Old 08-16-2004, 04:53 PM   #6931
I have also developed this same problem the last two weeks. But only in mod. Stock it's fine. I just got the 1.1 gears but havn't installed them yet. I'm also going to replace the gear box just in case.
Originally posted by azenis
Ahh thanks for that RC ZOMBIES
And to keep this pro4 related, i seem to have a gear mesh problem with my back gear box
got the shims mounted like this
spur/bearing/1 shim/spacer in gearcase/2 shims/bearing/bevel gear
Whenever I launch or brake it crunches and the gears slip
Should I put all 3 shims in the back position? Only trouble with that is my thicker than standard spur gear then JUST touches the chassis plate
I have a set of the 1.1 gears in my tool box, If I fitted them would that fix the problem? Do the 1.1 gears need boiling?
Downforce is offline   Reply With Quote
Old 08-16-2004, 04:55 PM   #6932
azenis's Avatar
Oh I didnt know there were shims you could move ar diff gear as well, only been adjusting the ones on the bevel/spur gear shaft (I didnt build my car and havent had the diffs apart myself yet - rebuilt about everything else though)
cheers thanks for that
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 08-16-2004, 04:58 PM   #6933
Default hara
any 1 know of an atsushi hara varsion of da pro 4 in aus
pink panther is offline   Reply With Quote
Old 08-16-2004, 05:01 PM   #6934
rc-zombies's Avatar
Default Re: hara
not available at the moment... we'll see after the Worlds... Hara's car is basically stock anyways... except for the delrin diffs which is available already in some parts of the world..but not in the US..
Old 08-16-2004, 05:12 PM   #6935
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Re: hara
Not in Japan yet... but next week they will be
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 08-16-2004, 08:27 PM   #6936
rc-zombies's Avatar
Default Re: Re: Re: hara
-Dave
Not yet...wow...I'm surprise that Japan didn't get them first.... looks like the UK got them first... and was able to get something before you....
I got a handfull from the UK... they are super light and smooth.
so... nobody PM me... I don't have anymore to sell.. sorry all sold and spoken for.
Old 08-16-2004, 09:56 PM   #6937
Default Re: Re: Re: Re: hara
Yea yea I know
-Dave
Old 08-17-2004, 12:34 AM   #6938
Skill's Avatar
Wow that's a first, UK getting some parts before Japan and USA, I feel priveliged
Have the chassis weights and delrin bearing adaptors come out yet because they are out in the UK too?
Skill is offline   Reply With Quote
Old 08-17-2004, 01:10 AM   #6939
acutts's Avatar
Have you got the chassis weights? I was going to get them but then found out for 11 you only get 20g weight ... what a major rip-off ... think I will be sticking to lead weights I can get for free from tyre balancing place
acutts is offline   Reply With Quote
Old 08-17-2004, 01:11 AM   #6940
Default Re: hara
Not sure you can get a normal Pro 4 in Australia, most guys get them from H.K.
warex is offline   Reply With Quote
Old 08-17-2004, 02:28 AM   #6941
Speed Demon's Avatar
Default Alloy Front bevel gear
did anybody tried the square alloy bevel gear for the front one waY?? I believe that square came out with it when we have the problem of the bevel gear that flex... then came the prp & hpi backing plate to reduce the flex...
But, what you guys think of the alloy bevel gear???
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 08-17-2004, 02:38 AM   #6942
X2
X2's Avatar
I think the alloy gear would be a good fix to the gear breaking problem a touch heavy I would have thougt tho.
It would however probably just shift the stress somewhere else like the CVDs.
X2 is offline   Reply With Quote
Old 08-17-2004, 02:49 AM   #6943
Skill's Avatar
No I didn't buy them...or the bearing adaptors, I don't normally race with a minimum weight anyway, and like you, I'd just use lead weights, but the thing is, we've still got them in the shops here in the UK
IMO the alloy bevel gear will increase rotating mass by a lot and just make the smaller bevel gear strip easier but I can't say without trying it obviously.
Old 08-17-2004, 03:03 AM   #6944
acutts's Avatar
Yip it is rather amazing that we are getting things first here in the UK ... we are normally last to get the good stuff ..! Long may it last
Now I have to hope the new Hudy setup station is released here 1st !!!!!!!!!!!!!!!
Old 08-17-2004, 04:17 AM   #6945
Skill's Avatar
With Mirage now distributing Hudy that will be more likely, I think they're doing a good job of getting bits out so far, although the price might be a bit steep...
