Like Tree5Likes
Old 07-29-2004, 10:17 AM   #6541
rc-zombies's Avatar
Originally posted by X-Garage
Do you use spool front and rear?
only for the front... as with the one-way you need alot of practice runnng a spool. also be prepared to replace more parts.... running a spool is very hard on the drivetrain.
Old 07-29-2004, 10:19 AM   #6542
Skill's Avatar
The spool is usually for the front only.
I got my Delrin outdrives yesterday and haven't yet fitted them (I got them from my LHS, so pretty much any model shop in the UK should have them now).
I'll probably fit them next week sometime and let everyone know how they go.
Skill is offline   Reply With Quote
Old 07-29-2004, 10:29 AM   #6543
Originally posted by rc-zombies
you can..some use the Losi Spool pads without the balls and pretty much lock up the diff tight.
I didn't like the Losi Pads because they use sandpaper that will eventually leave sand inside my diff case and get into my gears. I guess I'll just tighten my diffs until HPI or someone else comes out with one. Thanks
DOTMAN is offline   Reply With Quote
Old 07-29-2004, 10:35 AM   #6544
X2
X2's Avatar
Hey skill, how much did you pay for the derlin out drives in the UK?
X2 is offline   Reply With Quote
Old 07-29-2004, 10:39 AM   #6545
rc-zombies's Avatar
or use thin rubber washers from Home Depot.. and lock it down tight.
Old 07-29-2004, 10:41 AM   #6546
I'll try that...thanks
Old 07-29-2004, 10:50 AM   #6547
pro4_chris's Avatar
s anyone on here running the Derlin outdrives, what do you think of them
i've had mine about a week now and i run last weekend they felt quite abit smoother than the std ones, they are 14.99 over in england which is about $27
Chris
pro4_chris is offline   Reply With Quote
Old 07-29-2004, 10:58 AM   #6548
Is that per pair of for four. Thanks. Jonathan
jonny69 is offline   Reply With Quote
Old 07-29-2004, 11:02 AM   #6549
John Doucakis's Avatar
Default Hara's set up
It shows on Hara's set up from the nationals he just won that he used a spool up front.
Did the rules not allow for a one way or was it clearly his choice to use a spool as he thought it was the best choice?
John Doucakis is offline   Reply With Quote
Old 07-29-2004, 11:06 AM   #6550
rc-zombies's Avatar
1 pair for 1 diff.
Old 07-29-2004, 11:07 AM   #6551
rc-zombies's Avatar
Default Re: Hara's set up
racers preference... what ever it takes to win
Old 07-29-2004, 12:37 PM   #6552
coastaltony's Avatar
Default delrin outdrives
I won't get mine til this weekend... I've had them on my other cars.. delrin diffs makes for a very strong, light, and smooth diff.
Are you getting any spares?
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 07-29-2004, 12:55 PM   #6553
rc-zombies's Avatar
Default Re: delrin outdrives
yes...but they are all spoken for... my friend is still in the UK...
I'll see if he'll be able to get more before he comes back this weekend...
Old 07-29-2004, 01:11 PM   #6554
Thanks, let me know.
Old 07-29-2004, 03:35 PM   #6555
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
the HPI version has not been released.. you'll have to make one if you have extra diff parts.
This directed to Zombie or anyone for that matter.....I was looking through the latest RC Driver mag.....and well any way they have a spool in there from the MRC touring car which is a shaft drive car. And its only like 19 bucks retail and with it being MRC it should be metric so has anyone tried this spool to see if it will fit a Pro-4? It looks really close but I dont run a spool as I race mainly with foam tires but this might be something for you rubber tire guys to try out. Just a thought until one is made from HPI or someone else for that matter.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
