Like Tree5Likes
Old 08-21-2004, 11:58 PM   #7111
Skill's Avatar
Default Re: Boiling new gearsets?
Originally posted by revnine
Anyone know if HPI suggests boiling the new bevel gears sets like the old ones? Sorry for the repeat question, but I got the new ones and would like to get them in the car as soon as I can...
Thanks again.
There should be no need to boil the new gears.
Skill is offline   Reply With Quote
Old 08-22-2004, 03:54 AM   #7112
big_G's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Re: Springs
Originally posted by StewartFan20
I just put the BMI 3mm chassis on the car and the front shock tower is a lower profile and I cannot get ride hight below 6mm. I put the stock shock tower on and the lowest I can get the ride hight is 4.5mm. I am using AE springs which are about 25mm and I thought if I could find some shorter springs, it would help.
Do you really want to go lower than 4.5mm ??
big_G is offline   Reply With Quote
Old 08-22-2004, 06:20 AM   #7113
StewartFan20's Avatar
Default Re: Re: Re: Re: Springs
No. But, I can't get to 4.5mm with the BMI shock tower and I really want to use it. I can only get to 4.5mm with the stock shock tower.
StewartFan20 is offline   Reply With Quote
Old 08-22-2004, 07:14 AM   #7114
Super Steve's Avatar
Send a message via AIM to Super Steve
ya... i am also having probs getting to 5mm with bmi shocktowers...
Right now i am like 5.5ish
Super Steve is offline   Reply With Quote
Old 08-22-2004, 07:23 AM   #7115
lazyboy's Avatar
Send a message via AIM to lazyboy
check your droop. this will through off ride height settings by alot
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 08-22-2004, 09:35 AM   #7116
rc_square24's Avatar
some local guy is running the rear shock tower up front cuz of the spool he said ....what difference would that make?
rc_square24 is offline   Reply With Quote
Old 08-22-2004, 10:47 AM   #7117
X2
X2's Avatar
It would give a more balanced feel to the car and allow you to use the same springs all tound with very consistant handling.
The BMI front shock towers have the same hole locations as the HPI rear shock tower...
X2 is offline   Reply With Quote
Old 08-22-2004, 11:08 AM   #7118
well i ask a very profound question of you HPI people and all i got was ....dude ask some other guy...who which i never heard of. I never really had my question answered and passing my question off to some other guy was not what I was looking for. Now that my question is on the other page I bet no one will see it and thus my question is reasonably dead.
rustler753 is offline   Reply With Quote
Old 08-22-2004, 11:21 AM   #7119
big_G's Avatar
RC-Zombies gave you a profound answer!
You are looking for a comparison of 3 cars - now why should everyone in here be able to do that?
RCZ believes that Ray Haung is capable of giving you that answer.
Ah - you don't know him - well neither do I - but a search of the members list brings you all his details!
Send him a mail or a PM - I am sure that he will give you his honest opinion.
Old 08-22-2004, 11:28 AM   #7120
X2
X2's Avatar
I will have ago at your qeustion...
First of all the Xray and Pro4 are completly different in design, but both will still perform in the right hands.
Now, being a Pro4 driver its my duty to tell you that the Pro4 is better than any other car out there BUT I wont because that would be biased.
Look at the facts, The Xray should in theory have better weight distribution and balance due to the cell location. However, the Pro4 does have that extra advantage of having the added efficiency and acceleration a shaft brings, with torq steer though (which would be VERY hard to notice unless your name is Hara).
They can both be as competitive as each other so long as they are set up correctly, so there isnt much between them.
So, the only way to choose between the two would be looking at price (here in the UK the Pro4 is cheaper) , Parts support (also over here the Pro4 has exellent support) and set up information(I know there are a lot of set up sheets flying about on HPI's website, not sure about Xray though). Also see what other guys at your track are using, to get help with set ups.
Also, I THINK the Pro4 has a stiffer chassis too, it can also have extra purple parts added
Old 08-22-2004, 11:30 AM   #7121
X2
X2's Avatar
P.S. Pro4 rocks, U.S national champion. Buy one!
Old 08-22-2004, 12:20 PM   #7122
er...
droop doesn't affect ride height unless you have it set so tight that it adjausts ride height (but that's not what droop adjustment is for)
Old 08-22-2004, 12:33 PM   #7123
X2
X2's Avatar
Originally posted by Super Steve
er...
Droop affects the amount of body roll your car has
Old 08-22-2004, 12:33 PM   #7124
rc-zombies's Avatar
hmmm...
I was hoping not to install my BMI chassis til Dec...
I may have to install my chassi and check this situation out.... I too run 4.5mm up front and around 4.8-5mm in the rear.
oh btw...did you guys remove .5mm arm mount spacer to adjust the difference going from 2.5 to 3mm chassis?
Old 08-22-2004, 12:36 PM   #7125
rc-zombies's Avatar
Default Re: Re: Boiling new gearsets?
