someday, I hope to be the man my dog thinks I am.
StewartFan20 is offline   Reply With Quote
Old 09-09-2004, 09:11 AM   #7459
cartmen34's Avatar
Default Re: Ball Cups
Yes. Buy the Schumacher ball cups. I'm not sure on the part number, but its somewhere in this post.
They eliminate the slop that the stock ballcups give you.
cartmen34 is offline   Reply With Quote
Old 09-09-2004, 09:16 AM   #7460
cartmen34's Avatar
Does anyone run a mini fan on their Pro 4? I just bought one but don't know if I should hook it up to the receiver or the motor. If I connect to receiver, i'll have to do the painstaking task of crimping the metal contacts into the wire.
Also, do I want the plastic grille thing facing the motor or facing the electronics? (direction of air)
I have a mini fan on mine. I used servo tape, but will shoegoo it as soon as I notice it getting loose. The fan sits between my motor and ESC. Its sitting so that the air generated is blown straight into the top of the can.
I hooked mine into the receiver. If you plug it straight into the battery then you have the fan running as soon as you plug in the battery to the ESC.
I just bought a hitec receiver plug lead and soldered the plug lead to the fan leads. Mucho easier then crimping.
Old 09-09-2004, 09:29 AM   #7461
cartmen34's Avatar
Default Re: Re: Ball Cups
Found it. Knew it was in here somewhere.
This post has all the info you need to get the right ball cups:
http://www.rctech.net/forum/showthre...ups#post963231
Old 09-09-2004, 09:57 AM   #7462
Solara's Avatar
Trader Rating: 16 (100%+)
Domo..........I don't know what mini fan that you use....but I used the AE one with the blue heatsink that mounted onto the motor...it is not rocket science, and I don't know much about elect TC racing...but since I used it, I can gear up higher, and 5 minutes never be a problem to me........
And since I got that fan, ppl around me got them as well.........not that expensive...$25 or so I think, it plug into the battery port or your 3rd channel port in your receiver...when you turn on your radio/receiver, it is ON...
Old 09-09-2004, 11:37 AM   #7463
Default Re: Re: Re: Ball Cups
Just orderd two sets of 8. Thanks a bunch....
Old 09-09-2004, 11:50 AM   #7464
rc-zombies's Avatar
Another nice fan heatsink is this one:
too bad it only comes in blue...
Old 09-10-2004, 01:20 AM   #7465
Speed Demon's Avatar
Originally posted by racer
as you can see by the picture. the spur gear attached to the input shaft as one peice will have little to no play. compared to the titanium shafts you may have to do alittle more shimming.
well, my case is... I use this one for the rear, but the front is the titanium shaft.... It really works and the spurs does not woble compared to the stock ones....
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 09-10-2004, 05:57 AM   #7466
pucho's Avatar
Send a message via AIM to pucho
I like that but it's the price that scares me away. Ill keep my stock components untill there is a problem.
pucho is offline   Reply With Quote
Old 09-10-2004, 10:10 AM   #7467
pucho's Avatar
WELL Im off to the races.
Old 09-10-2004, 10:20 AM   #7468
rc-zombies's Avatar
stay dry...
Old 09-12-2004, 10:32 AM   #7469
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
silly question... do the Pro 4's rear hubs have any toe built in them? the only block i have for my car at the moment is the 3.0. seemed like a little much on carpet last night, and just not sure if i want to buy alllllll the blocks they make!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 09-12-2004, 10:53 AM   #7470
X-Garage's Avatar
May I see a picture of your PRO4? Here is mine.
X-Garage is offline   Reply With Quote
