Old 09-01-2004, 06:26 PM   #7321
the o rings provide a quicker rebound than the foam does so the shock responds faster.
sportracer is offline   Reply With Quote
Old 09-01-2004, 06:39 PM   #7322
azenis's Avatar
Makes sense. Can you use any old o-ring or is there a specific type to use?
What about my piston dilema?
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 09-01-2004, 10:46 PM   #7323
Send a message via Yahoo to Doug Gaut
Azenis, if it were me I would use the #2 pistons front and rear and drop your shock oil weight by 10wt. Use 45wt front and 40wt rear. This should be a close simulation plus you will still have balanced dampening front to rear by using the same pistons. I cannot comment on the o-ring in the shock as I have never tried it before. Hopefully Thad, Erik or somebody that has used the o-rings in this manner before can elaborate more for you. Until then I would leave them out just to be on the safe side.
Doug Gaut is offline   Reply With Quote
Old 09-01-2004, 10:51 PM   #7324
azenis's Avatar
Doh!
Not much use as I just bought 55wt and 50wt oil or this job and it is all i have
Nige
Old 09-02-2004, 09:07 AM   #7325
Erik Shauver's Avatar
Default Re: Wide Bumper...
Originally posted by DOMOisCOOL
Anyone have a wide bumper for this car or made one on their own? I modified my Kyosho V One R bumper to fit and it's saved me a ton of arms.
I believe the stock HPI R40 wide bumper will fit the Pro 4 as well, but have not tried it yet.*
*Edit: Stock R40 bumper will NOT fit.
DOMOisCOOL: Try this page of this thread Bumper Mod. Go about halfway down and I posted a 1:1 shot of a modded BRP bumper for a rough template.
JohnB: Thanks! Also, we are looking at a running change for the C-hubs. For now the fix is either a little heat to bend the C-hub or to file the steering block until it moves freely. We're working on it.
Erik Shauver is offline   Reply With Quote
Old 09-02-2004, 09:13 AM   #7326
The Evicerator
Erik:
How should I gear 4' castor blocks as opposed to 2' or 6'?
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 09-02-2004, 09:17 AM   #7327
rayhuang's Avatar
Man-those are some long caster blocks!! 2', 4' and 6'!!
I'd gear the 2' at 0.90
The 4' at 1.05
and the 6' at 2.00
Old 09-02-2004, 09:19 AM   #7328
big_G's Avatar
R/C Tech Charter Subscriber
Well the TIR spool arrived today and the engineering is excellent.
replacement outdrives supplied and also available as spares.
big_G is offline   Reply With Quote
Old 09-02-2004, 10:38 AM   #7329
rc-zombies's Avatar
Adrian from Schumacher just informed me that they have placed an order for the TIR spools, outdrive cups, plus the other Pro4 option parts. and they expect them withing 4-6 weeks. check the Schumacher website in Oct.
Old 09-02-2004, 01:10 PM   #7330
pucho's Avatar
Send a message via AIM to pucho
Default Re: Re: Wide Bumper...
Hey Erik good to see you around again, is there anyway to make the steering block a little more durable, I keep braking them at the bottom screw position. Also It would be nice if one could just buy 2 steering block instead of the current packaging. Please tell your people about this that would be a nice change.
pucho is offline   Reply With Quote
Old 09-02-2004, 01:14 PM   #7331
rc-zombies's Avatar
Default Re: Re: Re: Wide Bumper...
yes...definately..packaging the steering knuckle and rear hub seperately would be benificial...
if racers are breaking the steering knuckle alot more...what you're left with is handful of rear hubs gathering dust...
or another option is post a parts trade in the for sale/wanted threads
Old 09-02-2004, 01:19 PM   #7332
kewdawg's Avatar
Default Re: Re: Re: Re: Wide Bumper...
Very true! Associated does the same thing, with the TC3. I can't tell you how many rear hubs I have in my pit box.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 09-02-2004, 03:40 PM   #7333
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Pucho.....I was having the same issue....so what I ended up doing was using XXXS graphite steering blocks. They fit right in the only thing is that you need new bearings and new CVD axles....I used TC3 ones and TC3 hex's. The only real draw back to this is that you dont have the back hole on the losi block. The losi block only has one hole and its in the same place as the forward hole. I only did this b/c I was tired of replacing the steering blocks too often....and one to a package also sucked. Once I did this change I have not had any more breakages.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 09-02-2004, 05:25 PM   #7334
pucho's Avatar
Kevin thanks for the suggestion, I have most of the parts available. Question is what kind of effect did it have on your handling? Steering?
Old 09-02-2004, 06:20 PM   #7335
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default rubber tire questions
Ok all you west coast rubber tire guys help me out with this.
With track temps around 100-125 what tire/insert combo would you start with. The track is med/high bite treated with sugar water.
I normally run on carpet with foams and rubber tire are still kinda of a mystery.
In Connecticut we dont get the super high track temps.
I have tried 32r and 36r with hpi blue med/hard insert and car seems to push badly.
I tried 28r with hpi blues and tires seem to overheat and wear quickly but car has improved steering.
Can I get more steering by running a softer insert med or med soft in 32 and 36r's.
Thanks for the info
Jamie
J.Gonzalez is offline   Reply With Quote
