Like Tree5Likes
Old 09-06-2004, 10:42 AM   #7396
kevin2's Avatar
Send a message via AIM to kevin2
kevin2 is offline   Reply With Quote
Old 09-06-2004, 10:49 AM   #7397
pro4racer's Avatar
thanks john b i will try that on friday thanks for putting it alot simpler 4 me cheers
james
pro4racer is offline   Reply With Quote
Old 09-06-2004, 08:19 PM   #7398
MI2
MI2's Avatar
does any one have a pro 4 for sale
MI2 is offline   Reply With Quote
Old 09-07-2004, 10:53 AM   #7399
Default 48p Spur?
Sorry for the novice question, but I'm wondering if there are 48 pitch spurs that will fit the Pro 4. My LHS only has 48p pinions and I know the Losi XXX-S uses a 48p spur.
What would the advantages/disadvantages of changing to a 48p spur be? (other than local parts availability in my case)
Thanks for the help,
tony
revnine is offline   Reply With Quote
Old 09-07-2004, 10:57 AM   #7400
X2
X2's Avatar
Any 48dp spur will fit fine. The only advantage to 48dp is that if you are racing outside with 64dp grit can easily build up in the teeth. Also 48dp will not strip so easy.
X2 is offline   Reply With Quote
Old 09-07-2004, 11:02 AM   #7401
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
Tony:
checkout: http://www.robinsonracing.com/tips.html
The RRP geat will work good.
Checkout the TC3 Ultra gears...
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 09-07-2004, 11:13 AM   #7402
chr15tophe's Avatar
Default Pro4 Setup Q.
Went racing the other Sunday had on Corrally SSB tyres, made by (Take off), rear of the car was loose as anything despite running a soft setup at rear and stiff at front, lowered the camber link and have long wheelbase at rear, steering turned down to reduce steering throw also ride height at rear is 6 as is front, droop 4 at front 3 at back. Would appear that my initial turn is so much its causing the rear to kick out, now when i put on CS 27 tyres the car was a dream to drive and took ftd and won the A, however this is no good as ive got to run with the SSB tyre ( quite a hard compound) how can i get the car to handle like when i put the cs 27 tyres on?? Running a oneway up front also as its quicker than running a diff.
chr15tophe is offline   Reply With Quote
Old 09-07-2004, 11:17 AM   #7403
Tres's Avatar
chr15tophe: did you adjust Front toe-in any?
Tre's
www.tnt-fx.com
Old 09-07-2004, 11:22 AM   #7404
Default Thanks!
Tres and X2,
Thanks for the info! Cool link too!
Tony
Old 09-07-2004, 11:31 AM   #7405
chr15tophe's Avatar
the rear toe in is set at 3 and the front I generally run at 0, i have run 1 degree toe in b4 but didnt effect greatly how the rear was behaving
Old 09-07-2004, 11:32 AM   #7406
chr15tophe's Avatar
possibly a castor change is in order maybe goto the 6 degree block
Old 09-07-2004, 12:24 PM   #7407
Going to the 6 degree blocks will make your car turn in harder and more agressivley. You could try the 2 or 0 degree blocks. Or try adding some antisquat, I found the that this helped make the rear of the car to behave more predictably and still have 95% of the steering that it had before. Jonathan
jonny69 is offline   Reply With Quote
Old 09-07-2004, 12:46 PM   #7408
robk's Avatar
Trader Rating: 22 (100%+)
Raise rear camber link, shorten wheelbase.
Old 09-07-2004, 01:01 PM   #7409
chr15tophe's Avatar
shortening the wheelbase will only make the situation worse, as its ment for tight twisty tracks when you need more steering by transfering weight to the front. I have too much steering i think.
Going to a 6 degree castor block increases mid corner steering and takes away initial steering, doesnt it? I reckon i have a car that is turning to sharp on entry to a corner.
Hard to know what the car does sometimes when racing i just concentrate on each corner, after the race i tend to forget how the car went... More practice needed heheheh
Old 09-07-2004, 02:08 PM   #7410
Quote from the Pro 4 manual. "Generally, more caster will give you more initial steering" and then "with less steering exiting the corner" I would try reducing the caster, and return the wheel base to its Kit setting. Then if you still need more grip lower the rear inner camber link, you may have to grind down the ball stud if you go too low as it may grind on the outdrive.Jonathan
