Old 08-02-2004, 06:37 PM   #6616
brushless's Avatar
Originally posted by rc-zombies
yea..at first they look fine...but after it's broken in it's when thinks start to happen. This is when you make your final adjustments... after this...you should have no problems.... cross your fingers...
I found out what the problem was with the clicking. On the rear input shaft close to the small bevel gear there are two bearings. Between those bearings are 3 washers. The more I drove the car, the more the drivetrain freed up. I had to move the three washers from the front bearing to the rear bearing. This pushed the small bevel gear into the larger gear creating a better mesh and no clicking.
brushless is offline   Reply With Quote
Old 08-02-2004, 06:46 PM   #6617
brushless's Avatar
Default One more thing
Should I worry about getting the new gear sets? Where can I find some info about this? What is the difference?
Old 08-02-2004, 07:31 PM   #6618
HuDy WiNnEr's Avatar
Send a message via AIM to HuDy WiNnEr
Default Re: One more thing
If you want info. on the new gears you could try calling hpi usa. 949-753-1099 and they can help you out. Infact they hooked me up with my new gears today.
HuDy WiNnEr is offline   Reply With Quote
Old 08-02-2004, 07:51 PM   #6619
Speed Demon's Avatar
Originally posted by Skill
I had a bit of side-to-side play in my spur gear, so when I came to rebuild my car I tried adding another spacer behind the e-clip, this didn't work because I couldn't then get the e-clip on. Instead I moved the spacer from behind the e-clip and placed it further back with the other 2 spacers. When this was done there was no more play in the spur, and I didn't even have to add any spacers . If you don't understand that let me know and I'll show you on the instructions
I think I get what you mean... I'll try that and at the same time, I'll order the SHP-16 from square..
Cheers..
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 08-02-2004, 09:34 PM   #6620
jedi's Avatar
Default Stripped Servo Gears
I stripped a couple of servo gears too. turns out I had too much EPA on my radio and this caused the servo horn to hit and bind with the servo case during full left turns. You may want to check that out.
It's better to be lucky than to be good......when it comes to getting a clean run in qualifying!
jedi is offline   Reply With Quote
Old 08-03-2004, 08:35 AM   #6621
brushless's Avatar
Default Re: Re: One more thing
But where did everyone find out about these new gears. Did HPI send out a notice or put something on their web site? Was there a problem with the original gears?
Old 08-03-2004, 08:43 AM   #6622
Send a message via AIM to galway
Default Re: Re: Re: One more thing
I take it you haven't run the original gears much. The bevel gear teeth on the one way would stip off very easily in a moderate crash, or bump.
galway is offline   Reply With Quote
Old 08-03-2004, 08:46 AM   #6623
brushless's Avatar
I've been running the original gears for a month now. I didn't even know about that problem.
Old 08-03-2004, 08:46 AM   #6624
Regional Moderator
Darkseid's Avatar
Yeah, the ring gear had a tendancy to break when mounted on the one-way. HPI came out with these new gears as a cure for that problem. That, and a new backing plate for the one-way.
I don't know where everyone found out about them. I found out here.
TLR 22...Tamiya F104...
Old 08-03-2004, 08:47 AM   #6625
X-Garage's Avatar
me too! I have been using the original with no problem..what make the new gears better?
X-Garage is offline   Reply With Quote
Old 08-03-2004, 08:48 AM   #6626
Regional Moderator
Darkseid's Avatar
I've run mine all season, but I'm also not using the oneway, so...
Old 08-03-2004, 08:57 AM   #6627
Skill's Avatar
There's nothing wrong with the 1st version gears when running a ball diff up front, the problem is when the on-way is used. I broke 3 sets of gears with my one-way before changing to a ball diff and I haven't broken any gears since, must have been going for about 5 months now.
Skill is offline   Reply With Quote
Old 08-03-2004, 09:12 AM   #6628
popsracer's Avatar
Default Pro-4 success
Guys;
Just wanted to let everyone know that I too had a very successful weekend with my Pro-4.
Qualified 5th overall in Stock Sedan out of about 30+ entries and finished 3rd in the "A" main (Hitec Race).
popsracer is offline   Reply With Quote
Old 08-03-2004, 09:15 AM   #6629
brushless's Avatar
I've been running a one-way the whole time, and I've also hit the wall on two occasions hard enough to bend 2 CVDs and the gears are still fine. I guess I'll call and get some free gears anyway. I recently purchased some extra bevel gears, part # 73501, just as replacements. Are these the newer versions too?
Old 08-03-2004, 09:17 AM   #6630
Regional Moderator
Darkseid's Avatar
Hey whats up popsracer...
Good to hear your having good luck with your Pro 4.
SEO by vBSEO 3.5.0
