Old 07-07-2004, 07:47 PM   #6046
Originally posted by Pit-racer
I just went thru my pro4 and rebuild it. Do you guys have trouble w/ the e-clip that goes on the spur retainer? Does it cause the spur to be off center as it spins?(wobble a bit)
It shouldn't wobble with the stock spur. Mine spins true and free. Check your spacers inside the diff case and make sure they are located correctly.
Downforce is offline   Reply With Quote
Old 07-07-2004, 08:28 PM   #6047
Pit-racer's Avatar
They are all in the right spots. Spur is a new one also. I'm gonna remove it and see if thats the problem.
www.igthobbies.com / Serpent Cobra GT / 748 TQ / Serpent Eryx 3.0 / Desoto Racing / Veytrex.com / JZRacing / Flo-Control
Pit-racer is offline   Reply With Quote
Old 07-08-2004, 09:19 AM   #6048
rice's Avatar
question
is der a pro4 hara edition?
rice is offline   Reply With Quote
Old 07-08-2004, 09:23 AM   #6049
rc-zombies's Avatar
Originally posted by rice
question
yes...it's pretty much the stock version...
I don't think we'll see a Hara Version. his car mostly stock...
Old 07-08-2004, 09:25 AM   #6050
If you have play in your spur check the position of the 3 smaller shimss and if needed put another one in.
Steve B is offline   Reply With Quote
Old 07-08-2004, 10:26 AM   #6051
Pit-racer's Avatar
There is no play, it might be the 4 screws or the pin it sits on or the e-clip. I will find it Is there a plate made for both sides? to sandwich the spur evenly?
Old 07-08-2004, 12:30 PM   #6052
Skill's Avatar
PRP make a "TruSpin" spur gear plate which goes on the side with the screws, this should help.
Also, Square make a spur gear plate machined with the output shaft so there shouldn't be any play in that.
Skill is offline   Reply With Quote
Old 07-08-2004, 12:38 PM   #6053
rc-zombies's Avatar
The square spur gear plate and output shaft is great..zero play..lots of acceleration... highly recommended!
Old 07-08-2004, 12:50 PM   #6054
kewdawg's Avatar
Are you using a Hpi spur?When I use any other spur w/ only 2 holes, for the screws(Robinson Racing or Kimbrough), I get a wobble in the spur.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 07-08-2004, 01:06 PM   #6055
cartmen34's Avatar
I'm using Kimbrough 48 pitch gears without any trouble at all.
cartmen34 is offline   Reply With Quote
Old 07-08-2004, 02:05 PM   #6056
Erik Shauver's Avatar
If your car is being rebuilt, it may be time for some new Z251 spring pins (they come 10 per package, enough to redo the front and the rear input shaft pins). They will wear out over time and need to be replaced when you notice play.
Z251, SPRING PIN 1.5x8mm (10pcs) $1.50
Erik Shauver is offline   Reply With Quote
Old 07-08-2004, 02:36 PM   #6057
PW
PW's Avatar
Send a message via AIM to PW
New Part!
TR9502 Alloy input shafts now available from Titanium Racing/Schumacher
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 07-08-2004, 03:16 PM   #6058
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by PW
New Part!
Looks nice
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-08-2004, 04:23 PM   #6059
Assasin's Avatar
question
ha-ha
Assasin is offline   Reply With Quote
Old 07-08-2004, 04:41 PM   #6060
rice's Avatar
assasin,
bro wer's the pic of ur pro4?
