Like Tree6Likes
Old 07-02-2004, 12:09 PM   #5941
Frank McKinney's Avatar
Default Re: Re: RE: Shimming
Originally posted by Pit-racer
How do we know if we got a new version or an old?
The new ring gears have a very thick outer edge on the side opposite the teeth (I think there are pictures on this forum for them), plus the newest kits include the aluminum backing plate.
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 07-02-2004, 03:45 PM   #5942
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Re: Re: RE: Shimming
Here ya go
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-02-2004, 03:56 PM   #5943
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Does anyone have any setups for a tight/technical asphalt and low traction track?
DOMOisCOOL is offline   Reply With Quote
Old 07-02-2004, 04:42 PM   #5944
Pit-racer's Avatar
Default Re: Re: Re: Re: RE: Shimming
Originally posted by JDM_DOHC_SiR
Here ya go
-Dave
So the new one is on the right.
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 07-02-2004, 04:50 PM   #5945
Default Re: Re: Re: Re: Re: RE: Shimming
Nope new ones are on the left and old ones on the right
Old 07-03-2004, 07:01 PM   #5946
Registered User
Pro 4 modification for avoiding chassis tweak. See pic. What is that orange color? O-ring?
Aku-Man is offline   Reply With Quote
Old 07-03-2004, 09:55 PM   #5947
Oasis's Avatar
Trader Rating: 36 (100%+)
DOMO..It's called "the stock" set up.. No really,the stock set up works very well on the type of track your asking about,dont run the sway bars,try it,I run this set up and it works great..Aku Man..Does not look like that to me,the O rings are just on the steering posts,I dont think it would have much to do on the tweak "problem"..
Oasis is offline   Reply With Quote
Old 07-03-2004, 09:56 PM   #5948
DOMOisCOOL's Avatar
Is it the "instruction manual" setup?
Old 07-03-2004, 10:18 PM   #5949
Oasis's Avatar
Yes it is,I run this set up on a parking lot track,my car is so hooked up..I dont run the sway bars,I do run the oneway(I just have a hard time running a diff)But the car works,In fact the car works better than I can drive.. I'm just glad that no one else runs one at my local track..if they did I dont think I would win to much.. I would try the stock set up and make adjustments off of the base set up,The way I look at it is the sway bars take away rear traction(rear sway bar)and take away front steering(front sway bar) On a loose track some body roll(aka:weight transfer)is not a bad thing,you can also change how much droop you are running without messing with ride height or anything else,and you can can pick up some traction this way..as in running more droop,to get the car to transfer more weight,side to side..harder to explain..I'm not to sure if I'm explaining this..
Old 07-03-2004, 10:23 PM   #5950
DOMOisCOOL's Avatar
Thanks for the explaination
I'll try this setup on Tuesday night and will let you know how it runs.
By the way, the Pro4 I bought from tomdav comes with a PRP 'Backplate'. I heard that an HPI version is coming out and should be more sturdier than the PRP one? Is the PRP one good enough to prevent breakage?
Thanx
Old 07-03-2004, 10:59 PM   #5951
Skill's Avatar
The PRP backing plate covers more of the gear and is much better than the HPI on version 1 gears. However, HPI have brought out some stronger gears called version 1.1, the PRP brace does not fit on these gears so you need the HPI for version 1.1 gears.
Skill is offline   Reply With Quote
Old 07-03-2004, 11:12 PM   #5952
DOMOisCOOL's Avatar
Which one will be better in the long run?
Old 07-03-2004, 11:28 PM   #5953
azenis's Avatar
Default foam setup and 3mm chassis
Hi guys
I just bought a 2nd hand pro4 with bmi3mm chassis, apparantly this is designed for funning foam tyres.
Can anyone tell me if this will be any good for rubber tyres as well?
If not, why is it so?
Sorry, a bit of a newbie question, but I have never run foam tyres OR had a carbon fibre chassis before so I dont know.
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 07-03-2004, 11:33 PM   #5954
DOMOisCOOL's Avatar
Any car can be adapted to run foam/rubber tires.
For example, the Yokomo SD CGM. A lot of people run it on carpet, yet some guys ran it at the Reedy Race (asphalt).
Old 07-03-2004, 11:42 PM   #5955
azenis's Avatar
I realise that but what i wanted to know is why is the 3mm thick chassis better suited to foam, as opposed to a 2mm chassis or the standard 2.5mm (isnt it?)
And If I ran the rubber tyres on the thicker chassis, will it not perform as well?
Nige
