Like Tree5Likes
Old 07-05-2004, 11:17 PM   #6016
Skill's Avatar
Originally posted by Ralf
Guys,
Do you know where I can find the 2mm main chassis ?
I have asked some shops in Japan and they don't even know its existence...
Try www.apexmodels.com they are in the UK but ship worldwide and should have the 2mm chassis in stock.
Skill is offline   Reply With Quote
Old 07-06-2004, 10:15 AM   #6017
X-Garage's Avatar
Where to get that heatsink and what are those two things on the car?
X-Garage is offline   Reply With Quote
Old 07-06-2004, 10:19 AM   #6018
rc-zombies's Avatar
Heatsink you can buy from the Integy website or Ebay.
those two thingyabobs are ferrit magnets to reduce EMI interferrance... not really needed unless your car is really glitching wildly...
Old 07-06-2004, 10:28 AM   #6019
X-Garage's Avatar
Thanks!
I sometime have a problem with glitching. Is there a site to order one of those?
Old 07-06-2004, 10:39 AM   #6020
Default Re: Diff issue revisited
Originally posted by RCBuddha
I think i found the part necessary to solve this diff issue....(this is assuming your using the AE diff Screw, nut and spring already)
For a few nights, i was trying to assemble my diff with the screw head and thrust bearing on one side, and the diff spring and nut on the other. The problem has been that the diff nut needed to be in a longer housing to fit into the long diff halve...
While randomly at the hobby shop, i found AE # 2330; "NTC3 ATD Diff-T Nut" which seems to be the right length to allow the diff to be built in the "Correct" manner.
The only problem? I was unable to pick up the part, and I'm unable to work on my R/C stuff for a while! Anyone wanna spend a few bucks and let us know how it works??? Here's how the diff should build:
http://download.teamassociated.com/p...rawing_tc3.pdf
Anyone else got the time and spare diff to try this out? Zombies? JDM?
My only fear is that it may interfere with the dog bone, but if it works....
Your fear is correct. I spent last week trying to figure this problem out before the race this past Sat. I got a Nirto diff re-build kit and that longer T-Nut was to long bumping into the dog bone. So I went out and bought the standard electric T-Nut assembly (AE part # 6575). When I assembled the diff with the new shorter nut I found that the groove of the long hub was not deep enough causing the T-Tabs to cave in and go all the way down the shaft. This would in turn make it impossible to tighten down the nut anymore because it would just spin in place. I took out my handy dandy rotary tool and made the slots deeper on the long pro-4 hub. Here is a quick drawing of what I did and I am happy to report that she did not bust loose all weekend!!!
- Dana
Rotary Racer is offline   Reply With Quote
Old 07-06-2004, 11:39 AM   #6021
Pit-racer's Avatar
So you guys are putting the spring on the opposite end?
www.igthobbies.com / Serpent Eryx 3.0 / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 Red
Pit-racer is offline   Reply With Quote
Old 07-06-2004, 12:19 PM   #6022
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Default Re: Re: Diff issue revisited
Originally posted by Rotary Racer
[B]Your fear is correct. I spent last week trying to figure this problem out before the race this past Sat. I got a Nirto diff re-build kit and that longer T-Nut was to long bumping into the dog bone. So I went out and bought the standard electric T-Nut assembly (AE part # 6575). When I assembled the diff with the new shorter nut I found that the groove of the long hub was not deep enough causing the T-Tabs to cave in and go all the way down the shaft. This would in turn make it impossible to tighten down the nut anymore because it would just spin in place. I took out my handy dandy rotary tool and made the slots deeper on the long pro-4 hub. Here is a quick drawing of what I did and I am happy to report that she did not bust loose all weekend!!!
- Dana
Dana,
Thanks for the info, I'm glad i wasn't the only one who was trying to find a solution to problem! I only hope HPI is taking your drawing and doing something about the problem!!
BTW, YGPM
RCBuddha is offline   Reply With Quote
Old 07-06-2004, 12:21 PM   #6023
Skill's Avatar
Just pre-ordered PRP's HTS chassis kit...should be good
Oh well...we'll just have to see as it will be a couple of weeks before it is shipped out I guess...
Old 07-06-2004, 12:21 PM   #6024
RCBuddha's Avatar
Pit,
You can use the spring on the same side as the thrust bearing; its just that I think the diff will hold its settings better if the the spring and nut are on the opposite side of the thrust bearing....
Old 07-06-2004, 12:28 PM   #6025
X-Garage's Avatar
Can I use TC3 drive shaft with PRO 4?
Old 07-06-2004, 12:52 PM   #6026
onnetz's Avatar
pro 4 shaft is 163mm
and the tc3 shaft is 175mm
onnetz is offline   Reply With Quote
Old 07-06-2004, 01:52 PM   #6027
Pit-racer's Avatar
Pit,
Thanks, I just was asking cause I'm in the process of redoing everything on the pro4 after this weekend race/tune session.
Old 07-06-2004, 02:03 PM   #6028
Registered User
Why not just add more diff thrust washer? Or make another thrust bearings?
Like = screw-thrust-short cup + long cup-thrust(or thrust washers)-spring-nut
If the screw is long enough.
Aku-Man is offline   Reply With Quote
Old 07-06-2004, 02:09 PM   #6029
Thanks!
I have ordered the ferrit magnets from R10 in Japan, Yokomo has them in reference.
you can also order from them the heatsink, Eagle Racing.
Ralf is offline   Reply With Quote
Old 07-06-2004, 02:15 PM   #6030
You bring a very good point. Reason I did not do that is when the electric T-Nut is resting on the lowest part of the grove it is to far away from the top threads of the bolt. Simply put, the AE or even the HPI bolt is not long enough. I was thinking about heading down to my local metric hardware store and picking up a longer bolt with the correct pitch threads. I will keep you all appraised of my diff adventure
- Dana
