Like Tree5Likes
Old 08-01-2004, 10:13 AM   #6586
The tc3 dogbones are a direct fit, has anyone tried the UJ's instead of the CVD's, do they wear any better, any difference. Thanks. Jonathan.
jonny69 is offline   Reply With Quote
Old 08-01-2004, 10:14 AM   #6587
X2
X2's Avatar
Originally posted by Pit-racer
Is there a good replacement for the cvd (purple part)? These seem to break faster than when I had my pro2, they never broke then, maybe just bend. Are these new ones made cheaper? Someone needs to address MIP about these.
Yea I hate the MIP ones, the holes in mine where the pin goes through just get bigger and bigger untill they just pull through, meaning a new bone (£10 each here ) or the hastle of drilling a new hole.
Id like to try these tho (see attachment). Any body have any experience with these? Are they more durable, lighter heaveir?
Thanks.
X2 is offline   Reply With Quote
Old 08-01-2004, 10:48 AM   #6588
Pit-racer's Avatar
Direct fit? Also are they cheaper in price?No problems running them in mod?
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 Red
Pit-racer is offline   Reply With Quote
Old 08-01-2004, 12:06 PM   #6589
rc-zombies's Avatar
for mod get the shiny steel ones... more durable than the aluminum bones
Old 08-01-2004, 03:37 PM   #6590
Thad Garner's Avatar
Originally posted by xxxkat
if you run the 2mm chassis are you checking the tweak every run
I feel you should check the tweak every run no matter what car/chassis you’re using. Preparation and maintenance goes a long way. We use the 2mm chassis for outdoor track and the 3mm for carpet with foams. The 2.5mm is a good compromise between the two, that’s why it’s the standard kit chassis.
and if you are,is it tweaked?
If you crash
R1Wurks - Awesomatix USA
Thad Garner is offline   Reply With Quote
Old 08-01-2004, 03:47 PM   #6591
Oasis's Avatar
Trader Rating: 36 (100%+)
Dont crash very often..Yea I know I should but I check it if the car starts to handle funny,and before the mains.But you are right I should be checking after every race.
Oasis is offline   Reply With Quote
Old 08-01-2004, 04:34 PM   #6592
treky11's Avatar
Don't listen to Thad, he doesn't know what he is talking about
Seriously. You going to be at the NY Challenge there Thad???
treky11 is offline   Reply With Quote
Old 08-01-2004, 05:26 PM   #6593
Yes...unless something else takes priority
Old 08-01-2004, 05:56 PM   #6594
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Nothing is more important than the NY challenge,Meeting Fastharry and Treky 11,and NITRO cars.........
Thad will be there.....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 08-01-2004, 06:28 PM   #6595
NVisible's Avatar
that sir is one huge sig
NVisible is offline   Reply With Quote
Old 08-01-2004, 06:34 PM   #6596
fastharry™'s Avatar
Old 08-01-2004, 07:27 PM   #6597
Pit-racer's Avatar
Yes there is ...... The Austin HPI Challenge!
Old 08-02-2004, 12:45 AM   #6598
Speed Demon's Avatar
how do you all fix the PRO 4 spur gear that worble.????
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 08-02-2004, 12:47 AM   #6599
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Make sure you tightened the spur in an "X" pattern.
[1] [3]
[4] [2]
Or check the spur if it's bent/warped.
DOMOisCOOL is offline   Reply With Quote
Old 08-02-2004, 12:52 AM   #6600
Tek Nickal's Avatar
[1] [3]
[4] [2]
Count the number of turns on each screw. If you get it exactly right then it should run very smooth.
Tek Nickal is offline   Reply With Quote
