Like Tree5Likes
Old 09-01-2004, 08:17 AM   #7306
Thanks for all the words of encouragement on getting the Pro 4. Now to start building ?
Thanks, Marcusg
P.S. Is the building tips you fellas recommend, or upgrades ?
Thanks again.
marcusg is offline   Reply With Quote
Old 09-01-2004, 10:21 AM   #7307
big_G's Avatar
R/C Tech Charter Subscriber
Originally posted by acutts
Hey
Have you got contact details? The numbers I got off the website don't seem to work ....!
Cheers
Scott
Ah - I had the same problem - even tried to buy from the site but the secure server side kept crashing!
Eventually dropped them an email and they sent me a number to call but unfortunately it's at work - I'll drop you a PM tomorrow with the number
big_G is offline   Reply With Quote
Old 09-01-2004, 01:25 PM   #7308
Send a message via Yahoo to Doug Gaut
Marcusg, the only thing I did when I built the car was to install the associated diff bolt/nut and the diff spring. Other than that you will be fine by just following the instructions and building the car per spec. Depending on what surface you will be racing on , the kit setup works great on low to med bite concrete and asphalt tracks.
There are tons of aftermarket alum parts out for the car but I have yet to break anything on the car since getting it back in April so I dont think that any of it is absolutely necessary. Its the bling factor that kicks in on most of the stuff.
Good luck and ask away if you need anything. We all have different opinions on what is needed and what is not but all in all , we all agree on one thing, we love the car and are willing to help
Doug Gaut is offline   Reply With Quote
Old 09-01-2004, 01:31 PM   #7309
DOMOisCOOL's Avatar
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Default Wide Bumper...
Anyone have a wide bumper for this car or made one on their own? I modified my Kyosho V One R bumper to fit and it's saved me a ton of arms.
I believe the stock HPI R40 wide bumper will fit the Pro 4 as well, but have not tried it yet.*
*Edit: Stock R40 bumper will NOT fit.
DOMOisCOOL is offline   Reply With Quote
Old 09-01-2004, 01:35 PM   #7310
rc-zombies's Avatar
Default Re: Wide Bumper...
nope the R40 or NSR3 wide bumper will not fit....
some have modified the Bud's TC3 wide bumper to fit.
I cut my own from Kydex plastic. and recently use HPI nitros big foam bumper and trim to fit..and no need for a wider lower bumber plate...
Are you still going to SWR this SAT. free race?... I might drop by in the AM for a visit before I head to a family gathering in Elk Grove.
Old 09-01-2004, 01:37 PM   #7311
DOMOisCOOL's Avatar
Default Re: Re: Wide Bumper...
Don't think so. Too far.
Old 09-01-2004, 01:44 PM   #7312
Thanks Doug .
Marcusg
Old 09-01-2004, 01:59 PM   #7313
Registered User
Why need wide bumper! I still haven't break any single part on my pro4 yet. Maybe 19Tspec is not fast enough to break pro4.
Aku-Man is offline   Reply With Quote
Old 09-01-2004, 02:27 PM   #7314
pro4racer's Avatar
hi i c that every 1 changes the fixings in the hpi pro4 diffs to associated diff bolt/nut and the diff spring why is this what benefit would it have if any.
pro4racer is offline   Reply With Quote
Old 09-01-2004, 02:56 PM   #7315
big_G's Avatar
I have to agree with the posts above - Why fit a wide bumper?
I've raced my Pro4 since last October/November an have only broke the following.
One ball stud when someone used the side of my car as their brake in a corner!
Original gears - not boiled and all other parts standard
Old 09-01-2004, 03:06 PM   #7316
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
I have one on my car and have helped a couple other local guys fit kydex bumpers to the stock bumper. I used a BRP Losi XXXS bumper but what I have found to work the best is the Parma Losi XXXS bumper with a little work its fits very nicely and looks very clean. Before I added one to my car I was braking an arm about every race day. After I installed it I haven't broken one. Something like this is really only needed if you race on a track with boards for the barrier system. And all of the tracks that I race on are that way....you look at them wrong and your car will come back in pile of parts. If the track that you race on has a very forgiving barrier system then you will more then likely not need it.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 09-01-2004, 03:19 PM   #7317
JohnB's Avatar
Originally posted by yeuc001
hey guys,
I am trying to my pro4 together, when I try to put the steering block and C-hub together, I find out that it is too tight to fit.
no matter what I do, I can't get it to turn it smoothly.
does any of you guys run into this problem
when you put together your pro4?
pic attached
thanks guys
yeuc001 - It's not just you. I have been finding the same thing. Of the hubs that came with the car and one extra 6* pair, about half of them are mold so the C comes together on the end and pinches. I polishes all the steel inserts so they look like a mirror. That helped a little. One on side I put the steel insert in backwards (flat shoulder on the outside) and that worked.
HPI people if you reading ---- I am VERY impressed with all the molded parts on the car. But this one part needs to be addressed. Just open up the C a little bit would prevent any binding.
take care
john
JohnB is offline   Reply With Quote
Old 09-01-2004, 04:19 PM   #7318
DOMOisCOOL's Avatar
We use boards as our road course, so one hard hit to the board can be pretty devestating.
Old 09-01-2004, 04:26 PM   #7319
Entropy's Avatar
take care
john
I just use a high torque servo. Actually I'd rather have them tight than loose so I don't have to worry about the part being shaky and affecting handling.
Entropy is offline   Reply With Quote
Old 09-01-2004, 04:54 PM   #7320
azenis's Avatar
Default shocks
Im rebuilding my car to one of Thads setup sheets from may this year I think.
Anyhow the shocks use 55t front and 50wt rear. It mentiones something about an o-ring on top of the bladder, any idea what that means? Does it use an o-ring instead of the rebound foam thing?
Also it uses the number 1 pistons. I only have 2 of these (only got 2 of them with my car) and i dont have enough time to get any in from overseas before the race this sunday. Would it make much difference if I used the number two pistons? Or put my 2 number 1 pistons on one pair of shocks and the other get number 2s? If so should the number 1's go on the front or rear shocks?
thanks for the help
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
