Old 08-05-2004, 01:26 PM   #6736
rc-zombies's Avatar
Originally posted by X-Garage
I use red TAMIYA spring in the rear and that is the softest TAMIYA has. I do need more traction on the rear...what else could I do?
place harder springs in front... ?
Thinner oil in the rear shocks?
Old 08-05-2004, 01:33 PM   #6737
X-Garage's Avatar
I also added 2mm to rear arms block to increase roll center. I still feel a little loose on the rear.
I already have yellow Schumacher springs in the front which are pretty hard.
What oil number you are using? for the rear and for the front?
X-Garage is offline   Reply With Quote
Old 08-05-2004, 01:56 PM   #6738
Try lowering the inner roll centre spacers, lowering it will give you more grip.
jonny69 is offline   Reply With Quote
Old 08-05-2004, 01:59 PM   #6739
rc-zombies's Avatar
I'm using Hara's set-up from the ROAR nats....
40wt-F
35wt-R
same oil I used since Day 1 when I got the car.
Old 08-05-2004, 02:10 PM   #6740
X-Garage's Avatar
Does the set up on HPI web?
I was trying to set up to match the track condition at my local place, but I think too much time already to test and try now I'm going to go with Hara setup..
The car runs good now..but I want it to go on a rail!
Old 08-05-2004, 02:21 PM   #6741
rc-zombies's Avatar
see the link and click on the word "set-up"
http://www.hpiracing.com/index2.htm
Old 08-05-2004, 03:17 PM   #6742
robk's Avatar
Trader Rating: 22 (100%+)
"IT'S A JOKE, DAMNIT A JOKE!!!!
You know, being as it's the same four guys in here... you should see by now that nearly EVERY TIME I POST IN HERE I ASK ERIK HOW TO GEAR.
It does not require you to try to be a good samaritain and answer my silly "how do I gear?" question."
No no, what's your roll out? Roll out is a much better way to determine the proper ratio for your car. That way you can compare between two cars with different tire sizes. Much more accurate.
I'd also recommend BK pitch gears, they are definitely better. They hold up better than 64 p.
Old 08-05-2004, 03:28 PM   #6743
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally posted by Evicerator
Erik,
How should I gear my derlin diff halves?
Is this with a Brushless Motor?
Congrats on your Win man......
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 08-05-2004, 10:56 PM   #6744
The Evicerator
YAY!
Thank you!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 08-06-2004, 12:06 AM   #6745
Vegetto's Avatar
Default SETUP?
Hey guys,
Does anyone have a good setup for Foams and a Large VHT Track?
Thanks guys
Vegetto is offline   Reply With Quote
Old 08-06-2004, 08:06 AM   #6746
rc-zombies's Avatar
Originally posted by rc-zombies
yup labor day weekend... all the big name drivers will be attending....
http://www.speedworldraceway.com/1st...Sedan_Race.cfm
race was cancelled
due to the second world race warm-up.
Old 08-06-2004, 08:16 AM   #6747
coastaltony's Avatar
Sorry to hear that!
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 08-06-2004, 09:25 AM   #6748
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
hey rc - zombies where you get the hara's twister esc at and how much ? oh yea what pinion should i buy for a monster stock on my new pro 4 ?!?
Roberto Falcon is offline   Reply With Quote
Old 08-06-2004, 09:27 AM   #6749
rc-zombies's Avatar
try Horizon hobbies...
if you're LHS orders from Horizon..they can order you one.
Old 08-06-2004, 10:18 AM   #6750
Trader Rating: 36 (100%+)
http://horizon.hobbyshopnow.com/prod...?prod=HBS90000
Part Number: HBS90000
Product Name: Twister Speed Control
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
