Old 08-05-2004, 04:12 AM   #6721
Skill's Avatar
Zombies, did you use any grease or lubrication with the delrin pivot balls? I didn't think it was necessary but I'm just wondering. I've had the delrin pivot balls for about 2 months now, suspension is smooooth.
On a side note, the delrin diff outdrives actually weigh 0.1g more than the stock outdrives, I thought they were supposed to be lighter?
Skill is offline   Reply With Quote
Old 08-05-2004, 04:45 AM   #6722
azenis's Avatar
Further to that, as I dont have any, what should I buy as a replacement for the white cap and red cap grease as mentioned in the instruction manual?
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 08-05-2004, 05:41 AM   #6723
Skill's Avatar
I use silicon grease for the white cap grease, and Associated Black Grease for the red cap.
Old 08-05-2004, 07:51 AM   #6724
rc-zombies's Avatar
nope... I didn't use any grease...wasn't necessary...
the stock graphite outdrives will alsway be lighter...due to being more porous material and delrin is rock solid with properties of steel.
Old 08-05-2004, 09:41 AM   #6725
kewdawg's Avatar
Originally posted by galway
Hase anyone Tried the Extreme Racing Chassis or any of their products?
http://www.xtremercracing.com/PRO_4.cfm
I have the sivler surface graphite chassis on my Factory team TC3. I used it for carpet last indoor season. The car worked great. Very stiff! Don't know the thickness, though. I'll have to measure it.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 08-05-2004, 10:04 AM   #6726
Registered User
I use Woodland Scenics Premium Gear Lube on ball diff and diff gears. Extremely smooth. 100% better than white cap. I use Woodland Scenics Moly Grease w/Molybdenum replace red cap.
Aku-Man is offline   Reply With Quote
Old 08-05-2004, 11:09 AM   #6727
rc-zombies's Avatar
Victor... from SWR... contact me asap!!!!
got something for you....
and you can pick it up today at SWR...
sorry lost your email....
Old 08-05-2004, 11:42 AM   #6728
Skill's Avatar
I assumed that the delrin ones would be lighter, but they are definately stronger.
Old 08-05-2004, 12:09 PM   #6729
The Evicerator
Erik,
How should I gear my derlin diff halves?
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 08-05-2004, 12:32 PM   #6730
rc-zombies's Avatar
Originally posted by Evicerator
Erik,
I would gear it the same as you would the stock diffs...
Old 08-05-2004, 12:52 PM   #6731
Skill's Avatar
What do you mean by how should you gear them? They use the same bevel gears as the stock diffs do and are no different except their material...
Old 08-05-2004, 12:56 PM   #6732
The Evicerator
Default IT'S A JOKE, DAMNIT A JOKE!!!!
You know, being as it's the same four guys in here... you should see by now that nearly EVERY TIME I POST IN HERE I ASK ERIK HOW TO GEAR.
It does not require you to try to be a good samaritain and answer my silly "how do I gear?" question.
If you would like I can add some sort of notation that will allow you all to clearly tell that it is a joke, something like the following:
"THE FOLLOWING IS A JOKE INTENDED FOR THE AMUSEMENT OF ERIK SHAUVER. THIS IS ONLY A JOKE. IF IT WERE A REAL QUESTION IT WOULD HAVE PROBABLY BEEN EMAILED DIRECTLY TO MR. SHAUVER.
REMEMBER, THIS IS ONLY A JOKE."
But, if I did that everytime I made a silly joking comment, the comment itself would lose all commedic value...
Thank you for your attention to this matter.
Steve Weiss
Old 08-05-2004, 01:15 PM   #6733
Send a message via Yahoo to Doug Gaut
Doug Gaut is offline   Reply With Quote
Old 08-05-2004, 01:20 PM   #6734
Skill's Avatar
Lol, I guess I was a bit slow there....
Old 08-05-2004, 01:25 PM   #6735
X-Garage's Avatar
I use red TAMIYA spring in the rear and that is the softest TAMIYA has. I do need more traction on the rear...what else could I do?
X-Garage is offline   Reply With Quote
