Like Tree6Likes
Old 07-26-2004, 07:15 PM   #6421
X-Garage's Avatar
DOMOisCOOL
I see!
Here is my solution for now.
- put 2 layers of double side tape under receiver.
- keep servo wire away from other wires.
- try different crystal (just ordered channel 70)
thanks
X-Garage is offline   Reply With Quote
Old 07-26-2004, 07:20 PM   #6422
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
No problem.
Before, I had velcro to hold the receiver, had no glitches. But to play it safe, I switched over to 2 layer double sided tape.
Also, does the whole car glitch? Do the servo glitch too? If so, there may be interference or bad reception. If only the 'throttle' glitches, it has to do with your motor, or ESC.
DOMOisCOOL is offline   Reply With Quote
Old 07-26-2004, 08:15 PM   #6423
Check your antennae for small cuts or abrasions if ti has been cut down replace it with the proper lenght .
sportracer is offline   Reply With Quote
Old 07-26-2004, 09:34 PM   #6424
azenis's Avatar
some people (myself included) often get a glitch in one point on our track. We race on 2 school netball courts, that has 4 goal/ring posts, and there is one in particular, that is the furthest away from the driver stand, that seems to cause glitching when you get near it...
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 07-26-2004, 09:40 PM   #6425
azenis's Avatar
What is a good selection of springs to own for the Pro4?
There are only about 3 or 4 HPI ones on tower and i notice a lot of people refering to associated springs on setupsheets, and since i have to place an order from tower i thought i may as well stock up on some springs.
Also what do people think of the novak millenium pro charger?
Nige
Old 07-26-2004, 09:57 PM   #6426
DOMOisCOOL's Avatar
The Novak Millenium Pro charger is a great all around charger. But you can get a better one for the money. I recommend the LRP Pulsar Competition.
Old 07-26-2004, 10:03 PM   #6427
Tek Nickal's Avatar
Just because you just got one. BAH!
Tek Nickal is offline   Reply With Quote
Old 07-26-2004, 10:41 PM   #6428
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by rc-zombies
that would be kit #187 Zombie Edition
and #188 JDM-DOHC-SiR Blue edition.
That would be nice
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-26-2004, 10:54 PM   #6429
azenis's Avatar
That was the other one i was looking at
On Tower it mentions other things you need to get with it, and points to a small lead battery, does it work ok just off the battery in the car? or any AC => DC converter power supply you can get from Jaycar (australian store) etc?
Aside from the discharge and motor run-in functions, why is it better than the Novak? (Yes moderators I will post this in a new thread as well)
Nige
Old 07-26-2004, 11:01 PM   #6430
acutts's Avatar
Default Re: Here are some new problems.
Originally posted by brushless
This past weekend when I was racing, my Pro 4 all of a sudden wouldn't move any more. One of the rear wheels would spin freely. (Is that a word?) I took the rear diff apart and found out that the diff bolt head had totally broken off. I didn't have a replacement, so I replaced it with Associated's T-Nut thrust bolt, part number 6575. It went together fine and functioned properly. A few runs later I heard a spoadic clicking sound that sounded like it was coming from the rear of the car. I checked the spur and pinion gears and they were fine. I also took apart the front and rear diff and all the gears looked fine too. Does anyone know what could be causing this?
P.S. I haven't run the car since I took it apart and put it back together.
I also bent a front dog bone, but that's another story.
I had this problem .... on the purple dog bone the silver pin becomes loose and moves out further to one side and this clips the edge of the ball-stud that holds the turnbuckle above. Just even up the pin that seats in the outdrives and problem solved. Especially noticeable if you have removed some of the spacers below the ball-stud.
acutts is offline   Reply With Quote
Old 07-26-2004, 11:10 PM   #6431
DOMOisCOOL's Avatar
Don't post in new thread. Just do a search or something.
You will need to get a Power Supply (ex. US 120vAC->12vDC). You can get a fairly cheap one. A 10amp one will be enough.
In my opinion, those features make it more worth the money. Motor run in is very helpful for powering Comm Lathes, and breaking in motors. The discharger only discharges at 10a, but better than nothing.
Old 07-26-2004, 11:11 PM   #6432
acutts's Avatar
Originally posted by DOTMAN
Does anyone know where I can get a spool for the Pro4?
Build One!
HPI are working on a factory one and Hara has been testing so it should be released in the next couple of months I guess. I built one and it works great .... there is another thread I started on how to do it 'Building a spool'.
Old 07-26-2004, 11:31 PM   #6433
azenis's Avatar
Wont it run off a car battery?
Nige
Old 07-27-2004, 12:44 AM   #6434
Trinity2's Avatar
the 75190 diff brace will fit hte version 1 gears..
if you have lots of version 1 gears get the PRP diff plate.. I think it's better than HPI's... the Plate covers the entire gear.
Thanks zombies. I have a lots of those old gears. I just wonder when Rc Model get those new gear set ver 1.1? I send email to them... and i`ll wait answer.
Why? Reason is, at i have a good relationship with Rc Model and make all my orders from them
Trinity2 is offline   Reply With Quote
Old 07-27-2004, 12:50 AM   #6435
Trinity2's Avatar
Smile
Originally posted by Erik Shauver
Trinity2: If you got your car in the US (kit#185), give HPI USA customer service a call about the new gears and the one-way brace.
-E [/B]
Erik.
Yeah, i got mine #185 from SpeedTech last spring.
I live in Finland, so is it problem to give a call?
Sorry my bad english.
