Like Tree6Likes
Old 07-04-2004, 12:09 AM   #5956
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
I believe the stock chassis is 2.5mm.
The 3mm chassis has less flex which is good for carpet racing.
DOMOisCOOL is offline   Reply With Quote
Old 07-04-2004, 12:24 AM   #5957
azenis's Avatar
OK
I race on Asphalt though...
Will this be not good?
Also whats a good collection of gears to have in 48p to run the car with a stock motor and also a mod (I have a 14x2)
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 07-04-2004, 12:27 AM   #5958
DOMOisCOOL's Avatar
What stock motor do you run?
Old 07-04-2004, 12:28 AM   #5959
azenis's Avatar
I cant see how flex can be a good thing on asphalt either? Make the suspension do its job better.
Nige
Old 07-04-2004, 12:32 AM   #5960
azenis's Avatar
I have not got the car yet, should be bere Tuesday, and it is coming with an Orion stock motor, called a "Chrome"
That is all I know about the motor. I dont know what spurs are coming with the car and I dont know if there will be any pinions with it...
Nige
Old 07-04-2004, 02:21 AM   #5961
Default Tweak
Originally posted by Aku-Man
Pro 4 modification for avoiding chassis tweak. See pic. What is that orange color? O-ring?
Looks like an O-Ring!
I guess it stops the screws from pinching the top deck.
Toby is offline   Reply With Quote
Old 07-04-2004, 07:48 AM   #5962
Frank McKinney's Avatar
We used to do something similar on the rear screws of the pro 2 upper deck to add flex and rear grip to the car. Not sure how much good that will do with 8 other screws holding the upper deck on the Pro 4. I can't tell if that is Andy's car or not though.
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 07-04-2004, 07:58 AM   #5963
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Morning Frank...
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 07-04-2004, 08:39 AM   #5964
Skill's Avatar
Which one will be better in the long run?
The HPI one as eventually the supply of version 1 gears will dry up and PRP's brace will become useless.
Skill is offline   Reply With Quote
Old 07-04-2004, 09:28 AM   #5965
JusBox's Avatar
I'm sure PRP can revise their brace.
JusBox is offline   Reply With Quote
Old 07-04-2004, 11:32 AM   #5966
Skill's Avatar
I'm sure they will, but as it stands now the PRP brace will not fit the version 1.1 gears.
Old 07-04-2004, 12:58 PM   #5967
'evening, Harry
Old 07-04-2004, 01:09 PM   #5968
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
It's definately not useless if you already have the brace, or have the ver. 1 gears stockpiled.. I have yet to break a gear with the PRP brace installed. I need to check and make sure I have some spares, as I plan to keep running the PRP brace.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 07-04-2004, 01:16 PM   #5969
DOMOisCOOL's Avatar
Troy, sounds like the PRP brace is working good for you!
I haven't received the Pro 4 yet, but I saw some pics and it looks like it has a lot more electronics space than other touring cars. Is this true? And this is even with a standard servo (not the Futaba S9550).
What are some necessary hopups to get besides the gear brace?
Thanx
Old 07-04-2004, 01:24 PM   #5970
robk's Avatar
Trader Rating: 22 (100%+)
"I realise that but what i wanted to know is why is the 3mm thick chassis better suited to foam, as opposed to a 2mm chassis or the standard 2.5mm (isnt it?)
And If I ran the rubber tyres on the thicker chassis, will it not perform as well?"
I race with Kevin K a lot, he did the testing for the PRP chassis, whic is also 3mm. The chassis works everywhere,, rubber or foam, asphalt or carpet. A lot of Asian drivers seem to like a lot of chassis flex. But the American cars , like the TC3 or XXXS ar both very stiff and work on asphalt.
In other words you'll be fine.
