Old 07-21-2004, 02:51 PM   #6286
robk's Avatar
Trader Rating: 22 (100%+)
Rookie solara-
I came in second at the last Tinley park big race with this
front
40 shore tire
35 wt #5
2nd hole in on tower
outside hole on arm (you can run this if you run steering arm as bleow)
Losi black? 25 lb spring
6* caster
camber link on inside hole
3mm spacers under ball end
1* camber
black sway bar
forward hole on steering arm
1.5 or 2mm spacer on susp. mounts
you may want to run .5mm kick up
1.0 toe block
0* toe at wheels
rear
37 shore tire
35 wt #3
all the way out on tower
middle hole on arm
1* camber
camber link on inside hole at chassis
inside hole on hub
3mm spacer under ball end
susp. mount flat on chassis
again, you may want to add a small amount of anit squat
no rear swaybar
hubs all the way back
2 diffs
ran the center post (you may want to try to run w/o it)
102 spur33 or 34 pinion w/ 9 turn epic
tires around 59 mm
you may want to try the rear camber link out on the hub
raising and lowering the camber link is a good fine tuning adjustment
I think KevinK ran very similar to this, he gave me a lot of advice and help. Big ups to Kevin! i'm sure he can correct me if I'm wrong
This is for med traction asphalt (sprayed parking lot) Hope it helps
Old 07-21-2004, 03:15 PM   #6287
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
thanks Rob.....your car was very good aswell last time out. I just wish I would have had parts to fix mine that weekend. What Springs were you running in the rear Losi Purples maybe?
For Gearing I ran 36t with the 96 spur with an 8 turn Epic.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 07-21-2004, 08:27 PM   #6288
robk's Avatar
Ahhh, forgot the rear springs. I actually ran the Losi blacks.
Old 07-21-2004, 08:56 PM   #6289
Hi Thad,
Can please mail me ,what spring are u using and what piston shock oil are u using thanks
ongsan is offline   Reply With Quote
Old 07-21-2004, 08:58 PM   #6290
Thad,
We met at HPI changelle 2002 at NAGOYA still remember ?
Old 07-22-2004, 12:30 AM   #6291
acutts's Avatar
Originally posted by Skill
Looks like Hara is running carbon fibre camber link mounts, but just carbon fibre which fits over the stock mounts. He's also running purple spring perches
Also, does anyone know what those purple bits are on his steering knuckles?
Does anyone know how Hara attached the washers to limit the travel on the steering?
acutts is offline   Reply With Quote
Old 07-22-2004, 12:43 AM   #6292
in that picture hara isn't using the wheel spacers. is that ok?
peachpie is offline   Reply With Quote
Old 07-22-2004, 12:56 AM   #6293
acutts's Avatar
Just makes the track width slightly less. I don't use the spacers due to using the slightly bigger hex hubs which means you don't have to use the spacers.
Old 07-22-2004, 01:18 AM   #6294
Eirik's Avatar
I used superglue, I assume Hara did as well....
Eirik is offline   Reply With Quote
Old 07-22-2004, 01:23 AM   #6295
acutts's Avatar
Hi Eirik
Thanks ....What washers did you use?
Cheers
Old 07-22-2004, 03:29 AM   #6296
pro4_chris's Avatar
just got my delin outdrives today and the feel pretty smooth
chris
pro4_chris is offline   Reply With Quote
Old 07-22-2004, 03:39 AM   #6297
Registered User
Hara's car at Nat.
Aku-Man is offline   Reply With Quote
Old 07-22-2004, 03:41 AM   #6298
Registered User
Old 07-22-2004, 03:41 AM   #6299
Speed Demon's Avatar
Hi.. can I use the spool on the asphalt track??? or is it used on carpet track only...?? cheers
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 07-22-2004, 03:52 AM   #6300
acutts's Avatar
I used the spool on an outdoor asphalt track last night in my test and it was definitely the fastest option I tried ... and I tried a one-way and a diff and my times were better with the spool and the car easier to drive.
