Old 07-26-2004, 04:06 PM   #6406
rc-zombies's Avatar
Default Re: DITTO!
Originally posted by Michal101
Ditto on sportsracer's post. They were great.
BTW, has anybody seen the HPI spring kit out yet or even the individual springs? I do know that you can use Xray or AE, but I wanted to stay with HPI.
Thanks, Mike
The New HPI Pro4 springs has been out for a few months now..check Tower or Speedtech,
Old 07-26-2004, 05:20 PM   #6407
Send a message via Yahoo to Doug Gaut
X-Garage, were you running stock with a monster by chance?
Doug Gaut is offline   Reply With Quote
Old 07-26-2004, 05:43 PM   #6408
rice's Avatar
Originally posted by X-Garage
What cause the glitching? I ran the car with Quantum2 and Airtronics reciver. There is only one spot on the track that I I always lost the control. What would be your wild guess?
one of my friend also have that problem also. in a particular spot of the track it lost control. just check your the mounting of your receiver. be sure it is not so close to the chasi. what i did is put a 2 double sided tape. 2nd try to check your esc. especially the wiring,cut wires this are some cause of glitching.
rice is offline   Reply With Quote
Old 07-26-2004, 06:13 PM   #6409
X-Garage's Avatar
I'm runing 19T right now.
X-Garage is offline   Reply With Quote
Old 07-26-2004, 06:28 PM   #6410
X-Garage's Avatar
Do you mean cut the wires or don't cut them? I was thinking to cut them but I'm just not sure that it should be the way to fix or just change the channel. I just ordered new set of crystal channel 70. The one I have now is 88 made by "performance...something"
Here are some pic of the electronic installation.
Old 07-26-2004, 06:55 PM   #6411
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Put the antenna on top instead of the chassis.
Also, are there any street lamp's near that glitching area? Sometime's my car glitches near the street lamp.
DOMOisCOOL is offline   Reply With Quote
Old 07-26-2004, 06:58 PM   #6412
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Default Re: DITTO!
Thanks, Mike
There are other HPI springs that work just make sure they are the 25mm long ones...thats the same length of the Pro-4 springs. Some of the longer ones wont let you get your ride height low enough. There is a Spring chart here in the fourm someplace it might even be on HPI's Site....just look for ones that are 25mm long.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 07-26-2004, 07:38 PM   #6413
X-Garage's Avatar
If I put antenna on the top...the antenna wire would touch the top chassis and it would be even worst?
The area in the circle is when gliching kick in. There is only one spot in the whole track. There is no street lamp around that area. I try different position on the stand and nothing help.
Old 07-26-2004, 07:38 PM   #6414
Does anyone know where I can get a spool for the Pro4?
DOTMAN is offline   Reply With Quote
Old 07-26-2004, 07:54 PM   #6415
DOMOisCOOL's Avatar
X-Garage: To "protect" the wire from hitting the top deck, use a piece of fuel tubing (from nitro cars). I'll post a pic of my setup later.
Old 07-26-2004, 08:01 PM   #6416
Team EAM
EAMotorsports's Avatar
Trader Rating: 76 (100%+)
Send a message via AIM to EAMotorsports
X-garage....Try moving or unplugging your transponder...Here lately I have seen the personals cause a lot of glitching when mounted on top of the servo....Not sure why. If you move it away from the upper deck it goes away on most cars.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 07-26-2004, 08:03 PM   #6417
DOMOisCOOL's Avatar
EA
I have mine mounted on top of the servo and I've had no problems.
Old 07-26-2004, 08:05 PM   #6418
Team EAM
Mine is mounted on top of mine too and I have no problems...But I have seen it bite about 10 people since the personals got popular about a year and a half ago...Very weird. But Ive seen people change everything on the car except the transponder and still have glitching...un plug it and it stops asap!!
Its worth a try!!
EA
Contact Us
Old 07-26-2004, 08:07 PM   #6419
X-Garage's Avatar
How about crystal channel? Is there a best channel or worst channel for 72mhz?
Old 07-26-2004, 08:08 PM   #6420
DOMOisCOOL's Avatar
