Old 08-17-2004, 01:09 PM   #6961
jonathan123's Avatar
Originally posted by Skill
Jonny, the weight disadvantage of the delrin diffs is very small, I think it was about 0.1g for both sides of the diff. The delrin diffs are more durable and make the diff a bit smoother, plus they look nicer
Cheers mate
jonathan123 is offline   Reply With Quote
Old 08-17-2004, 08:00 PM   #6962
Speed Demon's Avatar
Default Re: Re: open gearbox
Originally posted by rc-zombies
PRP will be coming out with aluminum bulkheads by end of the year. What's wrong with the stock ones...they will be lighter than aluminum.
Plus... the pebles wont make their way into the bevel gears...
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 08-18-2004, 12:54 AM   #6963
Eirik's Avatar
Originally posted by acutts
Anyone know what make these white ballcups in the picture are?
It's the new Losi Ballcups, No more slope and they look great IMO!
Cheers,
Eirik
Eirik is offline   Reply With Quote
Old 08-18-2004, 12:59 AM   #6964
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Default Re: Re: Re: open gearbox
Although it would be pretty cool if there was a protective cover, like the Baracuda's.
DOMOisCOOL is offline   Reply With Quote
Old 08-18-2004, 02:30 AM   #6965
acutts's Avatar
Cheers,
Eirik
Thanks for the info Eirik .... Im assuming the car in the pic is yours .. .. if so well done on your win!!
Did you drill holes in the top of them? Also I see you stop sideways movement of the anti-roll bar with collets? Which ones do you use and do you have a part number?
Cheers
Scott
acutts is offline   Reply With Quote
Old 08-18-2004, 03:11 AM   #6966
Entropy's Avatar
Default Re: Re: Re: Re: open gearbox
Ewwww, I'd prefer a less boxy cover.
Entropy is offline   Reply With Quote
Old 08-18-2004, 04:05 AM   #6967
Eirik's Avatar
Acutts,
Yes, you are right, the car is mine....
I used a reamer to make the holes in the ballcups, makes it allot easier to change the rollcenters!
The collars are made made by a company called Q-World, you could also check out Ofna as this is the same parts. Not sure about the partnumbers though.
Later,
Eirik
Old 08-18-2004, 04:13 AM   #6968
X2
X2's Avatar
Default Open Gearbox
Id like the open gearbox or even just an alloy version of the stock gearboxes, it seems that alot of Pro4 tweak comes from the graphite ones.
The price for these will be high though
X2 is offline   Reply With Quote
Old 08-18-2004, 05:16 AM   #6969
Skill's Avatar
The mould on one of my gearboxes isn't too good, and the upper bulkhead doesn't sit on the lower bulkhead properly, I'm sure other peoples are like this, and alloy bulkheads would definately be more precise. If the bulkheads are open then that may save some weight and possibly be not much different to the stock gearboxes, plus most of the weight would be lower down.
Skill is offline   Reply With Quote
Old 08-18-2004, 07:16 AM   #6970
pucho's Avatar
Send a message via AIM to pucho
I would not mind seing a version like the CUDA, sort of like the prototype cars. I would just like the fact that everithing would rin truer but the stock ones due a great job.
pucho is offline   Reply With Quote
Old 08-18-2004, 10:11 AM   #6971
brushless's Avatar
Default Springs.
I know my answer is somewhere in this post, but do the TC3 springs fit on the Pro 4? The Pro 4 doesn't seem to have a very good selection of springs.
brushless is offline   Reply With Quote
Old 08-18-2004, 10:22 AM   #6972
rc-zombies's Avatar
Default Re: Springs.
yes they fit... and all the springs for the Pro4 are readily available and is very comparable to the spring weights of the TC3.
Old 08-18-2004, 10:24 AM   #6973
brushless's Avatar
Default Re: Re: Springs.
Yes, but there are only 7 different spring rates with the Pro 4 and they are pretty close together. The TC3 springs are spaced further apart and there are 9 different springs.
Do they fit exactly like the Pro 4 springs, or are they sized a little different?
Old 08-18-2004, 10:37 AM   #6974
rc-zombies's Avatar
Default Re: Re: Re: Springs.
the Pro4 springs are spaced closer together for more of precise setting. most likely you'll never use the lighter springs.
I forget what size the TC3 springs are...it's been a very long time since I've owned a TC3.... I think it's smaller than the Pro4 springs.
Old 08-18-2004, 10:45 AM   #6975
brushless's Avatar
Default Re: Re: Re: Re: Springs.
Have you used the TC3 springs on your car or have you just heard that they will work?
