Old 07-19-2004, 02:04 PM   #6211
rod_b's Avatar
Send a message via AIM to rod_b
I know this is the Pro4 thread but does anyone here know where I can get a titanium turnbuckle set for the HPI Pro2 (preferebly purple).
rod_b is offline   Reply With Quote
Old 07-19-2004, 02:05 PM   #6212
Registered User
Why adding weight at motor area? Isn't that make RR even more heavier?
Aku-Man is offline   Reply With Quote
Old 07-19-2004, 02:14 PM   #6213
rc-zombies's Avatar
the car has tons of steering... adding weight near the motor area helps improve rear traction...and reduce some steering as well. the car is more balanced.... one of the racers at my track has the weights the full lenth of the right chassis... end of servo to the motor...and his car handles very well...
Old 07-19-2004, 02:17 PM   #6214
Frank McKinney's Avatar
Rod, do a search on the HPI sites for the titanium turnbuckle set (it's purple ). Your local shop may be able to order it for you, or look for it online.
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 07-19-2004, 02:20 PM   #6215
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally posted by rc-zombies
....or soon to be released version from HPI which is offset about .5mm to improve handling...
Zombie....what part of the hub is offset?
Its good to see Hara beat all the other guys down like that at the nationals. Lets see what happens at the Worlds.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 07-19-2004, 02:27 PM   #6216
rc-zombies's Avatar
I think the main axle is offset about .5mm back from vertical..
sorry..don't have any part #...looking for it as well...
Old 07-19-2004, 03:04 PM   #6217
Kevin K's Avatar
Thanks.....
Let us all know of the number when you find it or if anyone else does feel free to post that part number.
Old 07-19-2004, 03:21 PM   #6218
S15Racer's Avatar
Default Help me! My car's handling like crap!!!
Ok so i went to the track yesterday to race 19 turn rubber out on our big asphault track. I set the car up with pretty much the box stock setup save for a couple of things: AE blue springs all the way around, rear shocks innermost hole on tower, front camber set to -1 just about (why does the stock setup have positive camber???) CS32 tires, geared 98/36. The first time I took it out for practice, it wouldnt hook up at all, I did maybe one or two turns with it before I decided something was very wrong. So I switched from the 32's to a set of 23's- thats how bad it was. This didnt help of anything, it plowed right through the entrance of each corner and as soon as I picked up the throttle, the rear end swung around. By this point Im getting very pissed, and breaking an a arm before any racing had even started didnt help much. So after I got the arm replaced... (thank you to Tim, I think it was Tim, for selling me the spare arm) ...I raised the rear shocks back up to the stock setting and swapped in the stock gold and silver springs and sauced the rear tires. Heat 1: the car was better, but lets just say I was still mad. It still pushed, not surprising for the amount of traction compound I put on those rears. But it also STILL SPUN OUT, almost as if the compound had never been there. I couldnt think of what else to do until the 3rd heat when I took off both the sway bars, this helped quite a bit but I still couldnt keep up with the other guys. By the main I was back to the 32s with compound on all 4 corners. This was the best handling set up I found all day, and it was still crap. Now it did this weird snapping type thing were it would turn in hard, off throttle, making the rear tires break loose, but then when I'd get on the gas the rears would catch and it would just push badly, but it wasnt a gradual or linear type thing like you'd expect, the whole car would just completely snap offline and wiggle for a moment before composing itself again (sort of)
can somebody help me here, I love this car, but man was it aggravating to drive yesterday
S15Racer is offline   Reply With Quote
Old 07-19-2004, 03:25 PM   #6219
SOuthernFRIED's Avatar
Trader Rating: 21 (100%+)
Yeah what he said///I have been fighting the same issues from day one.Except I started with the stock setup and changed everything one thing at a time without much help.I have now gone to a standard diff in the front and ditched the one-way.Have not driven the car since this change.I also have added 1 degree of anti-squat to try to help too...
James Cooper
SouthernFriedRacing
teamsfr@gmail.com
SOuthernFRIED is offline   Reply With Quote
Old 07-19-2004, 03:27 PM   #6220
HuDy WiNnEr's Avatar
Send a message via AIM to HuDy WiNnEr
Default well...
I had troubles with my car spinning out also, make sure you sauce all 4 tires and check the rear diff. if you hold one tire and the spur gear and you can still spin the opposite wheel your diff. is to loose. also If it only spun to one side then your chassis could be tweaked. thats what I would think
HuDy WiNnEr is offline   Reply With Quote
Old 07-19-2004, 03:35 PM   #6221
rod_b's Avatar
S15Racer - I switched to AE Gold springs all the way around and it made the car feel more stable all the way around. Also, are you running the stock droop settings? Sounds like too much weight is being thrown around. You can reduce the droop more on the front and rear of the car to have it run flatter not roll so much.
Old 07-19-2004, 03:49 PM   #6222
robk's Avatar
Trader Rating: 22 (100%+)
This looks like the new offset knuckle part# ---
31414 - Aluminum front knuckle (trail attaching /Pro4) - ¥3,800 -7/8 shipments
Old 07-19-2004, 03:51 PM   #6223
rc-zombies's Avatar
Thanks!!!..
and it's in stock at R10
3023430231414,HPI,,3800yen,31414 PRO4 ALUMINUM FRONT UPRIGHT SET
Old 07-19-2004, 03:54 PM   #6224
try also taking the rear metal spacer from the rear toe blocks out it will help settle the car a little
syntex1 is offline   Reply With Quote
Old 07-19-2004, 04:02 PM   #6225
BlueisBetter's Avatar
Any of you guys try a little anti dive on the front you can still keep your settings fairly soft................
BlueisBetter is offline   Reply With Quote
