Like Tree6Likes
Old 08-19-2004, 02:06 PM   #7036
kewdawg's Avatar
Originally posted by galway
ALso the new kits have upgraded gears that should break as easily.
Don't you mean... should NOT break as easily?
The new kits have the aluminum backing plate for the one-way, also.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 08-19-2004, 02:40 PM   #7037
robk's Avatar
Trader Rating: 22 (100%+)
"Not to mention, I bet that shaved at least 1/4 to 1/2 gram of weight....that is = 0.00547 Horse power gain....."
Rookie is funny
Old 08-19-2004, 02:40 PM   #7038
jland's Avatar
Trader Rating: 74 (100%+)
Originally posted by rc-zombies
I though you have to buy everyone a drink before you're an official Pro4 thread member.
Sure, just have to travel to the UK for it...
One thing I have found with this car and messing with the set-up it that Weight Distrabution is key. I had a really bad oversteer when I turned left. I added about 40g of weight around the motor area and now it is really driving well.
If you haven't put the car on scales or a tweak board it makes a huge difference when you get it right.
As for breakage I have had great luck keeping it in 1 piece. Only bent 1 mip bone..
jland is offline   Reply With Quote
Old 08-19-2004, 02:57 PM   #7039
JohnB's Avatar
R/C Tech Charter Subscriber
Default Another Pro 4
Howdy all. I just got a Pro 4 also. Spent the last few days reading through all these post, wow. I haven't seen a lot on carpet setup's. Just the one in the instruction book and one on the HPI web site. I did order some different degree's of block after looking at those two setup's. Any other carpet suggestions?
I glad you mentioned the dogbone. Is everyone running the alum. bones and composite outdrives for mod?
Thanks and take care
john
JohnB is offline   Reply With Quote
Old 08-19-2004, 03:48 PM   #7040
coastaltony's Avatar
I'M IN ON COCTAIL HOUR,
WHERE SHOULD WE MEET?
lol
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 08-19-2004, 04:20 PM   #7041
Essnowyt's Avatar
Send a message via AIM to Essnowyt
JohnB - Do you run carpet foam or rubber? I have a fair set up for Carpet with CS-27. Let me know if your interested.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 08-19-2004, 04:40 PM   #7042
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
JohnB.....If your racing Carpet Foam tires start with the setup from Hara in the book. It will get you going in the right direction. Also if you are racing Foam tires think about getting a 3mm chassis it makes the car faster as the grip gets higher. PRP, HPI and BMI all make a 3mm Chassis. Check out each one and see just what they bring to the table. IMHO the PRP is the best bang for the buck....unmatched tuning ability with this Chassis over the others. All three make very high quality stuff so you will get great quality with which ever one you go with.
AS far as the outdrives and bones....that seems the way most people are going. You can try the Delrin outdrives...Im not sure on how well they hold up to mod but Hara runs them in mod so they must be ok. I just got mine from KT hobbies(shameless plug ) and will try them this weekend and see how they work out.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 08-19-2004, 05:47 PM   #7043
HuDy WiNnEr's Avatar
Send a message via AIM to HuDy WiNnEr
Default Diff Gears
Hi, I received my version 1.1 diff gears a couple of weeks back and I was wondering if anyone had trouble with there drivetrain being "less free". It almost looked like the gears were rubbing on the diff case. I was just wandering if anyone had the same problem.
HuDy WiNnEr is offline   Reply With Quote
Old 08-19-2004, 06:55 PM   #7044
JohnB's Avatar
Thanks for the ideas. Yes, foam tires. I'm comparing the difference between Hara and Garner's setup as I'm putting the car together. Kinda going by that and from I know worked on the TC3 on our track.
On garner's setup he has 1.5mm and 2mm for rear anti squat. Guess you have to use washers to get the 1.5? The shims with the kit are .5 and 2mm. Hara had 1mm on both blocks so no anti squat? Or are the two blocks not the same height? I didn't messure them before I put them on.
I have looked at those chassis' a little. They look pretty good. The PRP looks good, but with a 3mm chassis, and 3mm top deck, what the heck do you need the side braces for? Seems like over kill I'll run the stock chassis for awhile and go from there.
Old 08-19-2004, 07:01 PM   #7045
Kevin K's Avatar
The side braces are to protect your electronics from a side impact...that is the main function of them. They will make the chassis a little stiffer but thats just secondary to the real reason they are there.
Old 08-19-2004, 08:29 PM   #7046
JJ187RC's Avatar
I am also building a Pro 4 for carpet. I have ordered all the pivot blocks and spacers to get what I want. Where can I look at this PRP chassis?
JJ187RC is offline   Reply With Quote
Old 08-19-2004, 08:52 PM   #7047
Kevin K's Avatar
Check it out at www.teamprpracing.com They have already started shipping.
Old 08-19-2004, 09:25 PM   #7048
JJ187RC's Avatar
Thanks Kevin.
Old 08-19-2004, 11:24 PM   #7049
Speed Demon's Avatar
JJ187RC .... your avatar is bouncy
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 08-20-2004, 03:38 AM   #7050
VenomWorldOrder's Avatar
i'm in australia...still waiting on my PRP chassis anyone around the world got theirs yet? i was hopping i could of raced with it this weekend
VenomWorldOrder is offline   Reply With Quote
