Hpi Pro 4
#6376
Originally posted by brushless
I don't think it's the CVDs. I got someone to hold both rear wheels when I gave it some gas, and it made the clicking noise. The only thing I can think of is that the bevel gears in the rear diff are not close enough to each other and they slip sometimes. Does that sound right?
if the shimming was done per manual and diffs look fine...might be something else.... mostly like something rubbing on the diff outdrive, driveshaft, cv axles etc.
remove the drive shaft and run it..and see if it still makes the noise... if there is no noise..the problem is up front... if there is..you've narrowed down which half of the car the problem is on....
#6377
What do you mean shimming?
#6379
After you fixed the rear diff with the associated t nut and screwed down the diffcases, were the shims on the small bevel gear side in the corrrect place? ( kinda hard to explain- i mean the three shims on the input shaft which go between the two small bearings) If not this would cause incorrect gear meshing and possibly what you are experiencing.
HTH.
HTH.
#6380
I think that's the problem. Somewhere the spacers might be off. I need to check that. Thanks guys.
#6381
page 14 of the manual... part #Z892 that goes on the outdrives..
you'll have to add or take away as needed.
Page 15... part # Z877 (3) shimms on the bevel gear..
If you have forgotten these... put them in place per the manual.
It always pays to read the manual a couple times before you start building... there may be little things you might miss...
especially on a Pro level kit like this...
#6382
Thanks. It's just weird that it would take this long for the clicking to appear. I've been running this car for two weeks and haven't changed anything with the input shaft spacings or anything.
#6383
#6384
PRO4 Tweak
Without reading back throgh all of this what are the things too look at to remove a tweak in the car when installing the top deck?
Thanks,
Thanks,
#6385
Re: PRO4 Tweak
Thanks,
Thanks,
#6386
Make sure the chassis is flat,I use a peice of glass(large oval)and tighten the screws a bit at a time(?)and I tighten the screws for the steering last.and I do tighten them in a pattern..front to rear,left to right,not sure how everyone else is doing it but this seems to work for me.
#6388
use the IRS AE bones w/pin cusions. i ruined the front two mip bones with the oneway(how idk) but since i switched over to the irs ones i havent had any prolblems.
lazyboy
lazyboy
#6389
Re: CVDs
Originally posted by StewartFan20
Are there any companys that make after market CVD kits for the Pro4? Is there any reason to use another manufaturers CVDs in the Pro4?
Square RC make the bones and axles in TI.
THe TC3 Dog bones is a direct fit.
THere is no reason to use others... it's all racers preference and how mush $$$ you want to spend...
#6390
I just need the new gear set ver 1.1 for my Pro4, but i can`t find any from RC Model HK
They only sell that 75190 one-way gear brace
I need bouth of them to make that front diff stronger... wright?
