Like Tree6Likes
Old 09-08-2004, 06:27 AM   #7426
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
Originally posted by Doug Gaut
Wes, Pro4 . I am surprised!! Thats cool!!! Welcome to the world of PURPLE. I would look at the setup from the DHI Cup in the back of the manual that Hara ran. That will give you a great starting point. BTW, where are you going to be running carpet at? I didnt think Tulsa had any carpet tracks any more or are you guys going to Springfield? If you decide to try foams hollar at me. You guys should try to come up in a few weeks to Hutch and race on the carpet with us.
you know me, i just enjoy people trying to figure out which car i am running!!!
i got this car a while back, just now decided to check it out. just built a diff for the front last night... figure that might be better on the rug. i think that they run rubber at springfield, tho.. im sure we will make a trip up to sunny KS before long! try to get an early start for the Novak race...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 09-08-2004, 07:02 AM   #7427
Rob Mincey's Avatar
FYI - Stock motors run rubber, 19T and up run foams.
Rob
Rob Mincey is offline   Reply With Quote
Old 09-08-2004, 07:40 AM   #7428
VenomWorldOrder's Avatar
Originally posted by azenis
Depends if you are adjusting the wheelbase by moving the hubs forward or back within the a-arm, or moving the entre rear (or front) gearbox assembly back and forward.
If you are only changing the spacers in the a-arm, you are moving the wheels forward or backwards relative to the main weight in the car (the gearbox and suspension) and this changes the balance of where the weight is. If you move the entire assembly, which I believe you are doing with the PRP chassis, this is a true wheelbase adjustment and longer will be more stable, shorter more steering, as the balance of weight over the wheels remains constant.
i'm moving the shims that are at the front and rear of the a arm.
VenomWorldOrder is offline   Reply With Quote
Old 09-08-2004, 07:57 AM   #7429
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
We have been having a good sized foam tire stock sedan class at hutch. I think there are some that are breaking off into the mod and 19t classes. Would be cool to have you guys up!
Jeff
Jeff Werner is offline   Reply With Quote
Old 09-08-2004, 08:37 AM   #7430
Send a message via Yahoo to Doug Gaut
Trust in what ROBK says guys. He knows what he is talking about.
Losirob/Tamiyadriver we race on Saturdays. Doors open at noon, racing at 6pm. Here is a link to that tracks website. The road rail is on order but not here yet. Wish I could swing the Novak. Hope you guys can make it up soon!!
http://www.hphobbies.com/
Doug Gaut is offline   Reply With Quote
Old 09-08-2004, 02:42 PM   #7431
Trader Rating: 37 (100%+)
just thought i might ask here since there might be some professional graphics designers on this thread who own pro4s.
anyone know what font HPI uses for there "hpi racing" logo?
thanks.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 09-08-2004, 02:45 PM   #7432
brushless's Avatar
THEIR
brushless is offline   Reply With Quote
Old 09-08-2004, 03:16 PM   #7433
Ronald B's Avatar
Default re: tamiyadriver
this set up i use for 19 turn stock with rubber tyres
Ronald B is offline   Reply With Quote
Old 09-08-2004, 03:24 PM   #7434
wagonman72's Avatar
They're.
wagonman72 is offline   Reply With Quote
Old 09-08-2004, 04:30 PM   #7435
coastaltony's Avatar
There's one in every crowd!
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 09-08-2004, 04:38 PM   #7436
rc-zombies's Avatar
thanks.
try: From MS Word:
swis721 BlkCn BT
or
inpact
Old 09-08-2004, 04:54 PM   #7437
Oasis's Avatar
Trader Rating: 36 (100%+)
Just bought some ceramic bearings and some Lt. Wt. input shafts..for the stock Pro4(not that the car is stock,it's just the car I use For stock racing)..It should really be fast now..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 09-08-2004, 05:11 PM   #7438
rc-zombies's Avatar
hope you got the Square aluminum input shafts/spur gear mount version instead of the TI. much quicker acceleration.
Old 09-08-2004, 05:34 PM   #7439
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default delrin diff questions.
It appears that delrin diff are same weight as stock diffs...at 18 a pair what is the advantage/purpose?
Jamie
J.Gonzalez is offline   Reply With Quote
Old 09-08-2004, 05:44 PM   #7440
According to Erik they are more durable and have less friction than the stock composite ones. If they are made anything like the stock spur gears they are going to last for quite some time!
