Like Tree6Likes
Old 08-06-2004, 05:22 PM   #6766
diesel's Avatar
If there is a ver.1.1 sticker pasted on your box, then you will know you have the updated gears.
diesel is offline   Reply With Quote
Old 08-06-2004, 07:16 PM   #6767
rc-zombies's Avatar
Default Re: new gears
Originally posted by csilve
I just bought a new kit. How do I know if it has the updated gears?
it will include a purple diff plate for the new gears to be used for the oe-way.
Old 08-07-2004, 12:39 PM   #6768
Super Steve's Avatar
Send a message via AIM to Super Steve
I still have to call HPI for the gears...
Can't wait till my new pro-4 stuff to get here...
i spent over 1 grand canadian in this thing now!
Super Steve is offline   Reply With Quote
Old 08-07-2004, 05:37 PM   #6769
NoChanceRacing's Avatar
Send a message via AIM to NoChanceRacing Send a message via Yahoo to NoChanceRacing
Yeah iam going to call Hpi this week to get the upgrade gear kit for the Pro4 got 2 Pro4s to get them for hope they are not out of stock.
NoChanceRacing is offline   Reply With Quote
Old 08-07-2004, 05:39 PM   #6770
Heard that the one way gear will brake without the upgrade kit?
Old 08-07-2004, 08:46 PM   #6771
Originally posted by NoChanceRacing
Heard that the one way gear will brake without the upgrade kit? when going into the pipes
I've broken about three of the original oneway gears, but I have gone several races without any problems to the original gear. It's just a part of racing to break parts. HPI can't engineer indestructibility into the car. Anything will break when going into pipes. Work on your driving and you won't have to work on the car.
jbackslash is offline   Reply With Quote
Old 08-08-2004, 06:08 AM   #6772
Yeah ive had no problems with the car or the one way braking only thang we had go wrong with the pro4 is the diffs were slipping but we fixed that problem so the car is awesome now just heard something about the one way braking. we had the pro4 for like 4-5 months now. nothing broken yet! i guess because havent crashed yet pro4 is on a rail so much!
Old 08-08-2004, 11:40 AM   #6773
rc_square24's Avatar
the nut under my steering plate that holds the left toe link ball studs keeps on scratching the "F/R" toe pivot blocks on the front end.
the f/r block was pressed forward evenly with two fingers while being tightened, and the steering wipers were new parts so what gives?
the left side of the plate seems to swing closer than the other(on max. point) as the right side nut doesnt get half as close when its at its closes pt to the block.
thanks guys
heres an attchmnt.
rc_square24 is offline   Reply With Quote
Old 08-08-2004, 11:59 AM   #6774
Default PRO4 Differential Parts
here is the listing of parts needed
someone posted this picture
One diff bolt, One diff bolt cover, One T-nut (6575)
One diff spring (6582)
for those who needs to know...
as for the steering rack problem, i don't think mine touches the F/R block
Old 08-08-2004, 01:22 PM   #6775
Skill's Avatar
What is most likely to have happened is that you have bent the F/R toe block somehow, which is causing it to catch on the steering. Mine also slightly does this on the opposite side, it must be when you take some hard hits it just bends it back slightly.
Skill is offline   Reply With Quote
Old 08-08-2004, 02:17 PM   #6776
or you could have a bent screw causing the block to be pushed back ,ihad the same problem and I replaced the block and the screws
sportracer is offline   Reply With Quote
Old 08-08-2004, 02:22 PM   #6777
HuDy WiNnEr's Avatar
Send a message via AIM to HuDy WiNnEr
Yeah most likely the f/r toe block is bent like skill said. You could take it out and put it flat on your tweak board or what ever and see if it sits flat or compare to the other block. hope that helps.
HuDy WiNnEr is offline   Reply With Quote
Old 08-08-2004, 02:29 PM   #6778
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
thanks guys
heres an attchmnt.
It"s bent.. Replace it.. ... both the Screws and the F/R block
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 08-08-2004, 02:47 PM   #6779
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Another Ackerman question. I was looking at set up sheets from HPI, there is a field to add a spacer in-between the servo saver arm and the carbon fiber Ackerman plate. So what affect would this have? If I put a 1mm washer in between the arm and plate will this add steering or decrease it? Thank for all your help.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 08-08-2004, 05:26 PM   #6780
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Ramon,
Looks like the Losi Race is cancelled...
DOMOisCOOL is offline   Reply With Quote
