Old 08-03-2004, 06:55 PM   #6661
racer's Avatar
sorry everyone, didn't mean to start anything like this here.
just needed some opinions.
racer is offline   Reply With Quote
Old 08-03-2004, 07:04 PM   #6662
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Racer.....Im not sure what you mean by what you started? It looks like everyone is just giving you opinions it doesnt look like any bashing or flaming has taken place if thats what your are eluding to.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 08-03-2004, 07:42 PM   #6663
azenis's Avatar
no it is all good
i have the BMI but would definately go for the PRP if i was buying (mine came with the car) even if it does need a bit of work with a file and sandpaper and glue... simply for the extra tuning options it offers, and the added protection from the braces.
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 08-03-2004, 07:45 PM   #6664
Michal101's Avatar
Originally posted by Kevin K
Michal....Im not Ben but I have been testing his Pro-4 HTS chassis and some of the options are......the battery is moved in closer to the drive shaft, there is the ability to play with the rear wheel base by moving the arm forward and rearwards, there is also braces that will go around the chassis can guard your electronics from a side impact, also you have the ability to use 3 center posts to further stiffen up the car or move the post the the front or the rear of the chassis to allow the opposite end of the chassis to have a little more flex.....this option is a great tuning aid. Its worked great so far.....I cant ask for anything more from it.
Guys I have seen chassis that BMI has made and they are of very great quality if you go with either chassis you will be getting a work of art. PRP does offer more options on the chassis....and going with either one you wont go wrong. Both are 3mm and once you build up a car with a chassis that thick its amazing how stiff it becomes....I think the PRP chassis would be a little stiffer as the top deck that comes with the HTS kit is full and has very few cut outs where the BMI ones that I have seen are cut out a little more so a little more flex.
Kevin,
I appreciate your prompt and thorough reply.
Thanks, Mike
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Michal101 is offline   Reply With Quote
Old 08-03-2004, 08:37 PM   #6665
X-Garage's Avatar
Thank you HPI!
X-Garage is offline   Reply With Quote
Old 08-03-2004, 08:54 PM   #6666
X-Garage's Avatar
I did put both capacitors directly to the speed control. Is this set up work? I haven't ran the car yet...just want to check before I burn everything.
Old 08-03-2004, 08:55 PM   #6667
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by azenis
no it is all good
ON a side note you could ask Jason at BMI to make a few mods to the BMI chassis for the Pro4... I asked him to change a few things on the sets that I bought ... PM him or call him up to ask
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 08-03-2004, 09:00 PM   #6668
should be no problem.... Hara I belive does this to
-Dave
Old 08-03-2004, 09:02 PM   #6669
azenis's Avatar
yeah cool!
-Dave
Nige
Old 08-03-2004, 09:04 PM   #6670
X-Garage's Avatar
-Dave
alright! I will bring it to the track tomorrow then..thanks!
Old 08-03-2004, 09:09 PM   #6671
azenis's Avatar
but they are schottky diodes not capacitors, they usually go on the motor between the +ve and -ve posts and oyu dont really need two of them, though i cant see why two would do any harm.
They work better the closer they are to the motor.
The novak gt7 has one inline on the motor wires.
just make sure the end with the silver stripe is on the +ve side or they will explode.
Nige
Old 08-03-2004, 09:27 PM   #6672
X-Garage's Avatar
yes..they are diodes...my bad...
yes, I have + on silver stripe side. I don't know why I have 2....may be 2 better than 1...
Old 08-03-2004, 09:33 PM   #6673
azenis's Avatar
cool
hey whats with the bits of foam between the battery slots?
Nige
Old 08-03-2004, 09:46 PM   #6674
X-Garage's Avatar
just to keep my batteries in place..
Old 08-03-2004, 10:05 PM   #6675
azenis's Avatar
Stick packs or side by side? I guess it would sqush into between the cells in a side by side and hold it in
does it help much?
where do you get that foam?
Nige
